简介
你有一双鞋子还是一双鞋底上有洞的鞋子? 通过本指南,您将能够修复这个洞并重新使用鞋子,不用重新买一双
你所需要的
使用120目砂纸磨擦外底表面把shoe goo 胶部分打磨光滑。
Quella del ghiaccio per spargere la colla e un idea superlativa
Spargere la colla per scarpe con un cubetto di ghiaccio mi sembra un'idea fuori dall'ordinario
You can use some other kind of sole glue too to fix holes or even reconstruct parts of a sole.
They are available in different, common sole colors. With a little experience and patience, the sole can look like new again.
The advice with the tape protection from the inside and the ice cube are very useful! -
现在你又可以出门走走咯!
现在你又可以出门走走咯!
30等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
Excellent - thank you
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
blackwidow - 回复
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
Why dont you just buy Shoe sole replacement on amazon or walmart and use the shoe goo the way it was meant and glue the New sole (or just a piece or part, they do sell half sole replacements as well all in various thickness, size, and style) to the shoe over the damage? Shoe goo is meant to bond 2 things together not fill holes..
Kristina M - 回复
I didnt quite get to doug before I made a whole account to rant a bit in a comment.
Smart
Kristina M - 回复
Clean the hole with paper towel sb clean the hole with chemical cleaner and rag. The material must be prep for the shoe goo to stay and not peel off after a few uses. Sanding will help too as will applying glue past the hole onto a crease or tread pattern as Doug mentioned. Some goo inside the hole is OK as it helps hold in the patch just flatten it so there is no lump inside
Thanks muchly.
