简介
如果您的尼克松手表需要换电池了,那么这篇指南将教您如何进行更换,并且它只适合于尼克松手表。更换电池不需要特别专业的知识,只需要一盏明亮的灯和一块平整的地方来摆放细小的螺丝。
你所需要的
您已经顺利的完成了腕表电池的更换。
如果你发现秒针没有开始走动,一般可能有2个原因。一个可能是在第11到12步调整时间之后,没有正确的放置表冠。还有一种可能是你换了一块坏的电池,如果是这样的话,你需要重复所有的步骤,重新更换一块新的电池。
如果问题依旧,请联系厂家作进一步的处理。
您已经顺利的完成了腕表电池的更换。
20等其他人完成本指南。
由衷感谢以下译者:
100%
周成波正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
12条评论
Works for also for my traser h3. Thank you!
Good guide but one does not need to force out battery with a screwdriver. This is overkill. I would not recommend putting a screwdriver there because the gears are exposed in that area and a slip would damage them. Just a finger nail is needed to move a little spring cover slightly to let battery out. Same goes for putting battery back in. Fingers are all that are needed at that point.
I have a "Newton" model Nixon. All black and the watch hands are floating circles just to clarify. It seems to have a battery cover, almost like a strip, holding it in place. Is there a tutorial for this extra step?
Hey Anthony! were you able to find an answer to your question? I’m also looking to replace my Newton’s battery.
Yash K -
That is for the backlight module. It takes a 2016 battery. The battery seen in this tutorial powers the movement and sits underneath the backlight module.
Thankyou! Worked perfect for my Nixon “Small Player" watch! This was very helpful!
How do i set the time on my the pirouette watch the hanfs just keep turning and wont stop
Linne Cobb - 回复
I have a Nixon yes rocker what size of battery is for the watch it came without one I bought it in another and cant take it back
I meant another country
can you guys help me with my nixon rerun batttery replacement
Is there a tutorial on how to replace the Nixon Re Run Watch? Because I can’t for the life open this watch to replace the battery..
