跳转到主内容
移走没有钉头的六角螺栓
你所需要的
  1. 移走没有钉头的六角螺栓, 移走没有钉头的六角螺栓: 步骤 1 中的图像 1,1
    • 在螺丝头切出一个槽。
    • 将一把螺丝刀放在插槽中,用逆时针方向的锤子敲击,松开螺栓。
    • 使用工具将其拧下、
    How do you cut a slot in the stripped steel screw head which is half an inch inside the faucet handle and access hole is only 1/4 inch ?
    Singh - 回复
    Great Share and Useful post. Visit our website at - https://jksuperdrive.com/hex-allen-key
    Meena Singhaniya - 回复
终点
44等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Wolfgang
于02/17/12注册
597 声望
创作了2篇指南
6条评论
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - 回复
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - 回复
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - 回复
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Ive always had the best luck using torx bits if not rusted in.
jazzberry_tpt1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 113
过去 30 天: 461
总计 258,558
