简介
请按照本指南更换 Nintendo Switch 上破裂或损坏的后面板。
Nintendo Switch 使用 JIS 螺丝,但是使用 Phillips 螺丝刀也是可以的。注意不要磨光螺纹。iFixit 的 Phillips 套件可以兼容 JIS 式螺丝。
注意:本指南以及我们出售的部件,与2017年发布的初始任天堂Switch和2019年发布的较新版本兼容(型号分别为HAC-001和HAC-001(-01))
你所需要的
将新的替换零件与原始零件进行比较。在安装之前,你可能需要从新零件中转移剩余的组件。要重新组装设备,请按照逆序进行操作。
将电子垃圾带到R2或e-Stewards认证的回收站。维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的社区寻求帮助。
62等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
9条评论
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
You can transfer the grill to the new back plat
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
