此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南将演示如何拆下 Galaxy Tab S 10.5 平板电脑的后盖。这是该设备处理大多数内部问题时的先决条件步骤。你必须先拆下后盖,才能接触到内部的许多组件。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
21等其他人完成本指南。
6指南评论
This is very misleading and not the correct way to open this device. This will damage the backplate and the antennas that are glued together. The proper way to open this tablet is from the front taking the LCD out of the frame.
I disassembled and assembled back SM-T805 for motherboard replacement 2 hours ago. Discovered that back cover have a row of tiny pins with tips molded into back cover rim who are designed to break out and larger pins who will click open and back on closing just fine. Also back cover rim is glued to cover with weak glue. Seems someone Samsung decided that those larger pins alone are not enough to keep back cover firmly in place without flapping around. In reality larger pins alone on assembling will click back and keep cover in place just fine.
However I agree to you that correct way is to carefully open this tablet from screen side with these small blue flat openers or with plastic cards. It will be faster as well. Back cover rim should be removed only to replace antennas. I hope that author of these manuals will fix that.
Jamee is right, the SM-T805 (3G) can be opened separating the cover from the LCD, and not by removing that back cover that is glued to the rest.
How can I get another charging female component
peter toombs - 回复 分享
