跳转到主内容
更换iPhone8的分集式Wi-Fi天线
你所需要的
  1. 更换iPhone8的分集式Wi-Fi天线, 卸下五角螺丝: 步骤 1 中的图像 1,1
    • 在你开始之前,请将你的iPhone电池放电至25%以下。 充满电的锂离子电池如果被意外刺破,可能会发生着火和(或)爆炸。
    • 在开始拆卸之前关闭您的iPhone。
    • 卸下iPhone底部的两个3.5毫米五角螺丝。
    • 打开 iPhone 的显示屏会损害其防水密封。在继续执行此步骤之前,请准备好更换密封件,或者如果您在不更换密封件的情况下重新组装 iPhone,请注意避免接触液体。
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - 回复
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - 回复
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - 回复
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - 回复
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - 回复
  2. 更换iPhone8的分集式Wi-Fi天线, 反向钳使用指南: 步骤 2 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线, 反向钳使用指南: 步骤 2 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线, 反向钳使用指南: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • 接下来的三个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 将蓝色手柄拉向铰链以解锁反向钳。
    • 将手机塞进反向钳的两臂之间。
    • 将吸盘放在屏幕上主页按钮的正上方——一个在前面,一个在后面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  3. 更换iPhone8的分集式Wi-Fi天线: 步骤 3 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 3 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 3 中的图像 3,3
    • 将蓝色手柄推离铰链以进入打开模式。
    • 顺时针转动手柄,直到你看到吸盘开始伸展。
    • 确保吸盘彼此保持对齐。 如果它们开始滑出不对齐,请稍微松开吸盘并重新对齐手臂。
  4. 更换iPhone8的分集式Wi-Fi天线: 步骤 4 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 4 中的图像 2,2
    • 加热 iOpener并将其穿过反向钳。
    • 你还可以使用吹风机热风枪或电热板,但过热可能会损坏显示屏和/或内部电池,因此请小心操作。
    • 折叠 iOpener,使其位于 iPhone 的底部边缘。
    • 等待一分钟,让粘合剂有机会释放并出现开口间隙。
    • 将撬片插入间隙中。
    • 如果反向钳无法形成足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 一次不要转动超过四分之一圈,并在转动之间等待一分钟。 把工作交给反向钳和时间来完成。
    • 跳过接下来的三个步骤。
    it looks like a....
    Gergely Soki - 回复
  5. 更换iPhone8的分集式Wi-Fi天线, 加热显示屏: 步骤 5 中的图像 1,1
    • 接下来的三个步骤展示了如何使用吸盘分离屏幕。
    • 加热iPhone的下缘将有助于软化固定显示屏的粘合剂,使其更容易打开。
    • 使用吹风机或准备一个iOpener,并将其放到手机的下缘约90秒,以软化显示屏下面的粘合剂。
    No hair dryer so GENTLY heated over stove burner
    John Toth - 回复
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - 回复
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - 回复
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - 回复
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - 回复
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - 回复
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - 回复
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - 回复
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - 回复
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - 回复
    Hairdryer works fine for this step. No issues.
    tripmusic - 回复
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - 回复
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - 回复
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    John Noble - 回复
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    John Noble - 回复
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    John Noble - 回复
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - 回复
  6. 更换iPhone8的分集式Wi-Fi天线, 分离屏幕: 步骤 6 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线, 分离屏幕: 步骤 6 中的图像 2,2
    • 将吸盘放在前面板的下半部分,刚好放在home按键的上方。
    • 确保吸盘不会与home按键重叠,因为这将导致吸盘和前面板玻璃之间不能形成密封。
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - 回复
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - 回复
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - 回复
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - 回复
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - 回复
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - 回复
  7. 更换iPhone8的分集式Wi-Fi天线: 步骤 7 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 7 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 7 中的图像 3,3
    • 用力、恒定的压力向上拉吸盘,在屏幕和框架之间形成微小的间隙。
    • 将撬片插入间隙中。
    • 将屏幕固定到位的防水粘合剂非常牢固; 创造这个初始间隙需要很大的力量。 如果你很难打开间隙,请施加更多热量,然后轻轻地上下摇动屏幕以削弱粘合剂,直到形成足够的间隙以插入工具。
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - 回复
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - 回复
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - 回复
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - 回复
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Johnny Emrica - 回复
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - 回复
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - 回复
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - 回复
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - 回复
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - 回复
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - 回复
    Suction cup pliers. Dead easy
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    dantegd - 回复
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - 回复
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - 回复
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - 回复
  8. 更换iPhone8的分集式Wi-Fi天线: 步骤 8 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 8 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 8 中的图像 3,3
    • 用拨片划动开口,从手机的下边缘开始一直到手机的左边缘,然后向音量控制按钮和静音开关划动,划开固定显示屏的粘合剂。
    • 停在显示屏左上角附近。
    • 不要试图将显示屏的顶部边缘从后壳上撬开,因为它可能会破坏显示屏上缘内用来固定显示屏和后壳的塑料插槽。
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - 回复
  9. 更换iPhone8的分集式Wi-Fi天线, 注意事项: 步骤 9 中的图像 1,1
    • iPhone 的右边缘有易损排线。 请勿将撬片尖端插入此处,因为可能会损坏排线。
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - 回复
  10. 更换iPhone8的分集式Wi-Fi天线: 步骤 10 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 10 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 10 中的图像 3,3
    • 将您的工具重新插入到iPhone的右下角,并将其划到手机右上角,以划开粘合剂。
    • 请勿将撬片尖端插入超过 3 毫米,否则可能会损坏显示屏排线。
    No pick in the kit you sent me.
    Ted Cooper - 回复
  11. 更换iPhone8的分集式Wi-Fi天线: 步骤 11 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 11 中的图像 2,2
    • 轻轻拉起吸盘,抬起显示屏底部边缘。
    • 请勿将显示屏抬高超过15º,否则会导致显示屏右侧的排线变形或撕裂。
    • 拉起吸盘上的小凸起,将吸盘从前面板上取下。
  12. 更换iPhone8的分集式Wi-Fi天线: 步骤 12 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 12 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 12 中的图像 3,3
    • 从显示屏左上角下的开口部分开始,将工具沿手机的顶部边缘划动,划开最后一处粘合剂。
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - 回复
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    Adam Yavner - 回复
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - 回复
  13. 更换iPhone8的分集式Wi-Fi天线: 步骤 13 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 13 中的图像 2,2
    • 稍微向下滑动显示屏部件(远离手机的顶部边缘),将显示屏下的塑料插槽与后壳脱离。
  14. 更换iPhone8的分集式Wi-Fi天线: 步骤 14 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 14 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 14 中的图像 3,3
    • 像翻书一样将显示屏轻轻的从手机的左侧翻开。
    • 先不要试图将显示屏与手机完全分离,因为显示屏脆弱的排线仍连接在手机的主板上。
    • 用其他物品支撑显示屏以保持其倾斜,以便您进行下一步的维修。
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - 回复
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - 回复
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - 回复
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Jim Glenys - 回复
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - 回复
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
    Raziocinjo - 回复
  15. 更换iPhone8的分集式Wi-Fi天线, 断连电池: 步骤 15 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线, 断连电池: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • 卸下将显示屏电路支架固定在电路板上如下的四个十字螺丝:
    • 两个1.3毫米的螺丝
    • 两个2.8毫米的螺丝
    • 在本指南中,请仔细关注您的螺丝,以便在重新组装时,每个螺丝都能回到原来的位置。在错误的地方安装螺丝可能会造成永久性损坏。
    • 卸下支架。
    Not Y000 this time haha
    Easy Repair - 回复
    can same length screws mixed up?
    Brook布魯克 - 回复
    It is not ideal, but possible for these screws.
    Arthur Shi -
    using the repair kit i purchased with my screen replacement, i am currently having issues removing these screws with the PH000. please help
    Mark Ordaz - 回复
    I was too, thankfully I had another set that contained the PH00 bit, that worked great for me.
    William Mitchell -
    Ok. My screw is stuck. How do I remove it? Philips head is stripped.
    Kristina Graham - 回复
    Solved it myself. Firm pressure did the trick.
    Kristina Graham -
    Takes a little pressure with the Philips head
    John Toth - 回复
    Upon this step, I noticed I had no bracket or screws. I had my screen replaced previously and I’m disappointed to find out the repairperson made no effort to replace these parts. I’ll start trusting myself more to do my own repairs.
    O D - 回复
    took me awhile to figure out I needed to use PHOO bit for the 2 -1.3 screws
    Karen Flowers - 回复
    It is important to keep careful track of the screws' position. Have a tidy workplace -- a few times when I tried to re-attach the very tiny screws with the tweezer, they slipped and flew away and I almost lost them.
    Matti Haveri - 回复
    can you strip the screws / how can you tell if its strip or not
    antonio - 回复
  16. 更换iPhone8的分集式Wi-Fi天线: 步骤 16 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 16 中的图像 2,2
    • 使用撬棒的尖端将电池连接线口从主板上的插槽中撬出。
    • 将电池连接线稍稍向外弯曲以远离主板,以防止其在维修过程中意外接触插槽使手机通电。
    Make sure you pry the battery connector off from the right hand side as shown in the picture. Theres a delicate component on the logicboard near the battery connector called a Mosfet which is linked to the battery charging software. If you knock it off accidently you’ll loose battery charging and the phone will boot loop and youll need to have it re-soldered back on.
    Gareth - 回复
    I can confirm this as I learned my lesson by unknowingly prying the mosfet off. The phone will not charge now and is useless. I really wish they would add a note about this on Step 12 as a warning.
    Jeff -
    So this is it. You don’t have to go any further removing the screen. You can replace the battery right from this point.
    John M - 回复
    I wish I saw this comment 2 hours ago
    Kenneth Moore -
    If I have to repeat this, I'd also consider removing replacing the battery at this point. The loose display must be then carefully fixed so the connectors don't break. And then it is not possible to re-attach the waterproof seal.
    The waterproof seal was included in the kit, but there were no instructions for it so I now skipped that. I later found YouTube video which seems to describe it (starting at 7:40):
    https://www.youtube.com/watch?v=RcgGRhaX...
    Matti Haveri -
    This is where I broke my phone, a phone that was working quite well, paid for in full. Just because I had a cracked screen. Be super careful when connecting the cables. I was in a hurry and not paying attention, used too much force when re-connecting and broke those teeny little pins that could not be repaired. A tech tried for an hour to no avail. cautionary tale. Good luck
    Karen Flowers - 回复
    The display ribbon is a certain length and allows for some give, but behind it is hidden the Home button/TouchID ribbon, which sits against what amounts to a razor blade. This ribbon is much more taut than the display one, and therefore you have far less freedom of movement than you think you do. This is absolutely an intentional trap to discourage replacing your own battery. Quite frankly, it’s despicable.
    Anyway, so beware of that, because although I was very careful and did not even swing the screen very far (not more than 90°), the Home button ribbon tore and now needs to be serviced. Home button is disabled now.
    Apple should be ashamed of themselves for this. Please do look at the legislation effort that people are doing to try to get this kind of sabotage illegal, as well as all sorts of other gimmicks they pull. For a company that makes phenomenal products, they’re controlling like an abusive spouse.
    Dan Knight
    daniel - 回复
    That happened to me and I could not figure out how it got broken. It's the home button and fingerprint reader.
    But I'm not bothering to get it fixed and I'm not replacing the entire screen. I went into system prefs/accessibility and activated the on-screen home button. Oh, well.
    Mangled Jargon -
    I cannot get the new battery reconnected to the connection port. Any tips/tricks? New and old battery connections appear similar. It wasn't difficult to disconnect to old battery.
    Robert Ast - 回复
    Some reports here seem to indicate that the battery must be the very last connector to re-connect because otherwise there might be malfunction in some display components?
    It wasn't difficult to disconnect to old battery. But the most difficult part for me was to get the new battery reconnected to the connection port. I tried many times to carefully position and press it down with my fingertip or the flat end of the spudger but it did not hold its position. Maybe I pressed too weak because I was afraid breaking the connector and the mosfet above (?) it. But finally to my surprise it connected (at that point I temporarily booted the iPhone with the loose display to verify that the battery was connected). Whew, it succeeded!
    Matti Haveri - 回复
    The connectors have very little "click" to them when they do seat properly, and are covered with soft foam. Very challenging to attach them by feel, and having the screen propped up, blocks light from exactly where you need it.
    Steve Trotman - 回复
    Make sure the new battery connector cable has similar length and width to the one of the original battery. I got a third party battery and the cable was longer and not folded in a "U" way near the connector, like the one in the genuine battery was, only folded at a 90 degree angle. That "U" actually perfectly fits in the small space between battery and connector port, so the cable doesn't stick up thus making connecting it or closing the screen impossible. So fold the cable, connect it, and while holding it to prevent it from disconnecting, stick the battery so the "U" curve of the cable sits down just between battery and connector port.
    Raziocinjo - 回复
  17. 更换iPhone8的分集式Wi-Fi天线, 断开显示排线: 步骤 17 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线, 断开显示排线: 步骤 17 中的图像 2,2
    • 使用撬棒的尖端轻轻将屏幕下部的第一个排线插头撬起。
    • 想要重新连接这种按压型插头,先将插头的一侧对准位置轻轻按压到位,然后在另一侧重复操作。切忌从中间按压插头。如果插头没有对准位置就对其进行按压的话,很可能会对插头插座造成永久性的损坏。
    I broke the lower display connector. Is it possible to replace that part separately or do I need to buy a full screen replacement?
    Ross Mckellar - 回复
    You need to buy a new screen
    conrad veldhouse -
    이렇게 친절하게 정성스럽게 분해도 올리신 분은 처음이네요 진정 프로/ 기타 나머지 잡것들은 대충 올려 돈이나 벌어보자는 업자num들/ 배터리 교체하는 유툽 영상보다...업자가 올린 ...배터리 교체는 따라했으나 그후 배터리 교체와는 전혀 상관 없는 액정 뒤판을 jo빤다고 설명도 없이 뜯어 그것까지 따라하다 액정이 나가버려 지금 무주공산에서 홀로 검색하다 이걸 보게됨
    평생놀아난다 - 回复
  18. 更换iPhone8的分集式Wi-Fi天线: 步骤 18 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 18 中的图像 2,2
    • 使用撬棒的尖端将屏幕下方的第二个排线插座撬开。
  19. 更换iPhone8的分集式Wi-Fi天线: 步骤 19 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 19 中的图像 2,2
    • 将手机上部,保护前面板传感器组排线的支架上的三个1.3mm的十字螺丝移除。
    • 移除支架。
    If you are replacing the adhesive liner, the remaining release liner strips will interfere with the two outer screws. I had to cut a working section out of the liner at each location and move it aside with the spudger.
    Thomas Tritt - 回复
    This part is throwing me for a loop. Having difficulty finding the read head for these screws. Is it the same size as the two small 1.3mm screws in step 12?
    Jared Hensley - 回复
    These are the same size screws mentioned in Step 17.
    Douglas Walker -
    ended up getting it with the PH000, I must of just been rushing it.
    Jared Hensley - 回复
    My bracket looks different and none of the screw heads I have fits.
    Ray Rushing - 回复
    Mine too? Any help?
    George Waller -
    These screws did not stick to the magnetic screwdriver. Extremely difficult to get them back in place - but with some patience i succeeded :)
    Niklas Brammer - 回复
  20. 更换iPhone8的分集式Wi-Fi天线: 步骤 20 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 20 中的图像 2,2
    • 使用撬棒的尖端将前面板传感器组的排线插头撬开。
    Do you have a link for the flex cord shown in the pictures so I can purchase it? Having a hard time locating that exact assembly
    Regal Carveiro - 回复
    It’s of a piece with the front camera.
    xint - 回复
  21. 更换iPhone8的分集式Wi-Fi天线, 拆下屏幕总成: 步骤 21 中的图像 1,1
    Hi ifixit, if you find my method dangerous, please remove it.
    After Step 17, I skipped Step 18 to Step 28.
    At Step 29, I lifted up the four adhesive black pull-tabs to expose the white adhesive side. Next, I use hot air gun and blow on the back cover of the iphone for about a minute (maybe a hairdryer will work too) .
    Warning: Don't overheat the iPhone, or you may accidentally ignite the battery.
    I think the temperature was around 60 DegC.
    Extreme Caution: Do Not overheat. I use my hand to gauge the hotness. Careful not to burn yourself or the board.
    I was able to pull out all the white adhesive tapes easily as the adhesive soften.
    DO NOT TRY this method if you are a novice or inexperience! I am not responsible if you hurt yourself or damage your iphone!
    John - 回复
    Hey John! I’m glad the repair worked out for you!
    From our research, applying heat does soften the adhesive strips, but it also causes them to lose structural integrity and break more easily. That’s why we normally suggest using heat after the strips are already broken. Removing the Taptic Engine definitely takes a few extra steps, but we feel that it gives fixers the best chance of pulling out the adhesive strips intact.
    Arthur Shi -
    I agree with John, skip 18 through 27. These are to make it easier to remove the battery adhesive. I replaced the batteries on two IPhone 8s. The first one I did all that stuff and the adhesive still broken and I had to carefully pry the battery out anyway. When I reassembled the phone the Home button no longer worked. Looking it up, this is apparently fairly common due to all the fragile wires involved in these steps. The second I skipped these steps and when I reassembled it everything worked fine. Not one of the eight (both phones) adhesive strips came out properly. I fully drained the batteries before doing the repairs. By the way, I use the virtual home button on the one phone, it’s a little annoying, but the phone is still usable if you’re not ready to shell out for a new phone.
    Gary Berman -
    I also skipped removing the Taptic Engine. I could only half-way pull the lower battery tapes and completely the upper tapes after carefully prying them loose with the tweezer. I then used a hair-dryer for a minute to warm the battery and the other side of the phone (I used my other hand to make sure I did not apply too much heat. Make sure you do not blow the tiny loose screws away with the hair dryer!) and then slowly lifted the upper battery somewhat with the Opening pics tool, then re-heated the lower remaining tapes and quite easily lifted the battery out.
    I had bought two-sided tape to reconnect the battery but it had the tapes pre-installed (I wonder if it is necessary to tape the battery at all?).
    Matti Haveri -
    I also skipped these steps. I won’t say it was entirely successful - two of the four adhesive strips broke and could not be grabbed with tweezers. But I had gotten most of the adhesive out already and the battery was quite loose, so I used a warmer under the phone, then gently slid a flat plastic blade under one end of the battery and slowly worked it up the phone. (Dental floss would have been safer-don’t do what I did, kids!)
    Matt D - 回复
    Likely can skip step 18-28 and all the risks. Battery tape is relatively removable by the following method
    - use a tweezer to pull up a corner of each tape. Then use fingers to peel back all the black tab on top of battery
    - use 2 hands. Index and thumb on both. Pull about 1/4” with one hand, hold the tension and pull 1/4” with the other hand. Alternate, go slow. Pull out all 4 tape completely. I think the pause after each 1/4” while holding the stretched tape firmly prevents the tape from over stretching to become too thin and break.
    - Don’t apply heat, I would guess that makes tape softer and break easier.
    Have tried other methods and failed in the past. Pulling too fast (tape will snap) or use a tweezer to twist/roll (sharp edges will cut tape) Anyway, just use index/thumb on both hands and alternately pull slowly
    I did do 2 iPhone 8 battery change this way. One removed all tape without breaking. Another broken all 4 tape after about 1/3 pulled so likely some factory assembly differeces.
    Howard - 回复
    I second this, this method works well in most cases. Removing the haptics helps to keep the angle low and pulling the tape as straight as possible
    Hein Blöd -
    Howards method for removing the adhesive works like a charm. The only addition I made was to slightly warm the back of the iphone on a rice pack (used for sore neck muscles—haha). Going back and forth between hands is really crucial. While on hand gives a gentle pull, the other holds the phone from moving. Slow back and forth. Thanks.
    Lynn Thomas - 回复
    Struggling with the glued down display, then properly cleaning all the remains of the old seal, then positioning the new seal is 95% of this job. I purchased my phone refurbished and it clearly had already been serviced once, there were remnants of an old seal below the current seal due to improper cleaning and prep that made getting the phone open harder than it needed to be.
    Steve Trotman - 回复
    For my 2nd iPhone 8 battery replacement, I chose not to remove the display completely, or the Taptic Engine and I was successful. You have to pay extra attention and it is a bit trickier to keep the display from moving around too much, but I think minimizing the amount of screws and connections to take out, the better. You can easily lose the screws and you have to mind which ones go where, as there are so many different lengths. YMMV.
    tripmusic - 回复
    In retrospect, I also would have skipped ahead to step 33. I didn't, but my efforts at removing the adhesive tape were also unsuccessful so steps 23-33 were for naught. Ended up applying isopropyl alcohol, then warming the back, and finally just physically levered the battery out. Battery was slightly deformed and became slightly warm, so as soon as I got it out I just put it outside on a brick.
    But the replacement worked.
    Peter Benson - 回复
  22. 更换iPhone8的分集式Wi-Fi天线, 拆卸Wi-Fi分集天线: 步骤 22 中的图像 1,1
    • 拧下用于固定Taptic Engine旁边支架的三颗螺丝钉:
    • 一个 1.3毫米的Y000型螺丝钉。
    • 一个 2.7毫米的十字型螺丝钉。
    • 一个 2.9毫米的十字型螺丝钉。
    My phone had Phillips screws in all three places, so I did not need the Y000 screwdriver bit.
    Daryl Maunder - 回复
    I don’t see the point in steps 18-27 if we’re only changing the battery. I pulled out the sticky tape with taptic and all this other jazz still intact. Am I missing something? Reconnecting that taptic connection cost me 5 years off my life, needlessly.
    William Mitchell - 回复
    Hey William!
    We instruct people to remove the Taptic Engine in order to minimize the chance that the battery adhesive will tear when you try to pull it out. The steep angle you have to pull the adhesive with the Taptic Engine installed dramatically increases the chance that the adhesive will break under the battery.
    Arthur Shi -
    since the sticky tape will usually tear anyway and it is no big deal, I agree stop at this point and take the battery out. Too many things can go wrong removing more screws and connecting/disconnecting all the connectors. Go to video instructions at this point. Wish I did.
    Bob McCall - 回复
    My tape tore away and now my home button does not work, which from what I see is to do with the tapic engine. It seems to be more dangerous to do that than to use heat and pry the battery out (which I had to do anyway). You should at least put in an warning/option for users.
    Gary Berman - 回复
    Hi Gary,
    The Home button connector is not related to the Taptic Engine and should not be affected by anything close to the battery adhesive. I would suggest carefully disconnecting and reconnecting the screen connectors, and make sure that there is no debris on the contacts. Be sure to disconnect the battery before you do this, or you will risk damaging the screen.
    Arthur Shi -
    Glad I stopped and watched the video at this point and skipped this step. Totally unnecessary, I used the iopener and heated the back of the phone before removing the battery with a pick and “ifixit card” came out easily. Not my first battery replacement.
    Rick Collins - 回复
    Kompletter bullshit!! Im Video wird es anders gezeigt und die Schritte 18-27 werden komplett ausgelassen. Ist auch viel besser so, da so das Risiko, dass man die Taptic Engine schrottet, wie es mir jetzt beim ausbauen passiert ist, einfach nicht vorhanden ist. Ich kann auch nicht nachvollziehen, warum man in einer schriftlichen Anleitung zum Akku Wechsel komplett andere Schritte schildert als im Video. An der Stelle hat iFixit deutlich versagt. Ein Haufen Splasher…
    Maximilian Ament - 回复
    Hallo Maximilian, du hast Recht, im Video wird die kürzere Methode gezeigt. Der Ausbau des Akkus ist für viele Menschen jedoch sehr schwer, wenn die Taptic Engine noch verbaut ist. Deshalb empfiehlt die Anleitung den Ausbau der Taptic Engine.
    Fabian Neidhardt -
    I can’t get the 2.7mm screw to tighten down the bracket.. not sure what i did wrong? the 2.9 will tighten in either place but the 2.7mm wont tighten anywhere.
    cb brooks - 回复
    Kann es sein das dieser Schritt falsch ist? Ich habe einen Y000 Schraubendreher aus dem Iphone 7 Set. Der passt aber nicht bei der roten Schraube.
    Sebastian Dechent - 回复
    The new part I received had two Phillips screws, so when you're doing the reverse, you may need to remove the screws from the new part before putting the old screws in, everything fit together otherwise
    Ronald Mitchev - 回复
    I really hope you guys not to skip these steps. it is really hard to pull out string with taptic engine. 4 of 3 strings were cutted when I treid to detach batteries with taptic engine. So, I really recommend you to get rid of taptic engine before you start this step. But if you skipped and strings are cutted, there is a way. Use hair dryer 90 secs as maximum hot behind the battries and detach the batteries. It worked to me.
    Min Su Kang - 回复
    The Y000 screw has an extremely shallow head and the screwdriver provided in the kit I used couldn't grip it at all. I skipped the entire taptic removal and was able to remove the adhesive with it in place by warming the phone then wrapping the end of the adhesive strips around a small screwdriver and gently rolling them out and away.
    Steve Trotman - 回复
    You can totally skip removing the Taptic Engine. Even with broken adhesive strips, I was still able to get the battery out with some patience. I removed it once before on a replacement and the strips still broke off, so removing the engine was kind of a waste of time anyways.
    tripmusic - 回复
  23. 更换iPhone8的分集式Wi-Fi天线: 步骤 23 中的图像 1,1
    • 将盖板(支架)取出。
  24. 更换iPhone8的分集式Wi-Fi天线: 步骤 24 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 24 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 24 中的图像 3,3
    • 用三角撬片将天线柔性电缆和扬声器顶部之间的缝隙轻轻地分离出来。
    • 柔性电缆的这部分会轻轻地粘附在适当位置。 如有必要,使用 iOpener 或吹风机中加一点热量来软化粘胶。 这样可以更轻松安全地分离柔性电缆。
  25. 更换iPhone8的分集式Wi-Fi天线: 步骤 25 中的图像 1,2 更换iPhone8的分集式Wi-Fi天线: 步骤 25 中的图像 2,2
    • 使用撬棒的尖端撬起并断开分集式天线的柔性电缆与主板的接口。
  26. 更换iPhone8的分集式Wi-Fi天线: 步骤 26 中的图像 1,3 更换iPhone8的分集式Wi-Fi天线: 步骤 26 中的图像 2,3 更换iPhone8的分集式Wi-Fi天线: 步骤 26 中的图像 3,3
    • 使用撬片在在天线柔性电缆下滑动,支架保持不动。
    • 使用撬棒的尖端撬起并断开天线的排线与其插座的连接,同时使用开口拨片压住插座不被破坏
    • 重新连接此电线 可能会比较需要技巧。使用镊子夹住柔性电缆,这样接口就和支架对齐了。然后,使用撬棒轻轻地按压,直到夹扣合上。
    Don’t worry if the socket lifts up a bit as you get it out. You’ll need to lift it up later (Step 25) so don’t push it back into place yet.
    Daryl Maunder - 回复
    Every instruction online (including your YouTube video) leaves the Taptic Engine in place. This added step did not help with battery replacement, and led to an hour of frustration trying to get the connector back in place.
    jgrsf - 回复
    I noticed the same thing and wondered if it was necessary. Thanks
    Laura Bernal -
    Yeah, I broke the connector off of my taptic engine trying to get it to reconnect to the lighting connector plate….freaking nightmare with that and the co-axe wifi connector……..I now have a working phone without haptics
    dave -
    I was glad I had the Taptic Engine removed when I failed to remove the battery adhesives. It leaves more room to work around the battery.
    Alexandre Deloffre - 回复
    I agree. And when reassembling the wifi antenna, I connected the two plugs first, which worked fine, and only after that stuck the antenna back to its sticky place.
    dl7utx -
    I was following this for replacing the loud speaker. I found that during reconnecting the antenna flex, I slightly rocked the taptic connector and it came lose. I was frustrated because my pre-close up test had everything working, then I shut it down, made sure everything was connected and put it all together (including a bang-on job on the display adhesive!!) and wham - no taptic responses.
    Just finishing reseating it, fought with the antenna flex, then ensured the taptic connector was seated properly underneath. All good now.
    Bill Shannon - 回复
    i cant get the small screw to tighten to hold the bracket in place. it just spins. the 2.7mm screw that is supposed to go into the lower left bottom. the 2.9mm screw that goes in lower right bottom will also snug down on lower left. I somehow messed up the hole I guess. can i use an extra 2.9mm instead of 2.7 mm ? if i can find one ? thank you
    cb brooks - 回复
  27. 更换iPhone8的分集式Wi-Fi天线: 步骤 27 中的图像 1,1
    • 移除 Wi-Fi 天线。
    What is Wi-Fi DIVERSITY antenna?
    Nikko - 回复
结论
若想要组装回您的手机,请按指南逆序安装。
在重新安装显示屏之前,别忘了重新粘贴示屏胶
你可以在这里处理电子垃圾 R2 或e-stewards 认证的回收商
维修遇见问题了?请参阅我们的社区论坛。iPhone 8 论坛
11等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Arthur Shi
于01/03/18注册
252,690 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
8条评论
Hello, The power of my iphone 8 plus other products is lower than the mains and wifi. When I dismantle the product in question, there is no change. Which product should change. The reason is that when I hold the top part of the phone the wifi and mains power is falling more and more.
kenany123456 - 回复
the two Phillips screws securing the bracket above the Taptic Engine won’t come out what do I do?
donnell wright - 回复
Hi Donnell,
Are the screws stripped or stuck? If they’re stripped, you can try some tips here.
Arthur Shi -
I’ve tested all networks on a phone without this antenna and it seems to work just fine.
What does the absence of this part actually entail?
Smeargle - 回复
The diversity antenna is basically an additional antenna which helps improve the Wi-Fi reliability and quality. Wireless functions should work without it, but this additional antenna can help in congested urban environments.
Arthur Shi -
Can someone please tell me what the connector is that the wifi diversity antenna plugs into by the taptic engine, as I have a phone in parts and it is missing that connector so my wifi diversity antenna has nothing to plug into. I am guessing the person I bought it off of lost it or broke it.
Doug - 回复
Hi Doug,
That connector connects to the lightning connector assembly, as seen here.
Arthur Shi -
How does wifi diversity antenna plug affect home button? I accidentally ripped the connector that connects to logic board that is right underneath the battery connector but now my home button is not working. How does wifi antenna affect that?
Sujan Lama - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 69
过去 30 天: 336
总计 37,255
