简介
该教程仅适用于你的新屏幕总成包含前置摄像头、听筒及 LCD 屏蔽板的情况。你只需要简单地移除旧的屏幕组件并将 Home 键与 Touch ID 传感器组件替换到新的屏幕上。
如果你的新屏幕不包含上述组件,你需要从旧屏幕上将其移到你的新屏幕上。请遵循这个更详细的指南 。
在以上两种情况中,原本的 Home 键与 Touch ID 传感器都必须从原本的屏幕上转移到新的屏幕上,否则会导致其无法使用。
注意:如果你的手机在维修之后,自动感光功能失效,请确保手机更新到iOS 12。即使是使用苹果原配件,True Tone 功能也会失效。
工具
如果您的手机显示屏已经碎裂,请避免屏幕进一步的破碎,并且当您用胶带粘贴屏幕玻璃以维修手机时,请避免身体部位受伤。
使用透明胶带交替重叠粘贴,完整地覆盖住手机的屏幕。
如果屏幕玻璃的碎裂导致接下来的步骤中的吸盘难以吸在屏幕上,请尝试使用黏度较高的胶带(如粘水管用的胶带)折叠成一个把手,来提起屏幕。
对比你的新更换的部件与原来的部件——你可能需要在安装之前将新的部件去移动剩余的部件或者除去粘合胶。
“‘以逆序来重组你的设备“‘
带上你的电子垃圾到R2 or e-Stewards 的认证回收商。
修理没有遵循预期?检查我们的问题解答社区 来解决问题。
“‘以逆序来重组你的设备“‘
65等其他人完成本指南。
特别感谢这些译者︰
20%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
6条评论
Very useful information…
Has anyone found out any info about replacing the Apple iPhone 8 Front glass. Last I checked Apple had made it that if you install a non OEM screen and updates their phone, it will brick there phone. I have not been fixing any iPhone 8’s or iPhone x’s due to this. I So if someone knows if this has been resolved or if this still holds true can you please let me know. Also, Fixing back glass. From what I have seen they use some crazy glue. Does anyone have any methods on a easy way to replace back glass on the iPhone 8’s ? do you still basically have to gut the phone ? what kind of glue is used to glue it back on? Any help with these issues would greatly be appreciated I have been repairing phones for over 8 years + and turning away customers because apple is so dumb with these things upsets me greatly. I loved repairing iPhone up until this point. Help please.
Replacing the screen will not Brick the iPhone, although the 8/8Plus & iPhone X all have an issue with the Ambient Sensor when a new screen is fitted. Although a way around this is to use a EEPROM device to copy the firmware from the original screen. It is also rumored that Apple are fixing the Ambient Sensor issue in iOS 12.
Donald -
Anyone know if the ambient sensor is fixed?
alexaamo91 - 回复
Hi. My iphone 8 plus screen is broken. I purchased it from USA, I’m in Turkey, Istanbul right know. When I took it to the apple store over there, they told me I need a code to replace the screen, and every country has different code. In order for me to replace the screen, I need that code.
Would some one please tell me what to do. I really appreciate it.
Thanks.
Sean Nouhi - 回复
