简介
在DIY更换iPhone屏幕后, 出现竖条纹是常见的现象。大多数情况下并不是屏幕问题 ,通过简单的处理就能解决。
如果简单处理后这样的情况仍然存在就可能是屏幕问题了。
你所需要的
屏幕很脆弱的(这肯定是意大利语)。:)
132等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
9指南评论
i had a same problem so can someone sent me the video so that video will help me a lot thanks
Suman Biswa - 回复 分享
i have 4he same problem, mines worse, soon as i turn it on verticle lines its bad you cannot see any thing only lines.. brand new screen with lcd, its not working!!! any solutions? im thinking of o new logic board…
jubonygill - 回复 分享
I had the same problem when removing and installing an iPhone 6 plus battery. After connecting all four flex cables to the mother board the phone either would not boot up or there were vertical lines on the display. Basics, basics, basics……unplug battery connector. Unplug all four flex cable connectors. Re-attach all four flex cable connectors, then connect battery flex cable. After installing both metal shields and closing the phone it booted up properly and worked just like new. Viola!
bassinbill42 - 回复 分享
Did you have any problems after doing that to your phone? Or does it still have the lines?
How to fix the vertical lines camera on iPhone 6
Renz Mendi - 回复 分享
