简介
安装一个修丁版的macOS Mojave,防止你的旧Mac出现问题。
请注意,如果你在你的Mac电脑上安装任何来自苹果的Mojave系统更新,你就会亲手葬送你的Mac,所以请不要从苹果更新系统。你将被系统要求删除你的硬盘分区并重新开始安装。
你所需要的
完成!
180等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
163指南评论
I have a mid 2009 MacBook Pro. I’ve gone through this process. Everything has worked great, till I reboot. It gets most of the way through then it hangs up. I’ve let it set for hours and nothing. You have any suggestions?
jetjock256 - 回复 分享
After initial install, the computer cannot complete reboot without the patch “MacOS Post install” (see step 13 above). This will require a hard shut down (hold down the power button if it is stuck) and restart holding down the alt/option key until you can select the installer again. This time, do not reinstall the OS but click on the button on the side (or double click it), or select in the pull down menu.
This will need to be repeated for updates, if new updates also get stuck.
Hope this helps.
Douglas Lee - 回复 分享
I have a Macbook 2008 with 10.7.5 on it and am being told that is the end of the line. Will this work on my Macbook?
Bill Hines - 回复 分享
