此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
如果你的汽车或卡车车轮上装有防盗螺母(轮毂锁),但手头没有对应的防盗螺母钥匙,可以按照本指南将其移除。
防盗螺母的作用与普通轮毂螺母一样,用于紧固车辆的轮子,但需要使用专用的防盗螺母钥匙才能打开。防盗螺母钥匙丢失的情况很常见。你可以手动移除防盗螺母。
在开始之前,请确保车辆停在平坦的地面上,所有车轮处于水平位置。同时,确保已拉起手刹(驻车制动)。
你所需要的
9等其他人完成本指南。
5指南评论
Hi, I have a 05 dodge dakota that has 4- 8 spline thin wall deep socket lug nuts on them. I have went to every tire/mechanic shop and tool store. I really need to get these off so I can change my breaks!!
If there's anything or any advice you can give on how to get these suckers off, I would greatly appreciate it 🙏🏽
As my husband has been trying for over a week now!!
Those are really tricky to get out, i remember welding on a 17mm nut properly and then using impact to get that out son years ago, last option in usually drilling out the whole stud and socket, both options are really frustrating especially if you have expensive rims. If u can hammer on a socket a impact gun will get that out.
Nirap Singh - 回复 分享
I was skeptical, but this did in fact work on my 2005 Honda CRV spare tire wheel lock. I used a 3/4 inch 12 point socket. Hammered it on and it came off easily. Can't get the wheel lock nut out of the socket, but well worth losing a socket to get off the nut.
Changer de huile de boîte automatique
Adama Mallé - 回复 分享
