简介
请按照本指南更换任天堂 Switch Lite 中的散热风扇。
注意:此过程需要卸下屏蔽板和散热器。在重新安装屏蔽板和散热器之前,需要清除两个组件以及CPU上的导热膏,然后重新涂抹。
你所需要的
用 JIS 000 螺丝刀或官方 iFixit PH 000 螺丝刀卸下固定后面板的螺丝:
设备顶部的两个3.6毫米长的螺丝
设备底部的两个3.6毫米长的螺丝
为防止这些拧的很紧的螺丝滑丝,请向下用力,缓慢操作,如果螺钉无法卸下,请尝试使用不同的螺丝刀。
要重新组装设备,请按照逆序进行操作。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的Nintendo Switch Lite 社区寻求帮助。
8等其他人完成本指南。
由衷感谢以下译者:
55%
neveare正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2指南评论
I used this guide to put my new fan in and let me just say THANK YOU!!! All I could find was ones for regular Switches on YouTube and not the Lite. The only problem I had was I'm not sure which side of the cable on the fan should be facing up. I looked on your website and the fan listen on here has one side with a gold part at the end where you insert it into the connector. Is that the side that goes up?
Many thanks for this guide it helped me so much it was pretty straight forward to do but attaching the fan ribbon/power cord and trying not to strip the tiny screws heads was probably the hardest bits really
