跳转到主内容
加入维修社区 - 创建账户
01 | XY Frame Assembly
你所需要的
  1. 01 | XY Frame Assembly, 01 | XY Frame Assembly: 步骤 1 中的图像 1,3 01 | XY Frame Assembly, 01 | XY Frame Assembly: 步骤 1 中的图像 2,3 01 | XY Frame Assembly, 01 | XY Frame Assembly: 步骤 1 中的图像 3,3
    • M8 x 40 screw for each corner. Insert T Nuts before M8 screws and do not tighten them now. Just to keep the frame in shape.
    • Blind L metal brackets for Z axis assembly should be inserted before M8 screws as well.
    • There are M8 holes for Z axis assembly on the 320mm aluminium extrusions which should be at the back of the XY Frame. Larger hole should be faced to bottom.
    • Insert two T-nuts for every corner in order to fasten the L brackets on the next step.
    • Do not forget to insert T Nuts for Y motor holder in back and LCD mount in front.
  2. 01 | XY Frame Assembly: 步骤 2 中的图像 1,3 01 | XY Frame Assembly: 步骤 2 中的图像 2,3 01 | XY Frame Assembly: 步骤 2 中的图像 3,3
    • One Metal L Brackets for each corner.
    • Two M6x12 socket cap screws for each metal L brackets.
    • Please align the extrusions on a flat surface like glass or marble and then tighten the M8 screws on the corners and the inside L brackets.
    • T-Nut insert for each bottom corner.
    • Printed Zaribo L brackets.
    • Misumi rubber foot for each corner.
    • M6x20 socket cap screw.
    • Misumi 3030 aluminium extrusion edge cover.
结论
4等其他人完成本指南。
Murathan Araz
于08/01/13注册
780 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 3,214
