简介
本指南是更换密封阀的捷径,省时省力的来维修马桶上的漏水以及烦人的噪音问题。
工具
没有特定工具。
配件
轻轻拉伸并将新密封件一直拉到溢流管的垂直组件上,并将其靠近底部浮动并将其定位到冲洗阀的顶部槽中。
一旦到位,您应该能够轻轻地抓住新密封件的边缘,并将其转到位于冲洗阀底部的槽中的适当位置。 通过冲洗,观察和收听来检密封垫圈。
it still leaks, very slowly....what do i need to do
i have repositioned it 3 times
这是冲水阀密封垫圈包装的反面。
There are other illustrations elsewhere on the web.. The problem will be the new gasket will leak slightly . I just replaced one twice, can't stop the leak. Can't buy OEM parts just the generic. I have three toilets, tried to replace the gasket in all of them. Flowmaster gasket worked nothing else does. That's one out of four, one toilet shut off, going to have to do something else with a flusher, can't shut off anymore toilets, don't to try anymore gaskets.
冲水阀密封件至少需要每隔几年更换一次,具体取决于水的状况。 其他种类的马桶水箱可能有类似的组件。 为什么叫水管工来更换这么容易做自己的事情呢?!
32等其他人完成本指南。
特别感谢这些译者︰
81%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
附加文件
10条评论
I followed the instructions on the package (turn off water, disassemble the flush valve).
It was so simple, I think this "shortcut" would have been more difficult.
You "think" it would have been more difficult? No disassembly (and reassembly) required on this one.
I just followed this instruction and it was fixed in less than 2 minutes.
apexmi -
Nina, A few ideas:
1. Sometimes there are mineral deposits (from 'hard' water) on the surfaces the gasket resides between (for instance, around the bottom of the float tube that sinks down onto the top of the seal). You can try carefully sanding them off with fine sandpaper.
2. If you have very cold water, especially, in winter months, a seal will be tested! Look for a new seal that is shiny on its surface. This indicates it may be silicone-based (not rubber) and they work better in areas with very cold water.
3. When installed normally, distortion of the seal is not a problem. You may just need to reinstall to make sure everything goes smoothly. But, first, gently pull the seal on opposite sides, with both hands. Do this moving around the seal to be sure it is properly seated in place. If nothing else woks, time to call a professional : )
Hey, is the flush valve seal comes with the complete toilet fill valve pack or purchased separately?
I can’t pull the flexible water tube out… help!
Never apply too much force. Perhaps it is originally molded-in. Try disconnecting the same water tube from the other end?
Is there a video available?
