简介
各位,
你是否怀疑自己的索尼手柄不是正品?希望这篇指南能解开你的疑惑
有些仿品制作精细,真假难辨,但是仍可以从中发现端倪
希望阅读完本文后,你也能鉴别索尼手柄的真伪
工具
配件
没有特定配件。
黑色的是正品索尼V2手柄,银色的是仿品。正面看上去都差不多。
第二张图是仿品手柄的背面。注意电池容量后面有“XF.LIN”这几个小小的字母,这些字母在正品上是没有的;同样,序列号前面的“DW”两字母也是正品上不会有的。其他地方均与正品无异。
现在将外壳拆下,看看仿品的其它部件!电池与正品相去甚远,原装电池容量为800毫安时,而仿品的电池仅有600毫安时。据说有的仿品也配有800毫安时的电池……
图2展示的是正品电池,和仿品的完全不同。
图3是LED/Micro USB的电路板,这个一看就是假的。我手上暂时没有正品的照片,不过正品的板子上肯定会有如JDM-011或JDM-030这样的字段,而图中的电路板上没有这样的字段。且板子上印的字应该是金色的而不是白色的。另外还可以看到,固定电路板的螺丝也是前文提到过的假螺丝。
事实上正品与仿品的区别还有很多,本文仅指出了最明显的几处不同
41等其他人完成本指南。
特别感谢这些译者︰
92%
Archie Kung正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
62条评论
The important questions:
1. Is the fake controller able to wake up the console from sleep?
2. Does the fake controller work in all games and apps? The buttons or sticks do not feeling identical are okay, e.g. unstable analog controls are not okay.
1. Sometimes no. It depends on the fake (there are many different fakes), but some of them are not able to wake up the console from sleep.
2. It should work in every app and game, but due the soldered on thumb sticks (they do not use the original ones) they do not respond every time or feeling identical. Some fakes uses a totally different input board which is causing that it’s unresponsive and/or not feeling identical to the original.
But how do you know if the casing is fake?
So far I have bought 1 fake controller and also found out that the plastic where the motherboard is on also is fake as you can't use original motherboard on that plastic as there seems to be some bad measures to the plastic part. Witch make the pad get stuck when closing.
Hi!
It can be very hard to see it from the outside. Did it came with the original battery or a fake on too? You need to modify the plastic part, otherwise it won’t fit I’m afraid..
1. Do original DUALSHOCK 4 (CUH - ZCT2) series controller's serial numbers start with a special number? For example the DUALSHOCK first version starts with 1 and second version starts with 2. One of the serial number starts with 3911 and the other with 1911. Will I be able to check anywhere whether the serial numbers belong to original series or not?
2. Without opening both my controllers, everything matches with the original ones as per your findings above. However the L3 and R3 buttons function on their own and doesn't let me control the player and camera angle fully. The controllers have never been dropped or any physical damage caused.
