简介
当你忘记了手机开机密码、PIN码、解锁图案,如何用索尼电脑端手机助手刷机
索尼电脑端手机助手会在你的手机上安装最新的固件并还原出厂设置。
如果你的设备启动有异常的话你也同样可以用这个方法修复你的手机。
!!!(重要)这项操作会抹掉你手机上的所有个人资料!!!
如果你的设备处于联网状态并登陆了谷歌账号,请参阅此手册:
如何使用 Android 设备管理器远程重置 Android 设备
视频网址:
视频概述
搜索并下载索尼电脑端手机助手(Sony PC Companion)
选择repair my phone / tablet(修复我的手机/平板电脑)选项。这样你就能彻底抹掉你的手机里的所有数据并清除开机密码,PIN码等。如果你的手机的操作系统运行有异常,这同样能给你的手机刷机。
It will not let me does this because I haven’t got the password for my phone so when I go onto the pc companion it says that because my phone is locked I can’t do it I just need to be able to unlock my Xperia M2 help!!
你的电脑必须识别的手机为SOMC闪存设备
如果你的电脑驱动有问题(无法识别你的手机),请在网上搜索"S1Boot Fastboot",并下载驱动。网址在下面:
当你的电脑手机助手完成更新以后,断开手机与电脑的连接并开机
现在你的手机已经还原出厂设置了,将个人资料和密码都抹掉了。
你刷机成功了吗
请订阅我的频道
After repair software does not success and may the device contains modified software that cannot be repaired error code Ue getphoneinforooteddevice UE-2003
BD use this software
如果你要重新组装你的设备,将以上步骤倒着来。
113等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
26条评论
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
really???????
my xperia ( LT22i ) is not listed
handset is stuck in a boot up mode / optimising of application - screen and power on/off have no effect - keeps repeating this process and getting hotter?
since the new android marshmellow tried to download - ???
PC Companion does not acknowledge the connection to the handset - requests to wait until restart complete and/or PCC detects handset - neither happen as stuck in loop - cables are all ok
HELP
Xperia Z
I can't get the three options that come after clicking on the "Support Zone " option, I need help!!!!
thom4jesus - 回复
Sony Xperia Z C0682 is not in the model list. What should I do?
how long does it takes (hrs) on software repair?? any guys.. ^^', tnx alot
I can't download the PC Companion!!!!!!!!!!!!!!!!
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 3hrs. Can I do a factory reset or could my battery die during the process?
I Also did a battery health test and it said the battery is good
Clive Donk - 回复
What to do if the program says you have to unlock the phone, but you dont remember the passcode...?
same man, what you do?
How to recover my sony xperia d2005 after installing software update disconnected? I can open my phone but only dead android can see.
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
I'm having issues with my Xperia z1 battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
The current version of Xperia Companion (v. 1.5.3.0) had 2 errors on my PC (W7 64 SP1):
1) Setup with .DLL problem: I fixed the problem by installing an update for Windows - Windows KB 2533623 (Windows6.1-KB2533623-x64.msu) -, easily found on the Microsot website. After the update, the Companion was installed normally;
2) Several failures when trying to upgrade or repair my smartphone, such as "unexpected error", "login failure", "download failure", etc .: I corrected the problem by uninstalling the "Sony Mobile Update Engine", by Control panel. This software is installed automatically by the Xperia Companion setup. After uninstalling this software, Xperia Companion will no longer display any errors (and will install the Sony Mobile Update Engine again during the operation of your device, this time not causing the error!).
At least for me everything worked this way and, since I did not see this unusual solution on another site, I decided to post it, in case it would be useful to someone else.
Good luck!
please whats the file to format my xperia its too slow and keep reloading over and over again
dear sir/ madam,
on my system, the Sony pc companion is not installing please help me.
hi how are u sir my phone xperia vl is not open password and no reset how can i solve it plz tell me soultion
syed adnan - 回复
Amazing this is so help full thank you so much SP flash
??? if i have Malware on my phone can using this program infect my lap top
