跳转到主内容
简介
Read me: This guide is archived. Many laptops covered by this have failing feet and most 3rd party replacements are anti-slip and do not fail in ways that make the notebook hard to balance when it happens, which is common with many furniture feet without impossible to remove glue and coddling the laptop in your bag or on your person. This will still work, but keep extra feet handy when they fall off. Unless you have a completely intact set of OEM feet, it is recommended to remove the factory feet that remain and install a non-slip 3rd party replacement set using this guide:
If your Mac laptop is running hotter then you would like, this guide will show you how to install rubber feet to lift the laptop to allow for additional cooling of the system.
Read before starting: While this guide will help reduce the temperature your Mac runs at, early systems (2006-2012 MacBook/Pro) will always run hotter then Retina systems by design. Apple relies on the ports to provide fresh air for the chassis and reuses the hot air in the system. This is not an issue with the rMBP. These laptops have real cooling and will see reduced temperature drops.
13" MacBook Pro only (Optical drive/Retina): 13" models lack a dGPU. These systems will not see as much of a temperature reduction as there is less heat the system needs to disperse due to this omission. This does not apply to dGPU systems (15”/17” MacBook Pro).
In the original guide, the author used a Early 2009 17” MacBook Pro was used by the author. Before this fix, the system regularly ran up to 180° F without taller feet. The operating temperature was reduced to 122° after adding taller feet.
工具
没有特定工具。
配件
  1. Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Place your MacBook upside down on a clean flat surface.
    • Clean the laptop surface with rubbing alcohol or a similar cleaner.
    • Identify where you would like to place your new rubber feet. The new feet should be placed somewhere near the factory installed feet. Avoid placing the new feet on curved edges.
  2. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  3. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop.
    • Peel the paper backing off each foot. Once this is done, install them onto the laptop.
终点
11等其他人完成本指南。
Nick
于2009年11月10日注册
47,971 信誉积分
创作了38篇指南
团队
Master Techs Master Techs 的会员
Community
286 名成员
创作了808篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 58
过去的30天: 165
总计 23,719
