简介
玩 Nintendo Switch 时,每个按钮都有特定的用途。如果这些按钮中的任何一个被卡住,它会导致您的游戏体验不完整。这可能会变得非常烦人和不方便,但很快就可以解决。只需要一把螺丝刀和一把镊子,可以解决卡住的按钮问题。此修复指南将提供有关如何快速修复 Nintendo Switch 手柄上卡住的 ZR 和 ZL 按钮的分步说明。这些按钮位于手柄上的右侧和左侧。因为经常使用,所以随着时间的推移,它们往往会卡住和磨损。
使用时用力过猛会导致它们卡住并且无法修复,给我们带来麻烦。为了修复这些卡住的 ZR 和 ZL 按钮,我们将跟从以下 7 个简单的步骤
你所需要的
完成这 7 个步骤后,您的游戏体验应该会恢复到原来的状态。如果另一个 Joy-Con 也有卡住的 ZL 或 ZR 按钮,只需重复上述 7 个步骤即可。
15等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
My button problem is the actual button on the flexible circuit board. Where can I get a replacement. It simply unplugs from the main board
Hi @gregory53491, I'm not sure what button you are referring to, but here is a link to our parts store with all of the parts we currently have in stock for the Switch JoyCon. If none of the parts we have currently are what you need, you might try checking eBay for used parts. I hope this helps!
Sarah,
The button I was looking for looking for is the ZL button, and I found one on Amazon. I needed the actual on/off smd button. The one one the flexible board. When it comes in I'll give a try at writing a how-to. 👍
Hi Gregory! Thanks for the update. I'm glad you found what you needed to complete the repair :)
