简介
使用本指南更换三星盖乐世 Note8 上破裂或损坏的显示屏。
在拆卸手机之前,请将电池放电至25%以下。如果意外被戳破,电池会着火和/或爆炸,但如果放电,发生这种情况的可能性要低得多。
注意:本指南只教导你更换显示屏,同时保留原始框架、逻辑板和电池。但是,这款手机的一些替换屏幕预先安装在一个新的框架(机箱)中,这需要一个非常不同的程序 —— 更换手机内部并安装新电池。在开始本指南之前,请确保你有正确的部件。
本指南涉及拆除后玻璃盖,你需要更换粘合剂才能将后盖重新连接到手机上。如果你的更换显示屏没有粘合剂,你将需要使用胶带来固定它。打开三星盖乐世Note8将“损坏设备上的防水密封'。如果你不更换粘合剂密封件,你的手机将“正常运行”,但是“它将失去防水功能”。
如果框架损坏或弯曲,更换它是很重要的,否则新屏幕可能无法正确安装,并且可能因压力不均而受损。
将显示屏与框架分开的过程通常会破坏显示屏,因此除非你打算更换显示屏,否则请不要按照本指南进行操作。
你所需要的
用一个吸盘来拉开后盖并将一个三角撬片插到后盖和边框的缝隙里。
一边拉着吸盘,一边用翘片从侧边中间开始沿着边缘滑动来切开密封胶
向手机的底部移动撬片,并把它留在那里(像图2一样)(你肯定不想你刚刚切开的密封胶又双叒叕粘到一起了)
插进另一个翘片,并把它移到手机的顶部(像图3一样)
I used an X-acto knife with the flat blade to get it started. I tried using the suction cup - but it’s difficult to get good leverage. Once I got the cover started - I used the metal pry tool (sharpened with a dremel file) and a business card to work it open.
This is definitely the hardest part.
Once off I see all the glue on the curved part of the chassis NOTON THE BACK. Apply heat to curved edges.
Lyle Walsh - 回复
当三条边的胶水都被划开了以后,你就可以缓慢地打开背面玻璃了。
当你翻开背面玻璃时,当心指纹识别器的连接线。你可能需要把链接线分开,下一步有所说明。
I broke the back camera cover for the NUT 8 and then I bought a commercial cover and installed it but the quality of the picture became very bad and my question is, do you know where to get the original cover at a reasonable price?
用一副镊子来取下指纹识别器的接口。
don't skip disconnecting the sensor, even if isn't still glued to the case. it has to move away from the NFC/charging coil assembly in order to free the latter so it can be lifted away from the battery.
取下后盖玻璃。
How do you swap the fingerprint sensor
Lukus Carr - 回复
You can use a tweezer to swap the fingerprint sensor, you might be careful when doing the step 6, additionally, a tweezer will be helpful when reassemble the fingerprint sensor. please note that your new back cover needs to have the fingerprint adhesive on. most of the product did not have. i have get a LUVSS brand from amazon which came with all OEM adhesive and full set tools, even a B6000 glue, best option to go for replacing the note 8 back glass
使用顶部边缘的撬片,以便在NFC天线和充电线圈组件与外壳之间进行操作。
撬出外壳顶部的组件。
准备 iOpener 并将其放置于显示器上至少两分钟,以软化下面的粘合剂。
将重叠的透明包装带放在Note8的显示屏上,直到整个面都被覆盖。
这将保持玻璃碎片在原位,并在撬起和提起显示器时提供结构完整性。
如有可能,请在涂抹粘合剂并重新密封手机之前,重启手机并测试维修。
重新涂抹粘合剂后,请按逆序操作这些说明重新组装你的设备。
确保新屏幕安全的最佳方法是使用一张修剪合适的双面胶带。将胶带贴在屏幕背面,然后小心地将显示屏电缆穿过框架。对齐屏幕并将其按入到位。
99等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
21条评论
I’m sorry, but this is just a preview question. When the guide says display, does it mean only the glass screen or the LCD and digetizer as well?
Hello Adrian Gomez. Here “display” refers to the glass, digitizer and LCD combo—those are fused together.
For this repair, do I need to buy the 230 dollar screen part as well?
This guide here is for replacing only the screen without the frame (which we currently don’t have in store). The 230 dollar part includes the frame and the according guide can be found here: Samsung Galaxy Note8 Display Assembly with Frame Replacement
Hi
I replace the new disply the camera ( front is working ) is not working I tried many things such as factory settings put it didn’t work
now I orderd a new camera hope it works or there is another way to solve it
nasser
zarmat2002 - 回复
I replaced my first cracked display screen today. Everything went quit smoothly thanks to Dominik . Thanks for the guide.
Can I purchase just a replacement front screen and digitiser (easily available on fleabay) to replace a cracked front Note8 screen?
Turns out that the screen+ digitiser are widely available without the LCF fused into them.
Thank you.
Hi ILM, separating the actual display from the front glass/digitizer is a cumbersome procedure that requires special tools. Same goes for fusing them together again. This could be done in well-equipped repair shops. Going for a combined display+digitizer assembly replacement is mostly the way to go for a “regular user” repair.
On part 19 the gold foil what is that and why have non of the parts ive bough come w it
Hi there,
Thank you for the guide and What is your opinion and recommendation on non-original (but fairly looking good)displays that we can buy online? Should we adhere to replace with original parts? What are the most possible consequences that can occur in such non-original replacements? Please share your ideas.
Hi uchira subhashana,
aftermarket screens can work well for repairs and often they are unbranded original parts. So there is nothing wrong with that. However you can’t say this in general because at the end of the day it always depends on where you buy the screen. Not all retailers are evenly reliable and you should always try to find a safe source like iFixit is. Worst that can happen with an aftermarket screen is that the new screen is not working but usually this wont harm your phone and you can send it back. This can happen with original frames as well.
will be awesome if you leave a links with all things we have to buy to do this.
Is there a safe reliable source for just the lcd/screen without the frame? A $200+ repair with 2+ hours of labor makes a hard sell.
I'm none to sanguine on the available options on amazon.
Thankyou again for the amazing guide.
Anyone have any recommendations?
Sorry for the delay, its awesome that you want to get into phone repair as it helps the environment and saves money!
https://www.megafixit.com/products/samsu...
I am repairing a note 8 myself, and will use this display totalling ~$180
Hop efully you guys can help me out, I did this procedure but when turning on the phone with the new display speaker, audio jack not working and Sim not recognized and everything was working properly before with the old screen.
Does iFixit sell display adhesive? if not where can i find some
You can use this double sided adhesive or pre-cut adhesive like this one (select different widths and pre-cut with the dropdown menu).
Is it good to use a glue or a double sided tesa tape to assemble everything back?
You might want to follow the link from two comment above for suitable adhesive :)
I used a heat gun to soften the glue - worked it around the edges, moving the heat gun quickly. As this is my first attempt, I’m still calibrating on this - but other guides mention getting the back cover hot enough so as it’s just too hot to touch. I also have a temp probe on my multi-meter, and I measured appx. 75 deg. C.
One of the other guides showed using a electronics hot plate set to 105 deg C for 60 sec.
Phil Brooks - 回复
