简介
有断掉的项链?因为你不会修理让其一直吃灰尘?使用这个简单的指南来维修链子让项链,再次戴上它!
你所需要的
通过轻轻拉扯两边来测试这个连接。如果散开了,重复第4步和第5步。
Omg! Thank you. Literally I was so sad that my necklace broke cos it was of my favourite band. Thank you
Jewelers newer use the needle nose pliers to fix the chain. Unless to put the needle thru the chain link and push inside to open that chain link. They use any different but not needle nose- to squeeze the links back. Best way- to twist the link by two pliers ( not needle nose!!) put thru the chain link and twist it back.
现在你可以再次炫耀你的项链了!
现在你可以再次炫耀你的项链了!
35等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
12条评论
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
Angela Wei - 回复
My costly gold chain break down...as it is very lin... How can I joint it
I would like to say that my gold chain down due to its thinness...how can I joint this chain
A link broke in my dogs chain collar. I'm using needle nose pliers, but I can't get the two ends of the open link to line up so I can close it!! I've never had this problem before!
This is so hard to do. I can’t even put the links together.
I acsadently broke my necklace
Jayden ayala
I want to say that my gold ring is down due to its thinness... Can you tell me how I can attach this chain?
