跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何帮任天堂Wii主机更换外壳
你所需要的
  1. 如何帮任天堂Wii主机更换外壳, 面板: 步骤 1 中的图像 1,2 如何帮任天堂Wii主机更换外壳, 面板: 步骤 1 中的图像 2,2
    • 用一个金属小铲子(小撬棍应该也可以)来拆开主机上的螺丝保护盖
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - 回复
    Don’t mistakenly remove the rubber case feet
    Bob Trout - 回复
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - 回复
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - 回复
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - 回复
  2. 如何帮任天堂Wii主机更换外壳: 步骤 2 中的图像 1,1
    • 拆掉这两颗8.3毫米的三角螺丝(注:如果你不明白三角螺丝的含义,你可以参考奔驰车标的样子),它们藏在你刚刚拆下的盖子下面
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - 回复
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - 回复
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - 回复
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - 回复
    How do you make one ? If you don’t have the screwdriver
    Ethan - 回复
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - 回复
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - 回复
  3. 如何帮任天堂Wii主机更换外壳: 步骤 3 中的图像 1,1
    • 拆下靠近手柄连接端口附近的一颗5.9毫米的十字螺丝
  4. 如何帮任天堂Wii主机更换外壳: 步骤 4 中的图像 1,1
    • 用刚才的小铲子移除光驱开口的橡胶垫片(注:在Wii的商标下面)
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - 回复
  5. 如何帮任天堂Wii主机更换外壳: 步骤 5 中的图像 1,1
    • 拆掉一颗5.9毫米的十字螺丝,它在你刚刚拆掉的橡胶垫下面
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - 回复
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - 回复
  6. 如何帮任天堂Wii主机更换外壳: 步骤 6 中的图像 1,2 如何帮任天堂Wii主机更换外壳: 步骤 6 中的图像 2,2
    • 小心的把Wii的面板拉开
    • 用镊子把LED的排线从主板拔出
    • 移开面板
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - 回复
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - 回复
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - 回复
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - 回复
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - 回复
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - 回复
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - 回复
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - 回复
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - 回复
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - 回复
    Needlenose pliers did the trick for us!
    Ron Cormier - 回复
    Needlenose pliers did it for us!
    Ron Cormier - 回复
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - 回复
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - 回复
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - 回复
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - 回复
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    grace nicosin - 回复
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - 回复
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - 回复
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - 回复
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - 回复
  7. 如何帮任天堂Wii主机更换外壳, 外壳: 步骤 7 中的图像 1,3 如何帮任天堂Wii主机更换外壳, 外壳: 步骤 7 中的图像 2,3 如何帮任天堂Wii主机更换外壳, 外壳: 步骤 7 中的图像 3,3
    • 打开手柄连接口保护盖,直到它与本体垂直
    • 把盖子直接向上拉,这样就可以拆下盖子
    • 内存卡保护盖也是这么拆
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - 回复
  8. 如何帮任天堂Wii主机更换外壳: 步骤 8 中的图像 1,2 如何帮任天堂Wii主机更换外壳: 步骤 8 中的图像 2,2
    • 拆掉手柄连接口边沿剩下的两颗4.1毫米十字螺丝
    • 在四个角用手拉保护板,即可拆下
    The 3rd hole is in step 3.
    James middleton - 回复
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - 回复
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. 如何帮任天堂Wii主机更换外壳: 步骤 9 中的图像 1,1
    • 拆掉两颗在手柄接口上5毫米十字螺丝
  10. 如何帮任天堂Wii主机更换外壳: 步骤 10 中的图像 1,1
    • 用一个金属小铲子移开三个螺丝保护盖(图上高光部分)
  11. 如何帮任天堂Wii主机更换外壳: 步骤 11 中的图像 1,1
    • 移开下列螺丝
    • 两颗5毫米十字螺丝(红圈)
    • 一颗8.2毫米三角螺丝(橙圈)
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - 回复
  12. 如何帮任天堂Wii主机更换外壳: 步骤 12 中的图像 1,1
    • 用祖传金属小铲子移开在主机下面的橡胶垫
  13. 如何帮任天堂Wii主机更换外壳: 步骤 13 中的图像 1,1
    • 移开两颗8.2毫米三角螺丝,它们在你拆下的橡胶垫下面
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - 回复
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - 回复
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - 回复
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - 回复
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - 回复
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - 回复
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - 回复
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - 回复
  14. 如何帮任天堂Wii主机更换外壳: 步骤 14 中的图像 1,1
    • 把壳子直接拉开就好啦~~
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - 回复
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - 回复
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - 回复
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - 回复
    This is an awful guide
    Alexander D Schaefer - 回复
结论
要重组设备,请反向做以上步骤
37等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
4条评论
Great guide. I had no problems.
wewomack - 回复
Ugh, I went and purchased an iFixit Essential Electronics Toolkit and the Tri-wing screwdriver is too small! Y000 is what it says on the box, time to return this purchase.
iamstilllaughing - 回复
Unfortunately this guide stops half way through and doesn’t include the other side of the case, which involves quite a few screws as the motherboard is screwed down in quite a few places, and the cpu heatsink has to come up, it’s much more complicated than this.
Lily Larceny - 回复
yes i would love if the poster edited the guide and made it so it could be used as a "reshell" guide because i am considering purchaseing a lower condition wii and reshelling it in another color
Sqwerks -
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 113
过去 30 天: 478
总计 45,147
