简介
经过一定时间或一定次数的使用后,一次充电后,电池也用不了多久。本指南说明了如何更换联想 Yoga 3 Pro上的电池。
你所需要的
使用菲利普斯 00号螺丝刀卸下电池周围的六颗3.5毫米螺丝。
Hi
I have a Lenovo Yoga 3 pro - 1370
I take off the SSD without remove the battery. Is this a problem?
TKS
Stanley
小心地提起并取出电池。
If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
要重新组装设备,请按逆序进行操作。将你的电子垃圾带到R2或e-Stewards认证回收商。
26等其他人完成本指南。
由衷感谢以下译者:
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Very good and very easy to understand
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
does this same process work for a lonovo yoga pro 2?
Awesome and simple! Thank you!
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Having the same problem. Replaced the battery as instructed - process was simple. However, the laptop does not recognize the new battery; I booted up plugged into the wall outlet and laptop saying “no battery installed.” I reconnected the new battery exactly as instructed and as the old battery was connected before. PLEASE HELP!
UPDATE: I uninstalled and reinstalled the battery… and now it seems to be recognized and is now beginning to charge.
