简介
游戏手柄的一个常见问题是内部电池的劣化。无论是由于时间的流逝还是内部损坏,毫无疑问,有故障的电池会影响游戏体验。我们的指南旨在通过提供全面的解决方案来解决这个问题。我们的分步方法将引导用户完成更换 8bitDo Ultimate C 2.4g 无线手柄电池的过程,为他们提供自行更换所需的知识。
你所需要的
要重新组装您的设备,请按相反顺序执行以下步骤。
5等其他人完成本指南。
由衷感谢以下译者:
100%
Kevin正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4指南评论
Where did you boght the battery replacement? I'm trying to find it on the internet but no clues yet
Lucas Simões - 回复 分享
Did some digging based on the specs listed in the picture (3.7V, 480mAh) and it appears that 303454 is the standard name for said specs, although not the same shape and size as the one pictured as they appear to be using a custom form factor. That said, it looks like there should be enough spare room in the controller to make it work, but I can't verify it myself as I'm only shopping for the controller at the time of writing. I was able to find a 303454 battery with the connector on Amazon for about $5, so no soldering should be required, and it looks thin enough to be compatible. They also have other capacities if you want to upgrade to 950 or 2,000mAh while you're at it. Let me know if you're able to try it!
egarcia1360 - 回复 分享
Hi, where can I get the new battery for replacement?
Juan Manuel - 回复 分享
See my reply to Lucas above.
egarcia1360 - 回复 分享
