简介
用这条指南来安全地用iFixit更换电池工具从你那MacBook Pro上拆除满是胶的电池。你的iFixit工具中的除胶剂可以溶化固定电池的胶,让你轻而易举地拆除电池。
“iFixit除胶剂非常易燃。”请在通风良好的地区做这件工作。在此过程中不要吸烟或是靠近明火。
注意:用来溶解胶的溶剂会损伤某些塑料。遵照所有这些指导并在涂溶剂的时候多加小心。
用力将底壳向MacBook的前端方向(与合叶相反的方向)拉,以此来分离最后的固定底壳的卡扣。
Difficult to explain clearly, but worked easily for me by gripping the adjacent bottom and top corners then pulling in opposite directions, rather than trying to grip the hinge corner which is too narrow to afford a strong grip.
小心地剥开这一大片盖住电池接头的胶带,它在主板最靠近电池的边缘。
拿走这胶带。
once the tape's back in place, it doesn't look tightly attached. not sure, did I do something wrong here or it should be so.
The tape will likely not adhere as well as when it came out of the factory. This isnt an issue! As long as the tape is in place when the lower cover is put back on the device you should be good to go.
The underside of the tape is not uniform. Therefore, pay attention to which direction it is placed by looking at the underside when you remove it. Possibly mark one edge so that you can replace in the same direction during reassembly.
Rick Jaffe - 回复
把电池数据排线滑出它的插槽来断开连接。
滑的时候要在排线方向平行于主板滑动。
The little tab that you pull back on, at least in my cable, was simple glued onto the rest of the cable. I tried to carefully remove the cable, and the tab came off. I did not have flat tweezers in the ifixit replacement kit and did not want to pinch the cable with sharp instruments. Therefore, be extremely careful when removing the tab as it is difficult to reattach the cable without it.
Rick Jaffe - 回复
把电池数据排线弯到后面去让它不要挡路。
The new battery I received did not come with the battery board data cable, so I had to remove the existing one and transfer it. The lock at the smaller end is the same mechanism as the one at the end shown in steps 11 and 12, but smaller (and harder to see. It helps to gently straighten the left end of the cable before trying to insert it in the end of the replacement circuit board.
So you have to take the small black square off that connects the ribbon to the base? I did that so as to remove the whole ribbon and replace it with the one attached to the new battery. I tried taping it down (okay and pritt sticking) now my laptop is fudged. when I turned it on again There was an X through the battery, and now it won’t load/ switch on at all and sounds like it’s about to take off. Can anyone help please?!
Likewise - the new battery came without a data cable. The cable was successfully removed from the old battery assembly and installed on the new battery, but it was tricky and nerve-racking (the cable is delicate and the connectors are very small) without instruction provided! The instructions should be updated to highlight the missing cable possibility, and provide information/illustration on transferring the cable.
In step 13, notice the amount of the data cable that sticks out of the connector. When moving this cable to the new battery, it is difficult to tell how far to push the cable into the connector or when it is fully inserted because the cable is so bendable.
Rick Jaffe - 回复
用一把T6内梅花头改锥拆掉这个固定电池接头的3.7mm“薄煎饼”螺丝。
When the battery management “BMS” circuit board is re-installed, loosely install the two 3.7 mm screws, put a spudger on the left side of the BMS board to wedge theBMS board to the right then tighten the two 3.7 mm screws. The reason for doing this is that the two power traces on the board may not make physical contact with the battery connector (connector at where the spudger is on step 15). One clue that you didn’t have physical contact is if you reinstalled everything but there is no power unless the AC supply is plugged in (with battery meter on the top at 0%). This was what happened to me. The reason is that when you bend the battery connector in step 15, it’s no longer in alignment with the traces on the BMS board and hence, you have to shift the BMS board to the right to compensate. Once I did this, voila 64% power.
用撬棒轻轻地抬起电池接头,断开电池。
将接头抬起足够高使得它从插槽中分离。如果在修理过程中它意外碰到插槽,你的MacBook Pro有可能会受损。
Hi , i t the screw , I lifted the connector up and it breaks this sort of black tape. Is it a tape or is it a conductive layer? My Mac won’t start up now. Can someone help? Can I buy it?
准备一个iOpener,把它放在触摸板排线上。
如果你没有iOpener,可以用一台吹风机来加热排线。排线应该是热的,但不能热到没法碰。
加热排线大约1分钟,让把触摸板排线固定在电池上的胶软下来。
there's nothing in this manual about how to secure the cable while reassembling. I used insulating tape.
拆除触摸板组件。
确保别丢了这六个还待在触摸板下面的垫圈(两个圆形的和四个矩形的)。
把撬棒的平头插到电池板下最靠近主板的一头。
抬起电池板大约45度。如果有必要,抬起电池插头来给电池板更多的空间。
A ce moment là, il faudrait déconnecter la nappe de données de la carte de la batterie et la mettre de côté
At this point I Jump to step 30 . I do not use the liquid adhesive remover method. I use a silicone rubber kitchen food scooper. The scoop end is a soft, silicone rubber material with a beveled edge. The handle is a hard plastic. This tool I’ve used in about 50 retina battery swaps. No floss, credit cards or metal spatulas for me.. The angle of the ends and the rubber pliability combined with the hard plastic handle is ideal. After a few repairs you will get better at it. Be careful when applying pressure or leveraging to get between battery and base. You don’t want to slip & “overshoot” the scoop end into the logic board. EASY DOES IT…Save yourself the mess of applying the liquid. I can remove a battery in 10 minutes. Here’s the link to this tool that I found in my GF’s kitchen:
现在你的MacBook Pro已经完全准备好了。下面该准备你自己了。
在涂除胶剂的时候戴一个护目镜。(护目镜包含在你的工具包里。)
没戴护目镜就不要戴隐形眼镜。
防水手套也包含在你的工具包里。如果你担心除胶剂可能刺激你的皮肤,马上戴好手套。
Wenn das Trackpad ausgebaut ist, kann man den alten Akku auch ohne Klebstoffentferner relativ gut auslösen.
打开你的除胶剂瓶盖。
向你工具包里的注射器里灌少量(大约2毫升)的除胶剂。
在剩余的过程中,如果需要就重新在注射器里充好除胶剂。
Au moment de ma commande le kit complet avec le dissolvant ifixit n’était pas disponible, mais seulement la batterie sans accéssoires, j’ai utilisé quelques gouttes d’acétone à la place. la battéerie originale s’est décollée sans difficulté à l’aide d’une carte de credit
Can I use isopropyl or ethanol instead?
举起并拿走电池。
如果你有些小幸运,你没准儿能用你的手指将那些胶慢慢撕掉。
不然,你就得用除胶剂浸泡每一块胶2、3分钟,然后再用塑料工具将他们刮掉。这会占用你相当长的一段工服,耐心点儿。
擦掉任何残留的除胶剂,再给你的MacBook Pro一点时间晾干它。
在你使用的电池之前先检测它:先给放一夜的电,再把它充到100%,然后再放电直到你的MacBook Pro自动关机。再充满电就可以正常使用。
Hi Jeff,
Thank you for the great instructions! With a piece of dental floss it goes even better. Also it’s good to explain to shift the back cover out after removing the bolts. At the moment to put in the new batteries it’s the best to tighten the batteryprint first and at last to fix the batteries. Put three pieces of plastic under the batteries to prevent fixing too early to the bottom.
Frans.
要重新组装你的设备,请按逆序操作。
要重新组装你的设备,请按逆序操作。
36等其他人完成本指南。
特别感谢这些译者︰
95%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
16条评论
Does the replacement battery comes with the same strong adhesive as the original battery?
I ordered my battery for the 2017 version of the Macbook Pro with function keys from ebay and it didn’t came with a adhesive strip. I am sure you can use your own adhesive strips or double sided tape, as long as you mind the gabs on the aluminum frame,
Serj Nko -
Hi Jeff,
Thank you for this great work to beat Apple greediness. I followed the exact steps and everything went well, but my battery is not charging nor the status is shown on the bar! I tried restarting and resetting and even restoring and it did not work would that be something you can help me with?
If the old battery still works, try putting it back in, and see if that clears up the problem. If it does, the new battery is defective.
i did this one today with just 1 bankcard in 30min time no adhesive loosener needed no head needed…. you don’t even have to remove the mousepad…
i might have to start making my own repair guide….
Glad yours was easy! The strength of the adhesive can vary a lot depending on age, heat cycles, how much was applied at the factory, etc. I’ve seen a few that were easy and quite a few that were absolute monsters to remove. Most fall somewhere in between. This guide should have you covered in all cases, but it probably doesn’t hurt to poke and pry a little before you start, in case you lucked out and got an easy one. Just be very careful not to puncture the battery. Thanks for your comment!
Thank you! This excellent guide gave me a lot of confidence in the replacement of the battery. All went precisely according to plan.
I just completed the swap… awesome guide and really easy.
The only Problem i had was the missing data cable from the battery board to the logic board which was not included with the new battery. Thanks to some comments from other users I used the cable from the old battery.
Everything Else worked as described.
Vielen Dank für die gute Anleitung. Der Akkutausch hat ohne Probleme sehr einfach in ca. einer Stunde geklappt.
Aaron Dalziel - 回复
