跳转到主内容
插入 舒尔 SM58 XLR 线缆
  1. 插入 舒尔 SM58 XLR 线缆, XLR 线缆 插入: 步骤 1 中的图像 1,1
    • 确保你拥有正确的三针XLR线缆
    • 握住线缆母头的尾部(3个孔)
  2. 插入 舒尔 SM58 XLR 线缆: 步骤 2 中的图像 1,1
    • 将麦克风(麦克风连接器)末端的针脚与XLR电缆上的孔对齐。
  3. 插入 舒尔 SM58 XLR 线缆: 步骤 3 中的图像 1,1
    • 一旦引脚对齐,将电缆推入麦克风的底端。 你应该听到“卡”的一声。
结论
要断开线缆和麦克风,按照指南的相反步骤。
13等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
nat coll
于09/27/12注册
642 声望
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了20篇指南
21条评论
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - 回复
Is this April's fool? XD
s6963172 - 回复
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - 回复
I know a few people who would see this and still screw it up.
jimboc - 回复
do it in reverse? you have to press the button though on the male end...
Michael Fox - 回复
Will this work with an Audio-Technica ATM-410, or just the Shure?
cbrislain - 回复
Just Shure. On Audio-Technica you have to rotate the plug six times clockwise and whisper a few nice words into it before plugging it in. I've always found that lullabies work quite well.
staale -
I have a 1/4 adapter on my Shure, is that process different? I can't seem to make the male 1/4" connect to the female XLR
JON CAMPBELL - 回复
Push harder.
staale -
Some of us are musicians , so we appreciate the help
tomandlindafirme - 回复
When do you hear the sound from it?
Charlie Green - 回复
Bloomin' eck.... & I've been using cellotape, Blu Tak and super glue. No wonder I had to revert to the megaphone all the time
george sandoz - 回复
I don't know about you lando77 but I always blow on the female end (the cable end with the holes) to blow dry any moisture out. What good does it do to blow on the male pins?
darryltrimm - 回复
Do these instructions work for the ElectroVoice EV 635A as well?
carterjim - 回复
This is useless. Why didn't you post a video that shows the process.
mperloe - 回复
Wow!!! Thank you so much! This is really great information. Now I won't have to hire people to come do this for me anymore. Can you post a video of how to put the microphone on a stand?
dhoffman98 - 回复
Thanks for posting this, I recently ran out of toilet tissue and have been using my Shure SM58 Owner's Manual. You're a lifesaver!
hemightbefluffy - 回复
He's holding the plug with his right hand. But what if I'm left handed. Do I need to rotate it? Or should I switch what side I'm standing on?
Bob DeMaa - 回复
Managed it on 5th attempt , now what the heck do I do with the other end of the cable ???
gary blair - 回复
are these instructions specifically for drummers or can anybody use them?
Cedric the Dead - 回复
Hola ..he comprado un micrófono shure pg48 1i no se porque al conectar con el cable no se escucha ningun sonido..
cristianbocanel51 - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 153
总计 67,486
