简介
iOS 13更新再次给部分 iPhone 用户带来了原彩显示功能消失的问题。不过,已经有人研究出了解决这个问题的新方法。我们将会以 iPhone XS作为例子,一步步向你展示在更换屏幕之后如何恢复原彩显示功能。
你所需要的
视频概述
打开设置>常规>关于,检查手机的软件版本 - iOS 13.2。 点按显示和亮度。 我们可以看到 True Tone(原彩显示)已打开,开关为绿色。
更换新的副厂屏幕
再次打开显示和亮度设置,我们可以看到True Tone(原彩显示)选项已经消失了。
现在让我们使用多功能读码编程器来恢复iphone副厂屏幕的原彩功能
首先,把原装屏幕与编程器上的屏幕接口相连接。
然后我们需要用读码编程器读取原有原装屏幕里的数据。
当你完成这一步后,断开与原装屏幕的链接,把副厂屏幕重新链接在屏幕扩展插口
最后我们需要用编程器的数据写入功能,把原装屏的代码写入副厂屏里。当完成后,断开链接
Bonjour, quels sont les outils / Logiciels complémentaires nécessaires pour cette reprogrammation ? Merci.
找到 设置>一般>关于,查看手机的版本号----IOS13.2。然后点击 显示和亮度。 可以看到这里并没有“原彩”这个选项
使手机与电脑相连,打开WL辅助软件。盖板序号会被自动读取。
断开与电脑的链接并关机。然后取下副厂屏幕。
Cos’è il software di assistenza WL?
Alessandro - 回复
Vorrei saperlo anche io,
Ho provato con 3uTools su un IPHONE 12 ma non lo riesce a leggere
Boncy -
Hakverdi Erdek
让我们一起恢复“原彩”功能,虽然不是原装屏。
把副厂屏幕与多功能编程器的显示延展接口相连接,然后使编程器链接电脑。
在软件的帮助下,我们需要把之前读取的盖板序号写入到副厂屏幕里,这样才能恢复“原彩”功能。
终于可以组装并测试了。安装好副厂屏幕,连接好电池。开机!!
然后 找到“显示与亮度”,恭喜你“原彩”功能被点亮了!那个小开关变绿了!
What’s the name of the machine for restoring true tone
I once did it successfully using better idea‘s clone boy 2.0 with my iphone8.
the replacement screen needs to have an eeprom installed - not every aftermarket screen has one.
I used an original refurbed iPhone8 display successfully.
When the screen broke again a few months later (I have four kids - they trash everything) I again bought a refurbished iPhone Screen and copied the ID from the previous replacement to the new refurb screen. Somehow this did not made True Tone reappear after installation even though I tried it twice.
Just after glueing anything together I found my first original screen in the recycling box. Maybe it would have worked if I copied directly from it but since everything else works fine (approximation sensor e. g.) I decided to store the first screen away and leave the phone as it is.
You can get the clone boy cheap from AliExpress but I saw some other devices which are able to clone the screen ID too. A quick search on the web should reveal something helpful.
vous utilisez l’ecran d’origine pour extraire le mtsn et le copier sur l’écran de remplacement. Pourquoi dire que la procédure se fait sans l’écran d’origine? Ce n’est pas clair. Ce qui est clair, c’est que si vous ne disposez pas de l’écran d’origine, vous ne pouvez pas du tout restaurez True Tone.
26等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
26条评论
Would this work with an original screen on another body?
Really nice fix!
I had installed an original iPhone screen from another body on my iPhoneXS . I used this tool for restoring TrueTone and it worked like a charm!
Hi is there any msg “ iphone canot check your screen”
Can anyone tell me where I you purchase the True Tone multi-functional programmer to do this?
Thanks
If you go to the YouTube video’s page, it’s in the description. It is from this site: https://shop.rewa.tech/
aliexpress is the one option or union something i forgot
Thank you for the link!
Does this also work on iPhone 8 Plus?
Does the iPad Pros have the same issue? If so, will this work? I assume it’s just an EDP protocol.
How I can activate true tone on my X's device, actually I replaced the screen before 3 months
Is there any way to do it by mobile to mobile or with any network?
joymore837 - 回复
I really suggest trying to reach out to the company beforehand. I've been trying to get some help with this device for 2 weeks and they're not responsive. I keep getting an “IIC chip not recognized!” error when trying to use the method without the original screen. Just suggesting to try reaching the company prior to committing. Seems like you'll largely be on your own after purchase.
Nice one, please how do I get the display extended models tools ???
I change my display and fix the original display but true tone is missing I updated my phone 15.4.1 but still true tone missing
If any possibility to fix the problem with out reopening my phone any software available
Should work most probably just with screen. Don't get your hopes high for the face id or touch id though. why would you be replacing the module if it can be read by this module? If the belt is broken then this module aint gonna read the data either, just saying.
Where can I buy the multi function programmer to reprogram the TrueTone?
Anyone had issue when reprogramming original iPhone XS screen damaged somehow touch ic? , touch is unresponsive on my XS but surprisingly it is working fine on iPhone X, I have tried to transfer data with MEGA-IDEA programmer from few different screens but no luck , touch only works on iPhone X but can’t use it on X as frame is different.
visit iphonesringtone.com
Really you have help alot in fixing true tone issue. Thanks Regards! iPhone Ringtone
Can u guys help to restore true tone on my iPhone without original screen
junior jay - 回复
Hi, does anyone know if this will work with used OEM screens? Will it overwrite the previously written data on the screen? Thanks
blitzn - 回复
Depends on the aftermarket screen. Some can only be written once.
bearzac -
Yes I’ve done but still the True Tone is not showing
Yoanne Patrick Koudou - 回复
Doesn’t work without original screen on iOS 16. Anyone know if an update is coming to allow this?
bearzac - 回复
