跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论
如何清洁 Nintendo 64 卡带插槽
你所需要的
    1. 如何清洁 Nintendo 64 卡带插槽, 如何清洁 Nintendo 64 卡带插槽: 步骤 1 中的图像 1,1
      • 用手指打开卡槽。用除尘气吹沿着卡带槽的长度方向吹气。
      询问修复机器人
      添加评论
    2. 如何清洁 Nintendo 64 卡带插槽: 步骤 2 中的图像 1,1
      • 用异丙醇润湿棉签。沿着卡带槽的长度方向擦拭。
      添加评论
结论
如果清洁卡带插槽有效,你应该可以插入游戏并正常进行游戏。如果游戏仍然无法正常启动,请检查引脚是否损坏,并确认是否需要清洁卡带。
取消:我没有完成这个指南。
30等其他人完成本指南。
tonymag28
于10/28/09注册
2,309 声望
创作了3篇指南
团队
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G4
7 名成员
创作了60篇指南
14指南评论
Oh, my God! I really didn't think the alcohol thing would work (actually, I thought it was going to scr#w my nintendo), but it did! Thank u so much!
silvestrerenata - 回复 分享
I'm a Iittle skeptic to use rubbing alcohol on my N64 system and games are you 100% sure it works and won't give me any problems downs the road.
James Hernandez - 回复 分享
You should use isopropyl alcohol, it’s 90% alcohol and drys very quickly. I usually dunk a q-tip in, tap it against the bottle to remove any excess, then clean the surface. As long as your not pouring the alcohol directly onto your electronics you’ll be fine.
Adam - 回复 分享
This works because water and other liquids contain minerals that are conductive, thus, by having it on a running electronic device, it will cause a malfunction/short, whatever you call it, HOWEVER, if the device is off, no electricity is flowing, thus the rubbing alcohol does what you want it to, and removes all the dirt and grime preventing your games from playing..
Bloxy - 回复 分享
This was great!
notoriousVKC - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 59
过去 30 天: 256
总计 88,926
