跳转到主内容
加入维修社区 - 创建账户
去除老化的类肤质涂层
你所需要的
  1. 去除老化的类肤质涂层, 使用异丙醇酒精清洁: 步骤 1 中的图像 1,3 去除老化的类肤质涂层, 使用异丙醇酒精清洁: 步骤 1 中的图像 2,3 去除老化的类肤质涂层, 使用异丙醇酒精清洁: 步骤 1 中的图像 3,3
    • 将少量异丙醇酒精涂抹在黏腻的涂层表面
    • 等待几秒使其溶解
    • 用力擦拭,直到剩下光亮的塑料表面
结论
根据您的喜好,可以用涂层或乙烯基包裹闪亮的塑料。一些想法包括橡胶漆 (plastidip) 或植绒。
6等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Metals
于09/10/22注册
253 声望
撰写一个指南
2指南评论
Isopropanol is commonly called isopropyl alcohol. It's found in pharmacies as "rubbing alcohol". Also sold in most hardware stores. Typically sold in strengths of 70% or 91%. The rest is water.
Isopropyl alcohol evaporates fairly quickly. The higher percentage of alcohol the faster the mixture will evaporate.
To deal with the evaporation, either work on a small area at a time, or wet the sticky part and wrap it in plastic wrap to allow the isopropyl alcohol to work for a time. Use a bit of paper towel to hold the alcohol where you want it.
You may want something to scrape off the goo rather than just trying to rub it off. iFixit has a soft plastic "iFixit Opening Tool" which will work, and may be safer for the underlying plastic than, say, a plastic paint scraper. The link has others options too, like the Spudger and Opening Picks.
Prying and Opening Tools
Get some "Goop" or other hand cleaner too. (Goop might also help remove the sticky paint. Haven't yet tried that.)
Winston - 回复 分享
Ich habe die Erfahrung gemacht, dass Dimethylsulfoxid DMSO eine viel bessere Wirkung hat. Dieses Lösungsmittel wird oft auch als Heiltropfen verkauft. Es ist ratsam diese Substanz mit Handschuhen aufzutragen da es im wahrsten Sinn durch die Haut geht.
https://de.wikipedia.org/wiki/Dimethylsu....
Brudix - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 231
过去 30 天: 774
总计 25,373
