简介
微软家的硬件设备存在一些信用危机,而微软又称呼新款Surface Pro为“最多才多艺的笔记本电脑”,也就意味着这台平板电脑实际上是一台笔记本电脑(可以将其转换为Surface工作站)。微软我们跟你说,我们会深入它的内心看看能否帮你们证实那句话。朋友们,接下来献上的是Surface Pro 5寻找自我拆解节目!
我们希望能够帮助您找到所有微软设备的内部构成。欢迎访问以下网址
你所需要的
视频概述
从外观上看,这台Surface Pro非常像去年的型号。但是想必各位也知道微软说过什么了,关键是它的内在:
12.3英寸 PixelSence 2736 x 1824 分辨率显示屏(267ppi)
英特尔 Skylake 酷睿 m3 (4M 缓存 2.70 GHz),最高可选 酷睿 i7 (8M 缓存 4.00 GHz)处理器
可选 4 GB / 8 GB / 16GB DDR3L 1600 MHz 内存
可选的 128 GB/ 256 GB/ 512 GB和1 TB 固态硬盘
支持1080p拍摄的8百万像素后摄像头,以及5百万像素前摄像头
USB 3.0 接口,micro-SD插槽,miniDP接口以及SurfaceConnect 充电接口
802.11a/b/g/n/ac Wi-Fi和蓝牙4.1连接
显示器背部的芯片,发现了看起来类似于在Surface Pro 4上的N-trig模块:
Microsoft X904169 06 CL1714
Microsoft X904163 01 CL1715
Macronix MX25U1635F 1.8V 16 Mb MXSMIO串行闪存
现在主板已经拿出来了,让我们看看有哪些芯片吧。
英特尔 酷睿 m3-7Y30 处理器
三星 KUS020203M-B000 NAND闪存
三星 K4E8E324EB 1 GB LPDDR3 1866 MHz DRAM芯片(共4片组成4GB)
Marvell Avastar 88W8897 802.11ac,NFC及蓝牙主控
Nuvoton NPCT650SBBWX TPM芯片
Winbond W25Q128FV128M-bit 的串行闪存
Monolithic Power Systems MPS1708 和MPSG53
What is the Winbond W25Q128FV for?
Most likely for UEFI
The i5 256 GB model uses Toshiba chips and the model number is KBG30ZPZ256G
Is there any chance that the Marvell Avastar chip can be replaced on the board? Mine just failed on me. No problem soldering, just can’t find anywhere It’s even possible.
I have microsoft surface pro 5 stick on starting on the windows logo.
Microsoft team tries to do everything would not help.
And they would not let me what is wrong with it ?
Just they said i have to swap it and pay 800 dollars.
Would be able to help and let me know how can i do replace the motherboard or the part is failed?
My Pro-5 face some UEFI issue and tried recover also cannot detect my onboard SSD. Send to repair shop, was told one of the memory chip on motherboard faulty and this chip also link to on board SSD. They also told me In most case when replace this memory chip (not sure is it the Winbond W25Q128FV 128M-bit Serial Flash Memory that I read earlier comment could be relate to UEFI) there high chance my on board SSD also need to be replace…. anyone know if this is true? Pro-5 seem like bad design…..
Is there an option to replace only the Bluetooth chip?
如果要说我们从之前的Surface Pro拆解中学到了什么,那就是移除电池是一个痛苦的过程,而且没有办法让其完美回归原样。
所以,这次我们打算就让它粘着好了……
这块四芯锂聚合物电池组总共拥有45Wh(7.57V x 5940mAh)的容量。比上一代产品的电池容量增加了近18%(电芯数量是上一代的两倍)。
拿苹果和
苹果Surface产品相比的话,我们上周拆解的10.5英寸 iPad Pro则拥有30.8Wh的电池。
这是全家福!
总而言之,它与它的前辈几乎完全相同——除开抛弃了 唯一可升级的组件,模块化固态硬盘。没错,微软让给我们留下了深刻的印象——是不好的那种印象。
若要查看更多的拆解文章,欢迎访问我们的Surface Laptop 拆解!
这些型号之间并没有太多区别,只是热管下方的那个迷之空间确实是用来安装风扇以增强散热能力的。
由衷感谢以下译者:
62%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
33条评论
You forgot to document the micro SD card reader controller and a few other less notable members of the entourage of chips. Is it still the Realtek one, the RTS5304, from the Surface Pro 4? I am curious as to if they improved that aspect at all as well.
it should be Realtek RTS5343
JJ Wu -
Can I use surface pro 4 screen replacement on the new surface pro 5/2017?
Bump Looking for the same answer
Arkrus K -
Also looking for the same answer BUMP
Looking for the answer as well, anyone figured it out yet?
coachman -
Unfortunately the connector plugs are different and the cables go in different areas.
Ben -
Can someone confirm this? I have a SP4 screen that I’m not using, and from the pictures, the SP4 and SP5 screens look very much alike. I have the connections from the SP5 as well as the controller board… would prefer not to have to spend another $240 for an SP5 screen.
Where are the display connectors located? I want to open the whole thing without breaking any cables.
Check step 3 of this guide: Microsoft Surface Pro 5 Screen Replacement
Ben -
I read the adhesive used for the screen on the Surface Pro 5 is made of foam? Does anybody know what kind of adhesvie that is and where to buy? Peter
Hi Peter! I’m not sure of exactly what adhesive Microsoft used, but it is some type of foam adhesive. I’ve found that Tesa tape makes a good substitute in most repairs, although it will be harder to cut than foam adhesive if you need to open the Surface again later.
Under the screen, next to the front-facing camera to the left, is a small clear plastic piece…cylindrical in shape. It almost looks like a lens that is not attached to either the screen or the internal boards. Does anyone know what this small piece is? It has come up missing in a screen replacement on my Surface and I need to replace it.
I think that’s a diffusing lens for the IR emitter. I don’t have any great ideas about how to find the part, you might try posting in our Answer forum. Best of luck!
Can I pull the data from the ssd drive ??
Is the SP5 WiFi antenna piece the same as the SP4?
I buy SP4 last year 16.5.2018..im not use everyday..after 1 year i use surface pro 4 show for update..then after update around 1 week i use my surface pro shaking..can u tell me what can i do to fix this problem
I just bought the tablet today and the best buy bag is crap it just tore and the tablet fell. So now the surface is chipped at the top right corner. Is that
Thanks for the great teardown again guys!
Does anyone know if i could remove the TPM chip and the computer still work? also, where is it located?
how do u remove the kickstand and re-attach it? the plastic tab for mine has come out completely so that i can see the black U that i think usually is under the tablet but not 100% and dont want to damage it.
Good day, i would like to find out if the Surface Pro 2017 Core i5 is SSD upgradable?
Sakhile SK - 回复
My SSD is basically dead, for reasons unknown Microsoft decides to soldered the SSD, is there any walk-around or fix for this, short on cash, don't wanna purchase another SP.
I am repairing a friend's surface pro 5 and need to find the bios/uefi battery… she doesn't remember the uefi password and is locked out. can you help?
Is there a second bios chip?
I have replaced the winbond w25q128fvpq to fix non working touchscreen but it’s not fixed it
any ideas
I also have a surface with non working touch. What surface pro 5 model do you have? I found that only the i5 version has a screw that rubs against the touch ribbon cable and has worn a hole to the copper in it in my surface pro.
jq910 -
How does the keyboard connector work internally? Does it end in a USB style connection onto the MOBO?
RAM BUILT IN
SSD BUILT IN
That info should be included in description. It is EXTREMELY IMPORTANT to state, Surface Pro (5) is NOT upgradable.
Gregory F. - 回复
