跳转到主内容
修复你的物品
维修的权力
商店
简介
If your back panel is cracked or you wish to change the color with one you found online here is the guide you are looking for! Be sure to turn off the camera and remove the battery before you begin the replacement.
  1. Locate the bottom panel of the camera.
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Pry open the back panel using the metal spudger. Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera.  Do not jam the tool in this part or the ribbon will rip.
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Open the two halves of the camera, taking care not to disturb the ribbon cable. Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the  next step
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  6. Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger. Push the ribbon out of its socket with the plastic opening tool. Push the ribbon out of its socket with the plastic opening tool.
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  7. Completely separate the back panel from the camera. Completely separate the back panel from the camera.
    • Completely separate the back panel from the camera.
  8. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  9. Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon. Using both thumbs push the ribbon out of the ZIF connection. Using both thumbs push the ribbon out of the ZIF connection.
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  10. Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  11. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
    • Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
  12. Separate the back panel from the LCD. Separate the back panel from the LCD.
    • Separate the back panel from the LCD.
结论
另外一个人完成了本指南。
Greg Baghdikian
于2015年01月22日注册
143 信誉积分
撰写一个指南
团队
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G13
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 7
总计 1,112
