跳转到主内容
修复你的物品
维修的权力
商店
简介
Taptic Engine 的作用是为你的 iPhone 产生震动,以及触觉反馈。参考本指南以拆卸及/或更换 iPhone 7 Plus 的Taptic Engine。
本指南之前提到如何完全地拆下屏幕,这将预防损坏屏幕排线。如果你认为拆除 Taptic Engine 的时候并不会拉拽屏幕排线,则可以跳过拆卸屏幕的步骤。
  1. 开始这一过程前,请将iPhone电量放至25%以下,电量过高可能使得锂电池在意外情况下更容易起火或爆炸。
    • 开始这一过程前,请将iPhone电量放至25%以下,电量过高可能使得锂电池在意外情况下更容易起火或爆炸。
    • 在拆解前,确保你的iPhone已经关机。
    • 移除位于手机底部的两颗3.4 mm五角梅花螺丝
    • 打开iPhone的显示屏将导致防水密封被破坏。 所以请准备好新的密封胶。未更换密封胶的情况下重新组装的iPhone将不再具有防泼溅功能。
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 回复
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    Ben Meinhart - 回复
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 回复
    How do you turn off if the screen isn’t responding to touch?
    adam - 回复
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 回复
    Instructions for replacing the seal are here: iPhone显示屏粘合胶的更换
    bester - 回复
  2. 加热 iPhone 的下方可以软化粘合剂,让拆解更轻松。
    • 加热 iPhone 的下方可以软化粘合剂,让拆解更轻松。
    • 用吹风机或者准备一个 iOpener 来加热 iPhone 下方大概一分钟,以软化屏幕下方的粘合剂
    How long should I use a hairdryer for?
    Warren Binder - 回复
    I used it until it was hot to the touch but not too hot where you burn yourself.
    gczarny -
    Hey, I just took apart my first iPhone 7 plus today, and it was easier for me to use guitar picks and a magic glass tool. I did tear the home flex on the screen—now I know to be more careful of that on disassembly—-~Katrina of iPad Rehab Microsoldering
    jessabethany - 回复
    First I tried to remove the screen with the hot iOpener, but it doesn’t worked, the day after I putted the Iphone in the sun for a while and then used the hot iOpener, then the screen was easy to remove :-)
    Marc Boon - 回复
    Get a T-shirt add heat to a lil corner of it, with either a hair straighter or an Iron , touch the T-shirt if it’s seems hot but doesn’t burn u hold that lil hot piece of T-shirt against the edge ur trying to pry open , if it’s still not opening add a I’ll more heat,
    www.tertlegerl - 回复
  3. 在前面板的下半部分放置一个吸盘,正好位于Home按钮的上方。 确保吸盘与Home按钮不重叠,以确保吸盘和前玻璃之间能形成密封状态。
    • 在前面板的下半部分放置一个吸盘,正好位于Home按钮的上方。
    • 确保吸盘与Home按钮不重叠,以确保吸盘和前玻璃之间能形成密封状态。
    • 如果您的屏幕已经严重损坏,使用透明胶带将其粘好可以让吸盘固定。或者您也可以用非常强力的胶带来替代吸盘。如果这些都失败的话,您可以用万能胶将吸盘和破损的屏幕粘在一起。
    Hi! My suction cup doesn’t work. It won’t strongly suck on my screen. Does anyone have any advice?
    kaiminliu119 - 回复
    Heat it up just a little with a hair dryer make sure it’s flat , let it coo a bit now try it??
    robertread - 回复
  4. 以固定的恒定拉力上拉吸盘,来使得前面板和后壳之间产生轻微的间隙。 将撬起工具的扁端插入间隙。 固定显示器的防水粘合剂非常坚固; 创造这个初始差距需要很大的力量。 如果你很难打开缝隙,上下摇晃屏幕以削弱粘合剂,直到你可以插入撬起工具。
    • 以固定的恒定拉力上拉吸盘,来使得前面板和后壳之间产生轻微的间隙。
    • 将撬起工具的扁端插入间隙。
    • 固定显示器的防水粘合剂非常坚固; 创造这个初始差距需要很大的力量。 如果你很难打开缝隙,上下摇晃屏幕以削弱粘合剂,直到你可以插入撬起工具。
    • 在向上拉起吸盘的同时,旋转撬起工具以加宽屏幕和后壳之间的开口。
    Be very careful not to pull up with too much force. My screen just shattered while I was pulling up with my suction cup. (There were no previous cracks or chips or anything).
    Benjamin Pounds - 回复
    I’m stuck on this part. I’ve heated the bottom up and attached the suction cup right above the home button, but I can’t pull it apart. I feel like I’m going to break the glass display. Tips?
    whtafrcn420 - 回复
    Someone mentioned above, using strong tape helps .
    MajorCouillon - 回复
  5. 在iPhone左下角的前面板和后壳之间插入撬起工具的扁端。 沿着手机的左边缘滑动撬起工具,从下方开始朝向音量控制按钮和静音开关移动,来将显示屏的粘合剂破开。 不要尝试将显示器顶部从后壳上撬开,因为那里有塑料卡勾固定,可能会被损坏。
    • 在iPhone左下角的前面板和后壳之间插入撬起工具的扁端。
    • 沿着手机的左边缘滑动撬起工具,从下方开始朝向音量控制按钮和静音开关移动,来将显示屏的粘合剂破开。
    • 不要尝试将显示器顶部从后壳上撬开,因为那里有塑料卡勾固定,可能会被损坏。
  6. 将撬起工具从左边取出,再从右下角插入。 从下至上的滑动撬起工具来破开固定显示器的背胶。
    • 将撬起工具从左边取出,再从右下角插入。
    • 从下至上的滑动撬起工具来破开固定显示器的背胶。
  7. 上拉吸盘来上提显示屏以及打开iPhone。 不要将显示屏提起超多10°,因为沿着设备右边有连接显示屏和逻辑板的细软性电路板。
    • 上拉吸盘来上提显示屏以及打开iPhone。
    • 不要将显示屏提起超多10°,因为沿着设备右边有连接显示屏和逻辑板的细软性电路板。
  8. 上拉吸盘上的小突块,将吸盘从前面板上取下。 上拉吸盘上的小突块,将吸盘从前面板上取下。
    • 上拉吸盘上的小突块,将吸盘从前面板上取下。
  9. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  10. 沿着手机顶部的边缘开口,使用开启塑料片滑动,以松开最后粘合剂。 沿着手机顶部的边缘开口,使用开启塑料片滑动,以松开最后粘合剂。
    • 沿着手机顶部的边缘开口,使用开启塑料片滑动,以松开最后粘合剂。
  11. 将显示屏组件拉到略微远离手机的顶部边缘,使其脱离将显示器固定至后壳上的卡勾。 通过从左侧摆动显示屏来打开iPhone,就像翻开一本书的封底页。 此时,先不要尝试将显示屏完全取开,因为还有一些脆弱的排线仍然连接着iPhone的主板。
    • 将显示屏组件拉到略微远离手机的顶部边缘,使其脱离将显示器固定至后壳上的卡勾。
    • 通过从左侧摆动显示屏来打开iPhone,就像翻开一本书的封底页。
    • 此时,先不要尝试将显示屏完全取开,因为还有一些脆弱的排线仍然连接着iPhone的主板。
    So if I broke the cable that connects the display to the logic board. What replacement part would I need to order now?
    Robert Danson - 回复
  12. 卸下四颗将下方显示线缆保护片固定至逻辑版的三端Y000螺丝:
    • 卸下四颗将下方显示线缆保护片固定至逻辑版的三端Y000螺丝:
    • 三颗1.2 mm螺丝
    • 一颗2.6 mm螺丝
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - 回复
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - 回复
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - 回复
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - 回复
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - 回复
  13. 卸下下方显示线缆保护片 卸下下方显示线缆保护片
    • 卸下下方显示线缆保护片
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - 回复
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - 回复
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - 回复
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - 回复
  14. 使用撬棒的尖端从逻辑板的插座上撬起并断开电池的连接。 向上轻轻翻开连接器线缆,以防止其意外触碰连接到插座并给手机供电。 向上轻轻翻开连接器线缆,以防止其意外触碰连接到插座并给手机供电。
    • 使用撬棒的尖端从逻辑板的插座上撬起并断开电池的连接。
    • 向上轻轻翻开连接器线缆,以防止其意外触碰连接到插座并给手机供电。
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - 回复
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - 回复
    I slipped a small piece of paper under the flap.
    MajorCouillon - 回复
  15. 确保电池接口是断开的。 使用撬棒的平端或者指甲以撬开两个下部显示连接器,笔直地从逻辑版的插座上撬起。 若要重新安装连接器,向下按压直到其到位,接着重复按下另一端。请不要按压中部。若连接器未对准,可能会弯曲从而造成永久损伤。
    • 确保电池接口是断开的。
    • 使用撬棒的平端或者指甲以撬开两个下部显示连接器,笔直地从逻辑版的插座上撬起。
    • 若要重新安装连接器,向下按压直到其到位,接着重复按下另一端。请不要按压中部。若连接器未对准,可能会弯曲从而造成永久损伤。
    • 如果你在重新组装手机时有空白屏幕,显示屏上有白线,或部分、完全没有触摸响应,请尝试断开连接并小心地重新连接这两根电缆,并确保它们完全就位。
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - 回复
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - 回复
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - 回复
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - 回复
  16. 卸下三颗固定前部面板传感器组件连接器的保护盖的三端Y000螺丝。 一颗1.3mm螺丝 两颗1.0mm螺丝
    • 卸下三颗固定前部面板传感器组件连接器的保护盖的三端Y000螺丝。
    • 一颗1.3mm螺丝
    • 两颗1.0mm螺丝
    • 卸下保护盖。
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    chris west - 回复
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - 回复
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - 回复
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - 回复
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - 回复
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - 回复
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - 回复
  17. 从逻辑板的插座上断开前部面板传感器总成连接器。 这种按压连接器应该小心避免弯曲损伤。
    • 从逻辑板的插座上断开前部面板传感器总成连接器。
    • 这种按压连接器应该小心避免弯曲损伤。
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - 回复
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - 回复
  18. 卸下显示屏总成。
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - 回复
  19. 在后部卸下两颗固定气压组件的Phillips螺丝:
    • 在后部卸下两颗固定气压组件的Phillips螺丝:
    • 一颗2.9mm螺丝。
    • 一颗2.1mm螺丝。
    I skipped this step and go straight to step 25. I skipped it because I couldn’t get the screws to come off. But skipping those step did not prevent me or has any detrimental effects on performing step 25.
    Jamie Liao - 回复
    I agree, I don’t see any reason to remove the Taptic engine to remove the battery…It seems like more of a chance of screwing something else up…keep it simple…
    William Karis - 回复
    If you’re replacing the battery, removing the Taptic Engine gives you a much better chance of removing the battery adhesive strips successfully. To keep them from snagging and breaking, you want to pull them from as low an angle as possible. With the Taptic Engine in the way, you have to pull them at almost 90 degrees, or risk snagging them on the Taptic Engine.
    Jeff Suovanen -
    i can’t get the 2.1 screw 2 come out pls help anyone
    John Bryce - 回复
    I agree with Jamie Liao above. Skips steps 18-24 as described. Before proceeding with step 25, I heated a microwavable hot/cold compress (used to treat muscle strains). I set the iPhone back casing on the heated compress before pulling out the adhesive strips.
    Again, there is no need to do steps 18 through 24.
    Thomas Young - 回复
  20. 温柔地把气压计向 Taptic Engine 的方向推动,分离固定 iPhone 底部的黏胶。 温柔地把气压计向 Taptic Engine 的方向推动,分离固定 iPhone 底部的黏胶。
    • 温柔地把气压计向 Taptic Engine 的方向推动,分离固定 iPhone 底部的黏胶。
    Adhesive may require a tiny amount of tugging of the barometric vent to free it…
    Sarr Sheffer - 回复
  21. 卸下气压组件。
    • 卸下气压组件。
  22. 使用撬棒(spudger)的平端从主板的插座上断开Taptic Engined的连接器。 使用撬棒(spudger)的平端从主板的插座上断开Taptic Engined的连接器。
    • 使用撬棒(spudger)的平端从主板的插座上断开Taptic Engined的连接器。
  23. 卸下三颗将Taptic Engine固定到后部框架的1.5mm Phillips螺丝。
    • 卸下三颗将Taptic Engine固定到后部框架的1.5mm Phillips螺丝。
  24. 拆下Taptic Engine 拆下Taptic Engine
    • 拆下Taptic Engine
结论
参考本指南的相反顺序以重新组装你的设备。
49等其他人完成本指南。
特别感谢这些译者︰
87%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Scott Havard
于2016年06月27日注册
41,711 信誉积分
创作了33篇指南
is there a replacement taptic engine available to purchase?
Jody Tamplen - 回复
Did you end up finding one anywhere?
Matthew Lafond -
添加评论
浏览统计数据:
过去的24小时: 21
过去的7天: 145
过去的30天: 498
总计 27,306
