简介
不小心掉落了S8?手机和钥匙放在同一个口袋里?
这些情况很可能会导致玻璃后盖破碎。参考本指南以更换三星盖乐世S8的后部玻璃面板。
如果你的更换部件并未包含将其固定的粘合胶,那么你将需要购买用于玻璃后盖及指纹读取器的粘合胶。可以选择专用于S8的粘合胶或薄的高粘合双面胶。
你所需要的
重新加热iOpener然后将其放在后玻璃指纹传感器上。
推动指纹传感器,来使其与后面板上的粘合剂分离。
如果传感器很难卸下,请轻轻地将一个塑料打开工具放置在塑料背衬的下方,以便在推动之前松开粘合剂。
黏好粘合胶后参考下列步骤的相反顺序重新组装你的设备。
128等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
17条评论
No. After the adhesive is removed, your water resistance is as gone as your warranty.
after the rear panel is removed? ... no...
Great tutorial, simple and straight to the point. My type of learning.
If I could add just one little thing….
I myself would have loved if you would have touched on replacing the fingerprint scanner ribbon when replacing the back glass. , I learned
None the less, you gave me knowledge and I thank you…
