跳转到主内容
简介
根据本指南的操作来更换损坏或工作不正常的Switch的风扇。
注意:本流程需要拆除屏蔽板和散热片。两者之间以及与CPU之间的导热硅脂将会失效且需要清理,并且在重新安装时涂敷新的导热硅脂。
  1. 开始维修之前,请确保设备已完全关闭电源。 按住Joy Con控制器背面的圆形小按钮。 按住该按钮的同时,向上滑动控制器。
    • 开始维修之前,请确保设备已完全关闭电源。
    • 按住Joy Con控制器背面的圆形小按钮。
    • 按住该按钮的同时,向上滑动控制器。
  2. 向上划出手柄直到完全取下它 同理于另一只手柄 同理于另一只手柄
    • 向上划出手柄直到完全取下它
    • 同理于另一只手柄
  3. 在后盖,使用Y00螺丝刀拧下4颗长度为6.3毫米的螺丝
    • 在后盖,使用Y00螺丝刀拧下4颗长度为6.3毫米的螺丝
    • 在整个维修过程中,你需要记下每个螺丝的位置, 以确保正确重组你的游戏机
    Had to use a Y0 from my kit - the Y00 was too small to get a grip on the screw.
    cday - 回复
  4. 使用JIS000螺丝刀取下如下固定后面板的螺丝 一颗在顶部边缘的长度为2.5毫米的螺丝
    • 使用JIS000螺丝刀取下如下固定后面板的螺丝
    • 一颗在顶部边缘的长度为2.5毫米的螺丝
    • 两颗在底部边缘的长度为2.5毫米的螺丝
    Hey guys, I tried removing the upper screw and it won't go out(neither will it go in) any tips how to fix this?
    Thanks
    Nemysis - 回复
    The screw boss might be stripped out. Has the device been taken apart before? If you can unscrew it a little bit to get the screw to peek out, maybe try and grab it with some pliers as a last-ditch effort.
    Craig Lloyd -
    I have the same problem. The JIS 000 tool works great on the joy con rails per step 5 but refuses to turn the bottom two 2.5 mm screws as in step 4. These bottom screws are noticeably smaller than the screws as in step 5. The JIS 000 does not get down into these screws. Hopefully they haven’t been stripped by the wrong tool. So is there a JIS tool that is smaller than 000? I’m stuck at this point…
    david brown - 回复
    We used the JIS 3.0mm screwdriver for both top and bottom screws and it worked
    Brooklyn Gardner - 回复
    Used PH00 to get these out with no problem.
    cday - 回复
    Fun fact: these screw into little plastic tabs that stick out of the rear panel. Apparently those tabs are fragile and easy to just break off…
    Benjamin Fritz - 回复
    My screws came out fine. But they are easily stripped with too much pressure on reassmbly
    Jaxon Lee - 回复
    this screws are way too fragile and way too small so be careful when taking them off dont use much force and unscrew also one of them fell somewhere and spent 30 mins searching for it
    Richard Aguirre - 回复
  5. 在设备两边,使用JIS000螺丝刀拧下2颗长度为3.8毫米的中心螺丝(一面一颗) 在设备两边,使用JIS000螺丝刀拧下2颗长度为3.8毫米的中心螺丝(一面一颗)
    • 在设备两边,使用JIS000螺丝刀拧下2颗长度为3.8毫米的中心螺丝(一面一颗)
    I tried my JIS 000 on Step 5 and was unable to get the screw to budge. It’s partner from the other side came right out with no trouble. Don’t really want to narf up the screw, so I bailed out. Anyone else have this issue?
    mrhoyt - 回复
    Could just be torqued down a bit more! I’d recommend making sure the driver bit seats nicely into the screw, apply some downward pressure, and slowly twist to try and back it out. Good luck!
    Craig Lloyd -
    Yeah I’m having this exact issue. Screw stripped and now I’m stuck. Wish I hadn’t even started.
    Ryan Quinn -
    I did finally get it out- one thing I noticed was some of the screws have blue Loctite on the threads. I guess they figure it’ll get tossed around. This underscores the importance of having the correct tools and making double darn sure you are using the correct size, etc.
    mrhoyt - 回复
    What worked for me here was a Phillips 000, not a JIS 000
    Federico Zivolo - 回复
  6. 用手指提起设备背部用来支撑设备的支架 在开始下一步之前,取出微型SD卡,如果卡槽里有卡的话。
    • 用手指提起设备背部用来支撑设备的支架
    • 在开始下一步之前,取出微型SD卡,如果卡槽里有卡的话。
  7. 从支架上,使用JIS000螺丝刀拧下一颗长度为1.6毫米的螺丝
    • 从支架上,使用JIS000螺丝刀拧下一颗长度为1.6毫米的螺丝
  8. 从设备底部提起后盖并取下 背部盖板连接到塑料外壳的另一半,防止你在关闭后面板时将其完全抬起。 从设备底部向上提起后面板并将其卸下。
    • 从设备底部提起后盖并取下
    • 背部盖板连接到塑料外壳的另一半,防止你在关闭后面板时将其完全抬起。
    • 从设备底部向上提起后面板并将其卸下。
    How to remove micro SD port?
    Pull straight up, press back into place when closing back up.
    Christopher Hernandez - 回复
  9. 移除Micro SD卡槽上的1颗3.1 mm十字形飞利浦螺丝。
    • 移除Micro SD卡槽上的1颗3.1 mm十字形飞利浦螺丝。
  10. 用手或镊子,缓慢地垂直提起micro SD卡槽所在的子板,使其从主机上脱离,然后断开连接并移除它。 在重新组装时,请对齐子板并轻轻地按压接口上的海绵垫,直到接头发出咔哒声为止。如果需要,你可以在安装前取下海绵垫。
    • 用手或镊子,缓慢地垂直提起micro SD卡槽所在的子板,使其从主机上脱离,然后断开连接并移除它。
    • 在重新组装时,请对齐子板并轻轻地按压接口上的海绵垫,直到接头发出咔哒声为止。如果需要,你可以在安装前取下海绵垫。
    Yes. The reverse is not so simple- you can’t see what you’re doing when you attempt to reconnect and it only takes one small error to completely bend the contacts on the connector. Very delicate.
    if you very gently remove the foam pad sticker, you can at least see better how it lines up and can feel your way to a degree… then you can stick the pad back in. The pad seems pretty critical in keeping things in place once reassembled.
    holmzee - 回复
    Definitely agree about not sticking the foam pad back on until the new SD card slot is connected. Saved a lot of headache. Great walkthrough and easy repair!
    Jonathan Stachewicz -
    Tried several times to replace this SD reader module. As mentioned above, the issue is aligning the connectors together. It appears the foam tape is being used to hold the connection in place. (assuming you can make a viable connection) I am rather surprised at this design. In my experience, mylar ribbon cables like this usually slide into a small PC mounted socket. It appears Nintendo went the cheap route here. This design is prone to failure since it does not enable a positive connection - at least from what I can see.
    Bill Little - 回复
    Alors je suis en détresse total . Jai cassé les bouches en or sur le connecteur qui est soudé sur la carte mère.. comment changer cette toute petite pièces, oû la trouver . Cela fais 1 mois que je cherche partout. Sans remplacer la carte mère. Merci pour vos réponses
    Mike Snow - 回复
    I found it easier to connect it without the black foam pad so I could see and than add the foam pad over it. It was super easy and I an I 33 Mom doing this for my son. Was well worth the money for the kit saved us almost 100 bucks
    Katherine Harrison - 回复
    Had my son follow this guide to fix his own switch where the ad card reader didn't work. And he did. Great instructions!!!! Thanks a million!
    William Scott - 回复
    The only difficult part of following this guide is connecting the new sd card reader into the poorly designed motherboard connector. Its quite possible the sd card reader that came in the console wasnt broken at all.
    The repair kit works just as advertised and even comes with stickers.
    Matthias_ Links - 回复
    I’m still getting error 2002-2054 even after replacing memory card reader module. Thanks, Nintendo!
    Wes Stephenson - 回复
    My switch won’t read my microSD card after I reassembled it (error 2016-0641) please help!
    Nate Topical - 回复
    Tip: Keep the old SD reader piece loosely attached while you line up and gently press the new SD component into the connector on the motherboard. Once the new piece is snug, then carefully remove the old piece keeping the sticky foam in place.
    I am a middle-aged mom with absolutely no special tech skills and I easily followed the directions and successfully fixed the broken SD drive. ifixit is the best!
    Wende David - 回复
    I missed this bit about reconnecting the SD card reader under the foam pad and didn’t realise until my son pointed out a data storage problem?. All fixed in about 5 minutes taking advice from the replacing the SD card reader fix, especially removing the foam pad from the connector to better see and feel what you’re doing. All sorted!
    Stuart Farquharson-Roberts - 回复
    Awesome guide! Very easy to do with the supplied kit
    cravenkeo khamone - 回复
    Tank you very much, and by tank I mean M1 Abrams, jokes apart easy and simple to follow
    Elia Veschi - 回复
    Thanks for the guide, I was struggling to find a solution, replaced more sd cards, before I stumbled upon this post. The Switch of my children works flawless again!
    Robert Morvai - 回复
  11. 使用飞利浦000螺丝刀,移除屏蔽板上的6颗3mm的十字形螺丝
    • 使用飞利浦000螺丝刀,移除屏蔽板上的6颗3mm的十字形螺丝
  12. 用手指或镊子剥下设备顶部边缘靠近风扇排气口的泡沫片。 如果泡沫不容易剥落,请不要强行撕开,否则可能会撕裂。 小心地在不同的地方剥离,最终完全剥离泡沫。
    • 用手指或镊子剥下设备顶部边缘靠近风扇排气口的泡沫片。
    • 如果泡沫不容易剥落,请不要强行撕开,否则可能会撕裂。 小心地在不同的地方剥离,最终完全剥离泡沫。
    My Switch (bought about two weeks after launch) seems to be missing this foam piece… Was it added later, similar to the foam piece in the left joy-con (to improve connectivity)?
    firetech - 回复
    It’s possible it was added to newer units! Nintendo slightly updated the internals of the Switch not too long ago.
    Craig Lloyd -
  13. 沿设备边缘在屏蔽板下方插入撬棒。 向上撬起屏蔽板。 您可能会感到有点阻力。 这是正常现象,因为屏蔽板和散热器之间有导热膏——稍微有点黏性。
    • 沿设备边缘在屏蔽板下方插入撬棒。
    • 向上撬起屏蔽板。
    • 您可能会感到有点阻力。 这是正常现象,因为屏蔽板和散热器之间有导热膏——稍微有点黏性。
    • 取下屏蔽板。
    • 在铜质热管和屏蔽罩之间涂有一层较厚的粉色导热硅脂。为了最好的散热效果,在移除屏蔽罩之后,最好参考我们的散热硅脂更换指南来移除旧的散热硅脂并为其更换合适厚度的硅脂,例如K5 Pro
    How do you know if the thermal paste needs to be replaced?
    Youji Hong - 回复
    Once you remove a heatsink you must always replace thermal paste even if you had just applied it ( or add a little more) . The reason is that once heat sink is fitted, paste splits around because of pressure and only needed amount will remain. If you remove the heatsink then some paste will move so when installed again there will be spots without paste. Hope this is clear enough. In any case cost of paste is very small compared to work time and value of your equipment…..
    MacTek -
    When your switch starts to lag and drop FPS, if you play breath of the wild and it starts to slow down in heavy areas like the forest where you get the master sword, can i use artic mx 4 insted of the pink compound?
    Diego Soto - 回复
    I’d like to know as well if a cpu thermal compound like arctic mx-4 can be used to replace the pink compound
    Adam Stillman - 回复
    No you shouldn't . It will spill around because it is not viscous enough and then there will be no heat transfer. As suggested by author K5 PRO is the most appropriate compound for such cases.
    MacTek -
    Arctic is generally only supposed to be used on bigger heat sinks like a personal computer. Its not nearly as thick or gummy compared to K5 PRO, and you should always use something that’s thicker for smaller project like a Switch/phone/tablet.
    Shawn Christensen -
    Why was this not included in the tools/equipment list? Getting to this step and now I will have to reverse and wait for yet another order to arrive. ? Very frustrated
    Amanda Nally - 回复
    Hi Amanda,
    Thanks for bringing this up. Sorry! We inadvertently left that part out during the guide refresh. I’ll add the necessary info into the step.
    Arthur Shi -
  14. 在将撬棒的底端伸到白色插头的地下然后向上移动将其从主板上撬下。 在将撬棒的底端伸到白色插头的地下然后向上移动将其从主板上撬下。
    • 在将撬棒的底端伸到白色插头的地下然后向上移动将其从主板上撬下。
  15. 使用JIS 000螺丝起子卸下将散热器固定到主板的三颗3毫米螺丝。
    • 使用JIS 000螺丝起子卸下将散热器固定到主板的三颗3毫米螺丝。
    • 小心地将粘在散热器和风扇上的两个泡沫片从风扇上剥离。
    • 只需将泡沫剥离到足以清洁风扇的程度。
    • 泡沫片十分脆弱,很容易撕裂。 使用下面的方法剥离泡沫:
    • 将撬棒的尖端插入泡沫片下方没有粘住任何东西的部分,
    • 用手指按压泡沫片顶部以将其固定到位。
    • 将撬棒尖端一直滚动到泡沫片下方的另一端让泡沫片分离。
    spudger technique is perfect.
    Jaxon Lee - 回复
  16. 用撬棒或手指将散热器提起并从主板上卸下,以将其卸下。 你可能会感到有些抵触。这是正常现象,因为散热器会通过导热胶与CPU轻微粘合。 使用高浓度(90%或更高)的异丙醇和超细纤维布清除散热器和CPU上的旧导热膏。重新组装前,请在CPU上涂抹新的导热膏。
    • 用撬棒或手指将散热器提起并从主板上卸下,以将其卸下。
    • 你可能会感到有些抵触。这是正常现象,因为散热器会通过导热胶与CPU轻微粘合。
    • 使用高浓度(90%或更高)的异丙醇和超细纤维布清除散热器和CPU上的旧导热膏。重新组装前,请在CPU上涂抹新的导热膏。
    What's on the heatsink?
    Raven.K - 回复
    Directions for this step say you can use Artic Silver ArctiClean but when adding to iFixit cart it says “This won’t work with your device (Nintendo Switch).
    Dan S. - 回复
    where do i get more of that black fabric like tape that is on the heat sink?
    Regal Pikachu - 回复
    They may sell it in the ifixit store.
    Joshua Graham -
    (1) Exactly how much thermal paste should be applied to the CPU?
    (2) Which application method should be used? The linked instructions list four methods (vertical line, horizontal line, middle dot, or surface spread) but it’s not clear to me which one is appropriate for the Switch. Thanks!
    Travis - 回复
    UPDATE: So, for anyone who also wanted to know the answers to these questions:
    1. I ended up eyeballing the amount. Imagine an amount the size of a pea, then split that amount in half. That’s how much I used, and it worked fine.
    2. The paste (I used K5-Pro as recommended) is quite thick and sticky and difficult to get to behave the way you want, so I ended up just doing the “middle dot” method and spreading it a bit with a popsicle stick before smushing it the rest of the way down with the heat sink. Seems to have done the trick.
    Good luck!
    Travis -
    you can also spread it with the spudger or any non-metalic tool if you are not sure how much you put
    just clean it afterwards
    Richard Aguirre -
    i used artic silver 5 and worked just fine
  17. 使用打开工具或指甲将数字转换器电缆的ZIF连接器上的小夹扣锁定翻盖向上翻转。 使用打开工具或指甲将数字转换器电缆的ZIF连接器上的小夹扣锁定翻盖向上翻转。
    • 使用打开工具或指甲将数字转换器电缆的ZIF连接器上的小夹扣锁定翻盖向上翻转。
  18. 使用镊子,将数字转换器电缆水平滑出游戏卡读卡器板上的连接器。 使用镊子,将数字转换器电缆水平滑出游戏卡读卡器板上的连接器。
    • 使用镊子,将数字转换器电缆水平滑出游戏卡读卡器板上的连接器。
    The reverse of this is a little tricky - it may be helpful to post some more detail about getting the ribbon all the way back in and ensuring the clasp goes down to troubleshoot some of the touchscreen comments below.
    Nick Wagner - 回复
    It was not clear form the picture, but you need to pull sideways out toward the edge of the Switch where the JoyCon attaches, not up away from the motherboard.
    Benjamin Fritz - 回复
    Thanks for the feedback! I’ll adjust the wording to reflect this.
    Arthur Shi -
  19. 用撬棒的尖端笔直向上撬起耳机插孔和游戏卡读取器连接器,以将其与主板断开连接。 用撬棒的尖端笔直向上撬起耳机插孔和游戏卡读取器连接器,以将其与主板断开连接。
    • 用撬棒的尖端笔直向上撬起耳机插孔和游戏卡读取器连接器,以将其与主板断开连接。
  20. 使用JIS 000螺丝起子卸下将耳机插孔和游戏卡读取器板固定至设备的三颗3.1毫米螺丝。
    • 使用JIS 000螺丝起子卸下将耳机插孔和游戏卡读取器板固定至设备的三颗3.1毫米螺丝。
  21. 用镊子或手指卸下耳机插孔支架。 用镊子或手指卸下耳机插孔支架。
    • 用镊子或手指卸下耳机插孔支架。
  22. 用镊子或手指卸下耳机插孔和游戏卡读取器板。 用镊子或手指卸下耳机插孔和游戏卡读取器板。
    • 用镊子或手指卸下耳机插孔和游戏卡读取器板。
  23. 使用打开工具、撬棒或你的指甲将风扇电缆  ZIF 接口上的小铰链锁盖翻起。 使用打开工具、撬棒或你的指甲将风扇电缆  ZIF 接口上的小铰链锁盖翻起。
    • 使用打开工具、撬棒或你的指甲将风扇电缆 ZIF 接口上的小铰链锁盖翻起。
    The little gray tab flew off while I removed the cable. I found it, but I can’t get it back on. Is it possible to install the new fan without it?
    Jesse DuRona - 回复
    No. You will need for professional help to replace the whole ribbon cable connector (ZIF connector).
    CCL13 -
  24. 使用镊子将风扇电缆从主板上的接口中直接拉出。 使用镊子将风扇电缆从主板上的接口中直接拉出。
    • 使用镊子将风扇电缆从主板上的接口中直接拉出。
    Will need to remove parts and board in top left in order to get to 3rd fan screw.
  25. 使用 JIS 000 螺丝刀卸下固定风扇的三颗 4.8 毫米螺丝。
    • 使用 JIS 000 螺丝刀卸下固定风扇的三颗 4.8 毫米螺丝。
  26. 使用镊子或手指将风扇垂直向上提起并将其从设备中取出。 将你的新更换零件与原始零件进行比较。 在安装之前,你可能需要将剩余的组件(例如橡胶衬套)转移到新部件上。
    • 使用镊子或手指将风扇垂直向上提起并将其从设备中取出。
    • 将你的新更换零件与原始零件进行比较。 在安装之前,你可能需要将剩余的组件(例如橡胶衬套)转移到新部件上。
结论
若要重新组装设备,请倒序按照本指南操作。
请将被替换下的电子垃圾送到回收点处置,不要随意抛弃。
如果维修未能成功,可以尝试参考维修后故障排除指南。也可以在Nintendo Switch Answers community(英文内容)论坛上求助。
90等其他人完成本指南。
特别感谢这些译者︰
en zh
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Craig Lloyd
于2016年02月10日注册
19,426 信誉积分
创作了82篇指南
团队
iFixit iFixit 的会员
Community
138 名成员
创作了16,504篇指南
If your joycons are not charging, it could be the fans fault as they seem to share a 1.8v and or 5v rail, I had both joycons refusing to charge, and the fan was not working, so by replacing the fan, it had them charging properly again.
Corbin - 回复
oh? i was wondering why my joycons died and never turned on. i though the hot switch short circuited them. the same thing happened to mine. The fan died as well as my joycons. very useful mate. thanks for the info!
Robby Ninte -
I changed the fan and it still don’t charge my Joycon. What should I do?
baron154 -
I’ve recently found a video that shows what can be wrong with Switch with the same issue, but working fan https://www.youtube.com/watch?v=WuQC3ipu... . In the comments people confirmed several times that it helps.
Andrey -
If I'm just replacing the fan, do I need to clean off/reapply any thermal paste?
Postponderance - 回复
It’s always a good idea to clean off and replace the thermal paste if the heat sink is removed.
Blake Klein -
Excellent guide, worked perfectly for me, and I’m very bad at taking things apart and putting them back together. Fan fixed my joycon not charging issue as well.
Jeremy Daniels - 回复
Thanks a lot. I used this a few minutes ago to fix my little son Nintendo switch (he will woke up tomorrow with this surprise!).
I am not an expert on this kind of fixes and did this with a lot of caution. Took me around 1 hr and 45 minutes.
Greetings from Mexico
Eduardo Sanchez - 回复
Thank you for all the instructions. I ran all the steps, but I was not sure if I put the fan cable properly. In the end, the new fan does not run. Is there a way to test the new fan before closing everything?
Elektra Star - 回复
After replacing the fan according to the instructions (which were easy-to-follow and comprehensive), my Switch now overheats in docked mode fairly quickly. Is there an easy way to determine if the fan is working properly? My Switch is extremely quiet now which leads me to wonder if the fan is faulty or if I just missed a step. I also redid the repair process a second time and took extra care to make sure all the connections were secure, and made sure to reapply the heat paste carefully in each area, including the underside of the shield plate.
This leads me to my other concern: I used the same heat paste applied to the CPU to the shield plate where the thick, pink compound was located. Could it be that I used the wrong paste in that section?
Thanks in advance for the advice.
Taylor Weaver - 回复
Completed the replacement, however, now that the fan works, my touch screen no longer is responsive to touch and the cartridge reader no longer reads cartridges. Any help would be appreciated.
Clint Allday - 回复
Hi Clint! This is a common issue. Try disconnecting the battery, wait ~5 seconds, and reconnect it again to power cycle the Switch.
Arthur Shi -
For Step 17, do we use the same thick/viscous thermal compound as from Step 13 (the K5 Pro) or can we use a standard CPU thermal paste (e.g. Artic Silver 5) ?
Step 17 does not specify, so any confirmation would be helpful.
jaime barillas - 回复
As far as my result goes, it is preferable to choose some less watery, more firm thermal compound on both. As long as it does not run around, it is fine to use the same on both. I have not used Arctic Silver 5 so don’t know how that works. But I have used Noctua NT-H1 and Thermal Grizzly Kryonaut, both working well. I’ve tried something quite watery from Prolimatech which quickly stopped working after like a week.
CCL13 -
Fantastic guide. I was able to purchase the fan and the needed tools and replace it without issues. I was able to easily follow the directions to take it apart and put everything back together again. Switch runs silently now like it a fresh new switch. Couldn’t be happier that I didn’t have to try to go out and buy a new switch! Thank you very much for the easy to follow guide.
Joseph Alioto - 回复
As a long time computer repair technician, this was about as easy as it comes. I have not touched a console since modding my Xbox 360 with a standard seagate barracuda hard drive in order to play original Xbox games. Excellent guide, easy to follow. Love my IFIXIT Pro Tech Tool Kit and want to thank Steve from @tronicsfix for turning me onto IFIXIT tools and guides.
Tom Rasmussen - 回复
Are the switch lite and original switch fan the same ?
Benoît - 回复
No they are different.
CCL13 -
Is there a different thermal paste I can use instead or can I get a link to smaller amount of the recommended one? I don’t need that much and I cant find a listing for a smaller amount. Thanks in advance!
Edwin - 回复
There's two kinds of thermal paste used originally for different purposes. For use between CPU and heatsink, I recommend something high quality like Arctic MX-4 or better. And the other between heatsink and the shell it could be whatever passable. If you just don't want to stock two variety, use good one for both. MX-4 is quite cost efficient but there are other choices too. 2gram should be about enough.
CCL13 -
Just finished taking everything apart and putting it back together for the second time. Everything seems fine, except that it seems like the switch now has no battery charge, and doesn’t seem to want to charge when connected by cable. Has anyone else had this problem? What should I be looking at to reconnect, or fix, or..?
Thanks
farM0use - 回复
For further information: If I leave it for a while, and try holding down the power button, the nintendo logo comes up for a moment, and then the battery symbol (with a red bar to indicate no charge) comes up. It stay on the screen when the charge cable is in, but doesn’t seem to change, even when I leave it plugged in.
farM0use -
Nevermind…. just needed to charge it for longer. Everything’s working great, and I can only hear the fan when I put my ear right up to it now!
farM0use -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 607
过去的30天: 3,091
总计 109,771
