简介
如果你的冰箱门因为无法密封的原因持续的弹出,那么这个教程将会非常有用。很多人认为如果冰箱门的密封条无法正常工作,那么就需要换掉整个门或者整个冰箱。实际上,很有可能你只需要把密封条更换即可,但是大多数时间清洗和重新调整就可以把冰箱修好了。这个教程展示了如何清洗目前冰箱门密封条并且重新安装的简单方案。
配件
没有特定配件。
你的冰箱应该正常的保持关闭状态,密封条也应该牢固的安装在应有的位置上。为了保证冰箱的功能,经常性的检查封条以保持其在正确的位置上。
49等其他人完成本指南。
特别感谢这些译者︰
100%
eric正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
11条评论
Love that you show how to fix on a mini fridge! #CollegeLife Thanks for this :)
tcarle1191 - 回复
How can I fix the seals on chest fridge.
How much should the GE repairman charge for this repair? My mother-in-law was told it’ll cost her between $250-$275. I think that’s too much due to the cost of the seal. Does the labor cost account for the extra $200?
CLICK on the link here to help us engineering students to solve Fridge door problems!! https://docs.google.com/forms/d/e/1FAIpQ...
DON'T PUT VASELINE. I've ruined 2 fridges with this, now they're constantly running. You'll need silicon grease. This article is right. If it ain't broke, don't fix it, and &&^& the Vaseline guys
The seal was indeed damaged, but the door is unbalanced. Next repair for my 30 year old fridge.
Thanks for the great guidance.
Buy used support the little guy who refurbish
Thanku so much. It was really helpful. Got my problem fixed by ur advice.
How to fix a fridge or freezer seal: The easy way!
Use Duct tape to hold the door closed while you push (gently crushing the door seal) the door closed as hard as you can easily do. Leave the duct tape on for about 24 hours.
In most cases this will cause the door seal to re-level itself and seal better for a long time to come.
Generally, if a dollar bill placed between the door and the fridge comes out EASILY it means that that spot is not sealing well.
