简介
长大后,我一直在 Xbox 上玩游戏,我曾用过不同的游戏手柄且遇到过几次摇杆漂移的问题。在玩第一人称和第三人称视频游戏时,这个问题会随着时间的推移而变得非常恼人。当我玩电子游戏时,我想以最佳姿态迎战,但摇杆漂移的问题让我无法发挥。有过这些经历,我决定创建本指南来帮助遇到同样问题的其他人。当你没碰游戏手柄,而你的角色却在自己移动或四处张望时,你就知道手柄出现漂移的故障了。解决问题并不需要很长时间,您只需要两件物品,一瓶 70% 异丙醇医用酒精和 3 到 4 个棉球。如果控制器上的模拟摇杆已经分崩离析且坏得一塌糊涂,那就干脆换一个新的吧。
你所需要的
修复控制器后,如果将来问题再次出现,则重复相同的过程使其再次正常工作。
5等其他人完成本指南。
由衷感谢以下译者:
87%
Peter Xu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Personally wouldn't recommend using hand sanitizer. IPA of various concentrations is already cheap and readily available in every pharmacy section, or a can of WD-40 Specialist Contact Cleaner is also around $5. In theory, hand sanitizer would "work" if it's ethanol/isopropyl alcohol based, but there's such a broad range of hand sanitizers, it would be irresponsible to make a blanket statement that they're all safe/unsafe for electronics. For example, many brands include fragrances, moisturizers, vitamin-E, etc. to keep your hands from excessively drying out, which can end up leaving residue and gumming up your electronics' contacts further.
I had actually been dumb enough not to look this up, so I just replaced the thumb sticks and it had made it better, but it didn't fix it. Any recommendations? I've had the controller since around 2016 or 2017. Original controller that came with the xbox.
The original Xbox one controller is notorious for getting stick drift. Only way to fix that one is the re-Solder the thumb stick back on. Like remove it and re-solder it.
THANK YOU!!!! Bruh….thank you.
