简介
如果你的Joy-Con手柄已经变得很容易从机子本体上松脱,这里将提供一个低成本且简单的维修方法:利用第三方的金属卡扣代替原有的塑料卡扣。
卸下图一中黄圈内的十字螺丝,轻轻地将图二中的金属盖撬开(用镊子应该会更轻松)。一定要让卡扣固定好,避免卡扣内的弹簧飞出来。
左右两边Joy-con的金属卡扣是不同的,在更换卡扣之前,请务必区分开,保证它与原本的塑料卡扣相匹配。要特别注意哪一面是凸出的,哪一面是平的。
取下卡扣,并小心别让内部的弹簧弹出。
若要重新组装你的机子,请按以下顺序进行。
64等其他人完成本指南。
特别感谢这些译者︰
90%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
18条评论
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
It seems rather strange.. Its pretty easy to reattach. All I have is a $@$*!& ph00 + y00 that stripped the screws so I broke the cover. Technically not my fault. I have done multiple reshells.
I tryed to do this but the 2nd at the bottom would not come out now my buckle is chiped
You mean the screws? Break off the shell! A perfect opportunity to put some clear ones :))
I bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/gp/product/B07BDH...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping $9.00 will set you up right.
I did have a bit of trouble replacing the metal cover that holds the buckle in place, but that was my own stupidity as I was trying to do this repair with insufficient light. Once I shed some light on the subject and I could see what I was doing, everything went back together smooth as silk. I replaced the buckles on both of my Joy Cons, and they’re both rock solid now.
