简介
这一步看上去可能很容易,但如果你没有事先搞清楚的话,会变得有些困难。请参考本指南以及影片。
相较于之前历代Mac键盘,包括使用AA电池的上一代无线键盘,这款键盘键帽安装更加困难。
你所需要的
视频概述
分辨空格键键帽的上方以及下方。
键帽的底部(靠近键盘外壳边缘的一侧)有两个塑料槽口,分别在左右两侧。这两个槽口将会扣在空格键两个剪刀式结构下方的小孔(图中指出的位置)中。
从一角稍微撬起键帽的底部,不要断开剪刀式结构与键帽之间的卡扣连接。
将下方支架从缝隙中插入键帽下方,微调到位。
沿键帽底部轻微按压。不要像旧款Mac键盘维修影片一样用力按压。
如要组装你的设备,请按本指南反向顺序操作。
18等其他人完成本指南。
由衷感谢以下译者:
100%
Ennis正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
28指南评论
Great tutorial, thanks a lot!
However I found it easier to attach the metal bracket to the holding clips and just popping the key back on top of it.
Same as Xavier. First both metal brackets in the keyboard in place and then gently pushing the spacebar down on them. The key got stuck in its lower position at first, but after pulling it up, it works like a charm.
Thanks for saying I had to pull it up a little.
Thanks! I spilled beer on my Enter and Caps Lock keys—two of the most complex :(
Your advice helped me for Caps Lock.
The Enter key is different.
For an Enter key, you need to remove the butterfly hinges and attach them to the key cap first. Then add the metal bar, then slide the butterfly hinges back into place. The other edge of the hinge and the metal bar then click back into place when you press down.
This is because under the Enter key there are two hinges that are not aligned, so you can’t slide the key in — whichever way I tried, I only ever caught one hinge and not the other.
By removing them from the keyboard you can check they are properly in their slots on the key cap. You need to look carefully at how they attach to the keyboard, so you can slide them back in later.
I really don’t recommend this repair for the Enter key unless you are really, really precise and have a real eye for detail and a magnifier. Trickiest is getting a <1mm piece of nylon into a <1mm piece of plastic.
Amazing design.
ElectricFeet - 回复 分享
This is awesome and helped a lot — once I realized that Apple reversed the scissors on my space grey magic keyboard, so up is down and down is up. So if you are following this guide, fine the little square notches on the scissor and that side is “bottom”. In my case that was actually towards the top of the keyboard.
