简介
显卡在「锻炼」五到十年后有很大机率过劳死。但是,部分故障显卡有一定机率透过使用烤箱烘烤救活。
使用本教程时记得小心小心再小心——这些步骤可能导致你的显卡完全无法修复。对显卡持续加熱,能夠軟化焊錫,有幾率把虛焊的焊點修復。
注意:加热塑料、焊料和电子元件时会产生有毒气体。处理热腾腾的物体时别忘了穿戴保护用品并带上手套。记得通风,以免吸入有毒气体。
你所需要的
精密螺丝刀:飞利浦 #0 或 #1 一般就够了。
铝箔纸:用于覆盖热敏元件,并在烤盘上支撑你的显卡。
散热硅脂:显卡出炉后你需要重抹硅脂。
厨房用纸:用来清除旧的散热硅脂。(酒精湿巾也可以)
烤箱:不要使用烧烤架。
烤盘:不要把显卡穿在烤肉串上。
65等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
103条评论
I fixed my friends dead out-of-warranty Leadtek Geforce 8800 GTS 640MB card using this procedure
That was 3 weeks ago, and he's still using it daily since then
We forgot to plug in the fan connector and his temperatures reached 124C while playing a game
Since then he reconnected his fan and it's working fine
Thanks for reading, hope it helps someone
How long did your reflowed graphics card last? Is it still rocking?
The card did eventually fail, i believe around 4 months later - the guy ended up buying a new card
Hi everyone,
I also fixed a almost dead NVIDIA 512mb MXM II card, at the first point I put the card 8 min to 190ºC aprox, it improved the performance but not yet to run.
Then i repeated the operation with 205ºC and 10 min and the card ran perfectly, add some thermal paste and it's solved.
Thanks for this manual it's very usefull!!!
