跳转到主内容
索尼Xperia Z5电池更换
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. 索尼Xperia Z5电池更换, 电池: 步骤 1 中的图像 1,2 索尼Xperia Z5电池更换, 电池: 步骤 1 中的图像 2,2
    • 取下SIM卡托。
  2. 索尼Xperia Z5电池更换: 步骤 2 中的图像 1,2 索尼Xperia Z5电池更换: 步骤 2 中的图像 2,2
    • 加热后盖软化粘合剂。
    • 放置吸盘并插入金属开口工具,从上面打开一个间隙。
    Any recommendation on how hot and how long to heat it up?
    Benedikt M. - 回复
  3. 索尼Xperia Z5电池更换: 步骤 3 中的图像 1,3 索尼Xperia Z5电池更换: 步骤 3 中的图像 2,3 索尼Xperia Z5电池更换: 步骤 3 中的图像 3,3
    • 插入小拨片并将其滑动以去除下面的粘合剂。
    • 取下后壳。
    Does the adhesive in this step need to be replaced? Don't really want to lose the water proofing…
    Harald McArthur - 回复
    Usually the adhesive is slightly damaged during the opening procedure which might void the water resistance of the phone. So to re-seal the back cover it’s best to use fresh adhesive. If you don’t find a pre-cut adhesive tailored to the Z5 you can go with double-sided adhesive tape or an adhesive glue. If you find the remaining adhesive in good condition and trust it to do its job, the re-use it by heating it up a little bit and applying pressure to the re-attached back cover for a few hours.
    Tobias Isakeit -
  4. 索尼Xperia Z5电池更换: 步骤 4 中的图像 1,3 索尼Xperia Z5电池更换: 步骤 4 中的图像 2,3 索尼Xperia Z5电池更换: 步骤 4 中的图像 3,3
    • 松开电池连接器,然后拉下下面的胶带。
    • 撬开电池。
    Can you tell me the wire connection colour code of battery? because i brought the ones but its not working.
    denkim2701 - 回复
终点
25等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Lenka
于11/06/15注册
2,376 声望
创作了6篇指南
7条评论
I missed the part about the adhesive for the battery and broke the tabs off. Made it slightly harder but I got it. Thanks for the instructions. Now I can get all my things off of it
Braydon - 回复
can you put a link to where i could buy the battery from? it would be helpful, thank you
ido r - 回复
worked a treat - simple straightforward - thanks!!
John Turnbull - 回复
umm how do you put the cover back on?
Dulantha Fernando - 回复
Just push and then consolidate with heat, I used hair dryer.
Jorge García Laosa -
can reuse the same cover, or need a new unit ?
Chu Tat Liang -
Will this work for z5 premium ???
Q8Lucifer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 52,871
