跳转到主内容
核心组件拆卸
你所需要的
  1. 核心组件拆卸, 打开手机: 步骤 1 中的图像 1,1
    • 卸下手表背面的四颗Y型#00螺丝(长度为4.2 mm)。
    I can't get them to budge
    Irene - 回复
    Same here, its impossible to get the screws off. They’re almost stripped now too.
    Prabhat - 回复
    Sorry to hear that. Here are some tips on how to get those screws off hopefully: 如何卸下滑丝的螺丝
    Tobias Isakeit -
    Just started working on watch. Can not get the screws out. I purchased the recommended tools. Screws won't budge. I have not stripped them yet. How do I get them to loosen up?
    joyce c - 回复
    Same here. I did buy your Electronics repair Bundle. The Y000 is too pointy, we need a flatter tool
    Robertob67 - 回复
    Hi Ladies & Gentleman, please try as follows:
    Use a spray can of "WD 40" with a spray pipe/tube but DO NOT spray into the screw holes. Just spray shortly on a piece of paper, a drop of WD40 will remain at the end of the spray pipe. This drop I put into the screw hole position. Do this for each screw hole and leave the stuff approx. 10 minutes alone. Afterwards use the screw driver as normal to turn the screws out.
    *** After the drop is placed into the hole do not wait too long as WD40 is crawling into "even not existing gaps"
    *** just use a small drop of WD40.
    *** I intend for using 4 new screws as the head (Tri-Pont profile) seems worn out. But if I get new screws for sure I will go for a TORX profile because its the best as you don't need to apply axial force on screw driver.
    Very best regards from Harald (a German machine building engineer)
    Harald - 回复
    Harald again to Robertob67:
    It is NOT the Tool Y000 but the Y00
    Best regards
    Harald
    Harald - 回复
  2. 核心组件拆卸: 步骤 2 中的图像 1,2 核心组件拆卸: 步骤 2 中的图像 2,2
    • 使用撬开工具进入手表的后盖和金属外壳之间。
    • 小心撬开塑料后盖。
    • 请勿卸下后盖。内部有一条的柔性电缆。
    You may need to use a small screwdriver or letter opener to pry the case apart. I found with two different spudgers I could not get it to budge.
    Tim Durstenfeld - 回复
    How do I Secure the sealing, and wish material du you use?
    Ejner Bøndergaard - 回复
    I managed to get the back cover to open with an unused pry tool on one side, however, to fully remove it I needed to use 2 iFixit opening picks from my toolkit as the one side wouldn't open with the pry tool.
    Austin Newman - 回复
    I couldn't get the back cover off with any normal tools. However, I discovered I could slip a razor blade a short distance under the back cover. With this in place, something thicker (like a plastic spudger) could easily be pushed between the razor blade and the metal of the watch. Obviously, working with a razor blade like this is quite risky, I had mine in a little holder to protect my fingers!
    David - 回复
  3. 核心组件拆卸: 步骤 3 中的图像 1,2 核心组件拆卸: 步骤 3 中的图像 2,2
    • 放下手表,然后提起后盖,以接触到主板上的传感器连接器。
  4. 核心组件拆卸: 步骤 4 中的图像 1,2 核心组件拆卸: 步骤 4 中的图像 2,2
    • 使用撬棒从主板上断开传感器柔性电缆的接口。
    My 2019 Gear Sport has no flex cable it used a post where the flex cable is. This plugs into the mother board.
    Much better for disassembly.
    William Barron - 回复
  5. 核心组件拆卸: 步骤 5 中的图像 1,3 核心组件拆卸: 步骤 5 中的图像 2,3 核心组件拆卸: 步骤 5 中的图像 3,3
    • 卸下后盖。
    • 关闭手表时,请确保橡胶垫圈未损坏,或更换新的橡胶垫圈。
    Has anyone seen a listing for the gasket?
    DaChew - 回复
    anyone where can find the rubber gasket?
    Melvyn Chang - 回复
    is the gasket the Adhesive? If not, what adhesive suggested and how do you apply it?
    batato kr - 回复
    No, the gasket is not the adhesive. As adhesive you can use this under the battery.
    Tobias Isakeit -
    woher bekomme ich eine neue gummidichtung?
    Anja Müller-Dreßler - 回复
    Hat jemand eine Quelle für die Dichtung der Rückabdeckung (rote Dichtung, 3. Bild Schritt 5). Hat jemand versucht die erfolgreich selber herzustellen?
    Helge Korz - 回复
    Falls jemand die Gummidichtung im Netz findet, gerne hier posten. Wir konnten bisher noch keine finden. Selbst rounded.com hat es nicht, und die haben recht viel für (Samsung) Smartwatches.
    Tobias Isakeit -
    Same question : has anybody found a solution for the rubber gasket ? I am not confident at all in the waterproofing of the watch now ...
    Bruno F - 回复
    If the waterproof seal is removed and you only encounter water while washing your hands, would there be any issue?
    Owen - 回复
    Anyone know where to get a replacement gasket? I wear my watch showering and swimming, I don't want to loose the waterproofing
    Mick Brady - 回复
    When I opened the back cover, the gasket was already muddy.
    I purchased a liquid gasket because it is difficult to obtain a dedicated gasket.
    It is for general-purpose waterproof packing used for cars and motorcycles, and is contained in a 5g tube.
    Since it is necessary to apply it to a fine place, I attached a very thin nozzle for super glue to the tip of the tube and applied it.
    I can't guarantee the waterproof performance, but I tried what I could.
    ジャッジアダックス - 回复
  6. 核心组件拆卸, 核心组件移除: 步骤 6 中的图像 1,2 核心组件拆卸, 核心组件移除: 步骤 6 中的图像 2,2
    • 使用撬棒从主板上断开显示屏柔性电缆的接口。
    My display flex cable is cut … is it possible to replace only cable without changing display… if yes please leave a link to buy it
    Akshat Dev - 回复
  7. 核心组件拆卸: 步骤 7 中的图像 1,2 核心组件拆卸: 步骤 7 中的图像 2,2
    • 将核心单元从机箱中提出。
    • 磁芯的塑料框架紧紧地固定在外壳内。
    • 小心地将显示屏弯曲电缆穿过芯塑料框的间隙。
    Es sind an den Ecken des Kernstücks ein paar "Plastikdreiecke" mit dem man es mit einem Spudger leichter raushebeln kann!
    Marco Marinkovic - 回复
    Thanks @Marco Marinkovic. There are a couple holes or points, on which to leverage in order to free and lift the core unit. The core unit won't move otherwise as it is anchored there
    Robertob67 - 回复
结论
要重新组装设备,请按照逆序进行操作。
5等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,588 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
3条评论
thanks, loved seeing this watch from the inside!
Crystal Blu - 回复
Great, but now I need to know how to get to the glass to replace it.
selwood.maria - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 51
总计 2,918
