跳转到主内容
恢复出产设置/硬重置
视频概述
  1. 恢复出产设置/硬重置, 恢复出产设置/硬重置: 步骤 1 中的图像 1,3 恢复出产设置/硬重置, 恢复出产设置/硬重置: 步骤 1 中的图像 2,3 恢复出产设置/硬重置, 恢复出产设置/硬重置: 步骤 1 中的图像 3,3
    • 1. 关闭设备。
    • 2. 按住电源按钮直到机器震动。
    • 3. 立刻松开电源按钮并且马上按住音量下按钮。在屏幕上会出现一个感叹号。
    • 4. 按顺序按下以下按钮- 音量上 - 音量下 -电源按钮 - 音量下
    • 5. 手机会重启并且恢复到出产设置。
    • 你成功了吗?
    • 请订阅我的频道 ツ
    how do I get this window pane remove so I can make outside calls
    Tracy Sampson - 回复
    how wil i unlock my phone. have tried the above method but it did not work
    obiagelipeter - 回复
    Thanks for the tip, it really works....
    Malika Jones - 回复
    Hello! Thank you so much, it's working.
    rufdoniedubalan - 回复
    yes, your methode is working bro
    keep it up.
    thank you
    jay mobile - 回复
    thaaaaaaaaaaaaaaaaaaaaaaaNkssssssssssss bro
    Ayesha yes shur - 回复
    yeah it was a great way of solving my problem yeah
    qwekujunior - 回复
    Yes thank very helpful
    Juliet Fraser - 回复
    thanks for the help
    TAWFIQ GOMDA - 回复
    When i try to reset this happens....instead of showing to rounded gears..it shows a sign of a spark of lighting and one gear..and it just stuck like that.
    Vincet - 回复
    what should i do...if that is the case..
    Vincet - 回复
    Did hard reset however ph just keeps shutting down and restarting none stop. Nokia 530
    toyota.sprinter.1984 - 回复
    So can anybody help me with my phone.
    Nice one worked first time.
    Stuart Wilson - 回复
    How do I update so that I can get messenger
    Stuart Wilson - 回复
    After the factory reset my phone it went to the logo and stuck on that screen. What next?
    Pauline Scaife - 回复
    it soo easy and simple
    marveeosei2 - 回复
    How can I reset without a power button?
    Fred Gallagher - 回复
    Thank you so much! That was exactly what I needed!
    Almaz Berenike Bergk - 回复
    Thakns so much dear friend i can use my phone now
    zafrullah ubwa - 回复
    I tried and it returned back to locked screen
    Archibong James - 回复
    Omg. It didn't do the exclamation but acted like it was gonna open the phone with emergency locked screen and I pressed something and it asked me if I wanted to be put in safe mode! Good enuf for me!! THANK YOU
    Blah - 回复
    Now it's on safe mode so hacker can't get in but it never factory reset. Is there something else I can try ? Or is the safe mode a product of the hacking?
    Anyway it won't reset. Please help me
    Blah -
结论
若要重新组装你的设备,按照以下步骤逆序操作。
45等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
ZFix
于12/09/13注册
191,341 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,541篇指南
54条评论
Thanks for your support
knowledge chinoda - 回复
I factory reset my Nokia model RM-1018. My IMEI # is completly clean and clear... so can I swap out my SIM card for another service provider?
Do I just change sim cards and turn on, and set up service?
thebentwan - 回复
work great....
andykam08 - 回复
Nice one more power to your elbow
tijani bashir - 回复
Adi maddest commands ryt there im going to make cash with these no hard feelings
rethabilentabe - 回复
Thanks for your usefull advice
Gizmo - 回复
Thanks bro successfully working. GOOD
Aravind Vfx - 回复
I'm trying to do this without an LCD on a Lumina 530. I get the vibration on step 2 -the phone turning on. Since i do not see an exclamation mark, I just hold the button for 15-20 seconds. Right before step 4 - the sequence I get another vibrate. After that I just push the buttons as directed but no more tactile feedback. I have NOOO idea if i'm wiping the device or not. No rebooting vibration - so I'm guessing that somewhere along the way I'm jumping the gun - right?
Can someone tell me the vibration feedback along the way that I should be paying attention to?
Or another way to do this - maybe?
Thanks!
heni1022 - 回复
just do these steps and wait for aprox 15 minutes because this process takes a lot of time complete the recovery
jay mobile -
Thank you so much... it really works for me... Good day to you...
Ricardo Reyes - 回复
flight mode not remove problem on my phone
balaram upadhayay - 回复
Thank you!It worked!
Kim - 回复
It just keeps restarting and showing the Microsoft symbol what do I do u can contact me at (Cell)#337-298-0132
michael trahan - 回复
Me too I have the same problem as you
Seidou -
great work thanx
Shanil - 回复
i do the following instruction then it just starts up again please help you can email me at shevez80@hotmail.co.uk thanks
shevez - 回复
plz try thish........... press power button until vibret relese the power and press ,volume down,
now you click volume down,volume up ,volume down ,power,and volume down
Ramesh Shah - 回复
mine dont work
Blair Bird -
i have nokia rm 1053 X+ and i already deleted system files at the heard reset time and also deleted all the files from sdstorage and format all storage location... and rebooting the mobile and now my mobile is not working... its not turning on :( can u pls help me?
Niteen Koshti - 回复
You really saved me the trouble pal
neso voke - 回复
I have a microsoft model rm 1077 and am trying to hard reset it because I've forgotten my unlock code. I've tried holding the volume down reset instructions above but I don't ever get the exclamation point to show. Any tips?
Melissa Evans Tedesco - 回复
My Nokia 530 kept starting shutting down got blue screen with ☹ , followed instructions. The operation system reinstalled. Phone works perfectly. Running windows 8.1
Hw to reset Nokia RM 970 plz help
silence - 回复
Ok now ask for a recovery key where do I get that. thanks for the heads up
Hyck lyfe - 回复
thank you kind sir
Marné Nagel - 回复
Idk what it did now my screen is frozen with a lightning bolt and a settings icon
Bill Arthofer - 回复
Idk what it did to my phone but now its frozen showing a lightning bolt and a settings
Bill Arthofer - 回复
In your case, i think, you need to charge your phone while resetting it.
make -
im doing that! what now?
fartybox34 -
Wow! This is great. It worked perfectly.
Omobemi Sule - 回复
wow thanks it worked.. ithinkithink
Lynn-Marie Kipp - 回复
I did that but now just h2 gears spinning
Is this the only way to by pass? I dropped my phone and it now reads that I have wait 1564946 minutes to try again! I have already had to reset to factory and lost all of my pics. I really do not want to have to do it again.
nicolerugbyny8 - 回复
is there a way to by pass the locked screen without deleting everything? I dropped my phone and it now reads that I have to wait 1564494 minutes to try again!
nicolerugbyny8 - 回复
My Nokia RM986 not remove the password and hard reset please help me…
Kishor Deokar - 回复
My Nokia RM986 not remove the password and hard reset please help me and solve my problem…
Kishor Deokar - 回复
it was very easy to understand, thanks a million for such idea.
F. Evesekai Tonnon Kettor - 回复
I have seen de exclamation mark but da phone just restarts normally
Edger Davis - 回复
mine is an RM 1067 and it’s showing Bitlocker recovery , and it says to remove this drive plug in the USB drive that has the bitlocker recovery key
Bit locker needs your recovery key to unlock your drive because the trusted platform module is not accessible for more information on how to retrieve this key go to http://windows.microsoft.com/recoverykey... for another pc or mobile device
press Enter to reboot and try again
Press ESC or windows key for more options
Samuel Beem - 回复
Mike Nixon - 回复
SUPER Awesome Guys… I should have googled this the first time i had trouble… Keep up the GREAT Job iFixit… Yall ROCK!!! Have a Blessed day
ede31421 - 回复
thank you sa video :D
ricky ygot - 回复
PLEASE HELP ME,
I USE NOKIA 6. AND I USE MY FINGERPRINTS AS MY UNLOCK FOR DEVICE,
THEN SOMEHOW IT REQUIRED BACKUP PASSWORD BUT I FORGOT MY PASSWORD, THERE IS NO FACTORY RESET WHEN I USE UP BOTTON +POWER KEY nO DATA.
I WANT TO RECOVER USING MY GOOGLE ACCOUNT. PLEASE HELP ME. THANKS
Liezel Magtanong - 回复
After reset it ask me for reset protection notification key
jamesjam20032003 - 回复
I have a nokia model : Rm-1189 it was my father cell phone and now i want to use it but i dont know the securityhow do i remove the security.
Xiganga Tv - 回复
Totally helped ! Kudos.
stephen musyimi - 回复
I forgot my password and tried to do a hard reset but i failed its just rebooting wth a display showing 4G LTE
Edwin Chinyathi - 回复
I have seen reached the exclamation mark stage but the phone just restarts normally and did not perfom the hard reset.Model written in chinese bt RM-1010
Nice one, it works perfectly
Ayotomiwa David - 回复
Didn't work, lock screen says try again 3580807 minutes ! What do I do ?
Robs Other - 回复
Bro youre a genuis cant believe it works i have been trying for many days now not untill I came to your website.
Thanks again bro
Joseph Afodu - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 129
总计 165,167
