简介
使用新的电池为您的iPhone 6重焕新生 - 整个操作很容易,并且会产生很大的影响! 如果您的电池肿胀,采用正确预防措施 [...]。
本指南指示你卸下前面板组件; 这是为了防止损坏显示屏电缆。 如果你在将电池从iPhone上剥离时小心地支撑显着示屏,则可以跳过显示屏的移除并直接进入电池取出步骤。
为了达到电池的最优性能,在完成本指南后,校准 你新安装的电池容量:不间断充电至100%,保持充电两个小时以上。然后使用iPhone 到没电关机。最后不间断充电到100%。 [...]你也可以使用本指南更换以下部件:[...] * [指南| 29363 |电池连接器支架| stepid = 132619] * [指南| 29363 |前面板组装电缆支架| stepid = 132622] [视频| https://www.youtube.com/watch?v = KtK7b_pqnCU]
卸下电池排线固定架上的两颗十字型螺丝。
一个2.2毫米螺丝
一个3.2毫米螺丝
如果电池仍然粘在后壳上, 请准备一个iOpener或使用吹风机直接加热电池后面的后壳。 应该加热到稍微有点热而无法舒适地触摸的程度。
然后,使用塑料打开工具轻轻提起电池。
或者在机身和电池之间插入一个塑料卡。
相对于牙线,一种更强的替代品是未缠绕的吉他弦,例如 12 弦组中的 0.009 E 弦。
3211等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
399条评论
Is it absolutely necessary to do step 11-15
Or is it possible to lean the front panel up while still connected and only removing the battery screws and the battery
I strongly recommend following ALL of the steps as shown. The cables are extremely fragile and can tear easily. It will only add about 5 minutes or so to the project, but could save hours and dollars. Also, take your time removing the battery adhesive strips. If they break off underneath the battery, they are a bear to get out.
I definitely skipped ahead and left these attached. I just held the screen up and only laid it down to apply the adhesive to the new battery.
leon -
I stuck the screen on to an iPhone box (just like in the photo) and did not have to remove the display cables.
BUT, you need to be very careful -- especially if the white strips break on you. If you need to use the plastic card and/or heat to remove the battery, I recommend disconnecting the display.
Carlos -
