跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
初代iPhone电池更换
你所需要的
  1. 初代iPhone电池更换, SIM卡: 步骤 1 中的图像 1,1
    • 在耳机孔旁的孔中插入SIM卡工具或扳直的回形针。
    • 向下压SIM卡工具或扳直的回形针,直到SIM卡托盘弹出。
    To remove the SIM, insert the end of a SIM eject tool or a small thin paper clip into the hole on the SIM tray. Press firmly and push the tool straight in until the tray pops out.
    http://support.apple.com/kb/ht1438
    neuronetix - 回复
    I put the SIM card back in, and the slide to unlock does not work.
    dean -
    The only carrier to accept this iPhone was AT&T, they have discontinued use of that baseband. Nobody else in the world except for early renegade reverse engineers such as Geohot can get the device to work as a really old iPod no use unlocking the device because the technology inside the most recently OEM sold/refurbed iPhone 1st gen fails universally. You should only buy a screen assembly and snap it onto the back and call it a dummy phone and put it in a museum.
    Alexander Weinhart - 回复
  2. 初代iPhone电池更换: 步骤 2 中的图像 1,1
    • 抓住SIM卡托盘并将其拉出iPhone。
  3. 初代iPhone电池更换, 天线盖: 步骤 3 中的图像 1,1
    • 此图显示了位于天线盖底侧的两个卡舌和两个卡扣。必须将图像顶部的两个选项卡推向黑色盖板以将其打开。
    YOU NEED TO PUT THE OPENER TOOL BETWEEN THE ANTENNA COVER AND THE DOCK CONNECTOR FIRST, THEN YOU WILL HAVE SPACE TO OPEN IT.. MY 2 CENTS
    riversde - 回复
    You better lay off the caps.
    lol SPLAAT -
    Very hard to remove and the plastic is very fragile
    Take care when removing
    miguelvillela - 回复
    When you get stuck follow this guy guide
    http://www.youtube.com/watch?v=sYHnr89HM...
    miguelb - 回复
    Great Guide.
    My dad banged his iPhone in a table after arguing with someone and got the aluminum cover next to the volume control bent in such a way as it got the volume control stuck in the max position. I used this guide to remove all parts out of the way so I can get the shape of that region and corrected it the "Han Solo" Way. It was an excellent opportunity to get the phone cleaned up as well
    The biggest problem I had was screwing some of the screws back. The screwdriver that I had was not magnetized, so I used a little bit of superglue to bind the screw and the screwdriver until I had it screwed tightly.
    The second biggest problem I had was that I lost a screw twice, but was lucky enough to find it quickly on the floor next to me.
    I am very happy as I waited more than a month to get the confidence to get this iPhone repaired.
    lantinian - 回复
    how do i know what part is in my phone? There are 2...
    Ivanfrost - 回复
    来自 Ivanfrost 的话:
    Once you have the phone apart and have gently unplugged the power ribbon, read the part number on the ribbon. If it's in the 821- family, you can safely use corresponding 821 headphone assembly. If it is the other part number, use the newer replacement. Many sites list both parts and let you order the appropriately numbered part. Otherwise (if you order the wrong part) it won't work or you'll have to [unnecessarily] hack the part to get it to work.
    Steve - 回复
    来自 Steve 的话:
    I bought the wrong one.... how do I hack it?
    Rune Smistad - 回复
    My iPhone is very first model. It doesn't have any of the four tabs shown.
    gameplayer2 - 回复
    The very first model does not have the four tabs. To open this version, use a plastic opener tool and push it into the middle of the tiny space between the rectangular dock connector and the antenna cover. Move the tool to the side and push it in a little deeper. A small gap should open up at the bottom of the antenna cover, where it meets the metal. Continue using the plastic opener tool in there, pushing it in and forcing it around the edge so that the antenna cover further separates. Then repeat this on the other side. To me it seems like a very brittle piece of plastic, so be careful. But now that it's loose at the bottom you can lift it with your fingers and work it off.
    Alexander Ljungberg - 回复
  4. 初代iPhone电池更换: 步骤 4 中的图像 1,1
    • 确保将金属撬棒插入扩展坞连接器和天线盖之间,不要插入扩展坞连接器里面。
    • 将金属撬棒插入扩展坞连接器和天线盖之间的插槽中。在两个卡舌附近轻轻撬起,以在天线盖和银色前挡板之间形成一个小间隙。
    Take heed to the note about getting the spudger between the dock connector and the cover. The dock connector is black plastic, as is the antenna cover, so it's difficult to see any gap between them. Putting the spudger between the metal shielding of the connector and the plastic is incorrect.
    Michael Lance - 回复
    Rens' duct tape technique (see comment in step 6 section below) worked very well. No need to risk breaking the antenna with a spudger.
    jbshoe - 回复
  5. 初代iPhone电池更换: 步骤 5 中的图像 1,1
    • 将塑料撬棒插入天线盖和前挡板之间的间隙。撬棒的楔子应指向天线盖。沿拐角处向上并向上滑动工具,直至到达金属底衬。
    • 在另一侧重复相同的步骤。
  6. 初代iPhone电池更换: 步骤 6 中的图像 1,1
    • 抓住任一侧的天线盖,将其向上滑动并与iPhone分开。这需要一些力量。如果无法松开,请确保将天线盖提起至足以松开卡扣。
    It was released very hard on my iPhone 2G but the problem comes when i have to put it back.
    It remains a little more space between the dock and the Antena cover and maybe that's because the two tabs between the mic and the speaker are not entered under the gold board?
    If someone knows please tell me how to put it back.
    Thanks
    infomihai - 回复
    There is a very easy way to remove the cover by simply sticking duct tape on it and pulling the tape away of the phone.
    It will leave no marks and it didn't damage my antenna cover as much(my "chinese" repair tools were to weak).
    rens - 回复
    Thanks, using the tape was quick and easy, no damage at all.
    Roeland -
    Brilliant. Works perfectly. 20 seconds of work.
    koenatclaes -
  7. 初代iPhone电池更换, 后壳: 步骤 7 中的图像 1,1
    • 拧下将后面板固定在iPhone上的三颗#00十字螺钉。
  8. 初代iPhone电池更换: 步骤 8 中的图像 1,1
    • 打开iPhone的后壳是一项艰巨的任务,因此要有耐心。 深吸一口气,并确保您有足够的时间完成工作。
    • 黄色小方孔是在下一步将要插入牙签的位置。
    Be sure to use the square hole, more to the inside, not the one between the outer shell and the little piece of metal. The Outer shell is attached to the metal.
    Gyuri Ordody - 回复
    You guys show this is vanilla dessert. And it's more difficult than building a DIY space shuttle. I wonder why Apple did the iPhone so problematic to disassemble. It's just the battery!
    Sebastian Di Mateo - 回复
    I've seen some instructions recommending using a knife to open up a space between the back cover and trim. Using the dental pick as shown here, it is very easy to break off the screw attachment near the edge of the cover.
    Bill Parquet - 回复
    Agree with Bill, I did break off one of the screw attachments. In retrospect, using a small putty knife between the cover and battery (which I'm replacing anyways) to apply force against the cover while prying at the hole would have helped.
    Michael Lance -
  9. 初代iPhone电池更换: 步骤 9 中的图像 1,1
    • 使用牙签卸下侧面的后面板。
    • 将牙签完全滑入方孔中。 您可能需要扭动牙签并施加大量力才能完成这一步。
  10. 初代iPhone电池更换: 步骤 10 中的图像 1,1
    • 逆时针快速拉动牙签撬起后面板。 垂直于显示器组合件的平面施加力。 您可能会害怕动作过快或者用力过大可能损坏设备,但动得过慢可能会使外壳弯曲。
    ugh. i totally mangled my case. snapped off the 2 outer screw brackets... broke my dental pick, too. and my small screwdriver. thank goodness for craftsman tools! ;)
    i was pretty disheartened by the whole thing, but i keep it in a hard shell anyway so it's not that noticeable.
    umopapisdn - 回复
    Like others - this is where I am stuck. No dental pick, so I search for alternatives. Good the get reminded - if I mangle the case too, hey, my speck cover will hide the scars!
    Spikey2 - 回复
    What material is that dental pick made of? Adamantium?
    I could NOT get this method to work. I tried three different picks and all bent when I tried to lever them this way. I did break one of the frame screws off in the process as well. I ended up going back to my old standby... The Exacto Knife and a 1/8 inch flat head screw driver... I used the exacto to get the flat head started, then worked my way up one side toward the top of the phone slowly and carefully wiggling the screw driver until it popped open on that side. Then I did the same to the other. That worked well for me. These plastic openers and dental picks just bent and broke on me. GOOD LUCK. My Advice: Get a 3G or 3GS, I can break one down in under a minute!
    Adam Susong - 回复
    I didn't have a dental pick. I used a narrow, flexible hobby putty knife. The button side edge popped right off. The blank side required me to slowly wiggle along, continually pushing the putty knife up to 2" to detach each of the clips.
    dennishodge - 回复
    I can’t get past here… I ruined 3 screwdrivers trying to do this, but failed
    Nick75704 - 回复
  11. 初代iPhone电池更换: 步骤 11 中的图像 1,1
    • 使用塑料撬棒从iPhone的角落和顶部撬起后壳。
  12. 初代iPhone电池更换: 步骤 12 中的图像 1,1
    • 在iPhone的另一侧重复相同的步骤。 将牙签完全滑入方孔中。 您可能需要扭动该工具并施加大量力才能完成此步骤。
    wich dental pick should I use? I´d bought some but they twist or didn´t fit on the scare... thx in advance and really good guide!!
    Chad720 - 回复
    I know this is old, but I've had some success. Rather than the dental pick, which I bent too, I ground down a very small "L" bend hex wrench. Worked like a champ. Also: If you have an iPhone 4 and are looking to use the microSIM in your 1st gen iPhone with the use of a microSIM adaptor... DO NOT put the empty adaptor in the SIM slot. That's what I did and had to dismantle the phone to get it repair the SIM contacts.
    tthomashardie -
    Actually, the "button" side released fairly easily and I was able to loosen the top end with a plastic spudger. However, the remaining side was a @#!@! and the process of popping it off caused the protruding screw lug to break off the internal guide, which itself came off seconds later. Oof! While the side guide was easily glued back in, the lug ultimately became a casualty since it was too small and unweildy to SuperGlue™ back on. But, as Meat Loaf wisely sings, "two out of three ain't bad." The 'phone can live w/o one screw and possibly two if the center lug remains.
    turkeyneck - 回复
    I didn't have a dental pick so i used a very small high quality allen key which worked perfectly. The back cover is interference fit to the front bezel and i found with the correct lever action it separated easily.
    Bigkarkus - 回复
  13. 初代iPhone电池更换: 步骤 13 中的图像 1,1
    • 顺时针方向快速拉动牙签,撬起后面板。向着垂直于显示器组件的方向施加力。 您可能会害怕动作过快,但走得更慢可能会使后壳弯曲。
    • 后壳上的耳机插孔电缆连接在iPhone主板上,因此暂时不要完全从iPhone上卸下后壳。
    I've seen some guides that recommend a technique for prying up on the center of the case. if you do so, it is easy to accidentally damage the battery if you pry in the wrong direction.
    Bill Parquet - 回复
  14. 初代iPhone电池更换: 步骤 14 中的图像 1,1
    • 断开耳机插孔电缆之前,请确保手机已关闭。
    • 使用塑料撬棒从主板上断开耳机插孔电缆。
    You need to stick the end in, and it detaches if you push it upwards.
    Gyuri Ordody - 回复
    A picture of what the dental pick is poking at would be useful inside the back case. If you get on the wrong side of the frame rail you can break the ear where the screw goes pretty easily with that pick (yes it appears to be titanium). Guess that is why only the plastic pick was part of the toolset, but used a metal one as depicted and ran into this. As you say this is challenging, and more pictures are better.
    edl - 回复
  15. 初代iPhone电池更换, 电池: 步骤 15 中的图像 1,1
    • 使用撬棒的尖端去除覆盖电池触点的白色胶水。
    • 为了减少将红色电池导线短路至金属护罩的风险,您可以先将黑色和白色电池导线上的胶水取出。拆除黑色和白色导线后,取下胶水并拆下红色导线。
    they seem to use lead-free solder in the original construction process. goody for the environment, but it made it really hard to get the original battery loose. i added a little bit of regular solder to what was already there and then was able to wick away the original.
    umopapisdn - 回复
  16. 初代iPhone电池更换: 步骤 16 中的图像 1,1
    • 从电池连接器对面的边缘开始,在电池和塑料框架之间插入撬棒并撬起。电池用粘合剂粘在外壳上,但应被慢慢撬起。
    Beware not to apply to much force on the battery !! In my case it broke and started to smoke ... surely not to healthy..
    Furthermore be aware that below the battery there is a flex cable which is easily destroyed.
    Dominik - 回复
    What work for me very well was to leave the original wires at the pads on the system board, cut them at an appropriate length and soldered the new battery to them. Of course you have to insultate them with tape or glue. There is enough space and you avoid any risk of messing up the system board.
    danielfca - 回复
    Dito. Cut the wires and spliced with the new battery wires. Had to peal away some of the white tape on the new battery to get enough wire to work with. Used some of the kapton tape from the old battery to insulate the splices (electrical tape too thick).
    Michael Lance -
  17. 初代iPhone电池更换: 步骤 17 中的图像 1,1
    • 如果你以前从未接触过焊接,我们有一个指南,使其更容易于操作。我们建议在继续之前清洁烙铁。
    • 我们现在准备开始焊接过程。你需要一个烙铁,焊锡和去锡条。如果你还没有他们,你应该可以在当地的五金店找到这些物品。
    • 将少量焊锡熔在烙铁头上,然后用潮湿的海绵擦拭烙铁头,清洁烙铁。
  18. 初代iPhone电池更换: 步骤 18 中的图像 1,1
    • 将去锡条放在现有焊点的上方。
    • 将烙铁放在焊点上方去锡条的上方。
    • 固定烙铁并加热,直到主板上的焊料融入去锡条中。
    • 对其余两个焊点重复相同的步骤。
    • 将旧电池从iPhone中取出。在将电线从电路板上拉开之前,确保所有的焊料都已被除去。电线应该是松动的,移除电线时几乎没有阻力。
    It is probably much easier to remove the solder with the wick, so be sure to get some. I did it without and it took forever.
    Gyuri Ordody - 回复
    when you preform this step de-solder the black wire first then the white and then the Red, do not de-solder the red first or it may short the device out
    Chris - 回复
    Using the desoldering wick is a good idea. I thought I could heat up the existing solder and pull the wire out but it is very easy to rip off the solder pad if you get the connection too hot.
    Bill Parquet - 回复
    much better to detach the 3 cables (white, red and black) from the battery rather than from the chassis.
    Andrea perinti - 回复
    If you’re replacing the battery anyway, it’s far easier to cut the wires to the battery first. Then you don’t need to worry about which one to desolder first etc.
    Bigphilly71 - 回复
  19. 初代iPhone电池更换: 步骤 19 中的图像 1,1
    • 我们建议您用软布或海绵和少量擦酒精清洁电路板的表面和焊点。
    • 将烙铁放在主板的连接器上,然后将焊锡条压在烙铁尖头和电路板上,将小焊珠直接熔到电路板上的连接器上。
    • 如足够少量焊料已熔到电路板上,先将焊料提起,再移走烙铁。
    It's very important to clean and prep the terminals before attaching the new leads. Get rid of as much glue as possible and any stray solder that might be left from the un-soldering process. Make sure all three terminals are electrically isolated from their neighbors! Like the instructions tell you, leave no more than a nice little pinhead-sized dome of shiny solder on each terminal and no 'cold' solder connections, which have the characteristic DULL GRAY lustre. If you must--do them over or risk having to pop the dang thing open all over again!
    turkeyneck - 回复
    What do I do if the red connector to the mother board comes off? Is there any other point I could solder to?
    mortenskogly - 回复
  20. 初代iPhone电池更换: 步骤 20 中的图像 1,1
    • 焊珠应该呈一个丘形或半球形。如果它是扁平的或呈锯齿状,需将烙铁放回焊点上重新熔化焊锡,然后将烙铁向正上方拉开。如果这不起作用,可能需要重复步骤五。
    If you accidentally ruin the negative (the black wire) soldering bead like I did. Then the big metal plate is an alternative for a negative connection. Just solder it directly onto this plate and it should work perfectly.
    XereX - 回复
    来自 XereX 的话:
    Um.. im not sure if exactly this happened to me... so the small squre piece came off with the black wire :( where should I solder it now? On that black little spot or somewhere else? Thanks for any help!
    ascent - 回复
  21. 初代iPhone电池更换: 步骤 21 中的图像 1,1
    • 先焊接红色导线,再焊接白色导线,最后焊接黑色导线。
    • 将新电池的电线放在新的焊点上。
    • 将烙铁尖端压到焊点及电线上,直至其融化。
    • 将电线滑入融化的液态焊锡中,直至其位于焊点的中心,然后移走烙铁。
    • 以同样的方式连接剩下的两根电线,特别注意不要让锡球连接主板上相邻的的连接器。
    Try to experiment with the temperature of the soldering iron if you can adjust it. If it's too hot for the solder you have, it'll melt it away in a small, spectacular boil and evaporation sequence.
    Gyuri Ordody - 回复
    When you get the battery and get it ready for installation leave the red wire in the heat shrink plastic wrap until you solder it to the board, and here's a tip... when you go to solder the battery to the board solder the black wire first and then the White but leave the plastic wrap on the red wire on until last... when you start soldering do it in this order and it will limit the chance of shorting out the device (black, white, red)
    Chris - 回复
    But I have a replacement battery with a yellow instead of the white
    raf -
    But mine has a yellow wire instead of a white
    raf -
    Hi Chris, do you know anything about the question I asked in Step 20? I tore off a little square piece where the black wire was soldered. Should I try soldering it on the same spot or I should put it somewhere else? Thanks!
    ascent - 回复
    来自 ascent 的话:
    I have the same problem, but a litle different, tore off the little square where the white wire was soldered. Same question, should I try to solder on the same spot, or somewhere else ?
    artur - 回复
    Hmm.. I would really appreciate some comments from people who know a little bit more than me :( please help!
    ascent - 回复
    来自 ascent 的话:
    You should be able to solder to either the big metal shield there or GENTLY (VERY GENTLY) remove a bit of the PCB top where the pad was to reveal the copper below it. I stress GENTLY, like barely scraping a razor over it with no pressure. If you do it too aggressively you'll go through the layer.
    shawncl - 回复
    First of all: thanks for the fantastic manual! I successfully fixed a broken solder bead, but due to a very raw, non-precise soldering iron, the solder bead of the black connection also touches the silvery metal plate (the one that can be seen in the top part of the step 20 image).
    Any problem with that? It is working fine for one day now.
    Flo - 回复
    wow, I just saw, that "ascent" used the same procedure to fix the black connection.
    @ascent: is your phone still OK? not broken due to excessive heat or something like that?
    Thanks and good luck!
    Flo - 回复
结论
请按逆序重组你的设备。
145等其他人完成本指南。
由衷感谢以下译者:
en zh
90%
王乐天正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2条评论
Where can I source an iPhone 2g battery in 2018?
Adrian Ledesma - 回复
Click on the button on the top of this page that says, “iPhone Gen 1 Replacement Battery available for sale on eBay”
Anthony Guerrero -
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 122
过去 30 天: 599
总计 384,641
