简介
根据本指南的操作来更换Switch的电源和音量键主板。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
使用 Y00 螺丝刀拧下固定在后盖上的 4 颗 6.3 毫米螺丝。
I think my screws are stripped, any way to get them out?
I hear that using a rubber band can help? Not 100% sure on that though.
Pifase -
My top 2 screws are stripped, one into triangle, the other circle, rather than triangle spokes.
This happened when I replaced the micro-sd card slot, which turned out to have replaced the broken one with another one that turns out to be broken. I need to fix the fact that when I reapplied the back cover, the vent was misaligned.
I had huge problems removing the bottom two screws. I continued with the next steps and lifted the plastic shell as much as possible while using the screwdriver and it became an ease.
y0 works best. Press HARD at beginning then ease off to finish.
J LWsMommy - 回复
使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
Hey guys, I tried removing the upper screw and it won't go out(neither will it go in) any tips how to fix this?
Thanks
The screw boss might be stripped out. Has the device been taken apart before? If you can unscrew it a little bit to get the screw to peek out, maybe try and grab it with some pliers as a last-ditch effort.
I have the same problem. The JIS 000 tool works great on the joy con rails per step 5 but refuses to turn the bottom two 2.5 mm screws as in step 4. These bottom screws are noticeably smaller than the screws as in step 5. The JIS 000 does not get down into these screws. Hopefully they haven’t been stripped by the wrong tool. So is there a JIS tool that is smaller than 000? I’m stuck at this point…
We used the JIS 3.0mm screwdriver for both top and bottom screws and it worked
Fun fact: these screw into little plastic tabs that stick out of the rear panel. Apparently those tabs are fragile and easy to just break off…
If the screw is turning but not coming out, the plastic tab that it screws into is probably damaged or broken. You’ll need to try to pry the screw out with tweezers as you unscrew it. It is not the end of the world if you can’t screw these back in during reassembly.
this screws are way too fragile and way too small so be careful when taking them off dont use much force and unscrew also one of them fell somewhere and spent 30 mins searching for it
PH000 will work if you don’t have JIS000. The large IFIXIT kit has both and I lost JIS000. Just be very careful as you can strip the heads when removing or inserting easier.
One thing that worked pretty well for me with the screws not coming out is slightly prying on the back cover to put them under some tension
Quick note, these screws are not magnetic. A magnetic screwdriver will hold onto any of the others safely, but you need to be careful not to drop these ones in particular.
Jason Lane - 回复
These would just keep rotating and not come out. What worked was, as Florian Kraupa suggested, i slid a plastic pick just between the 2 shells near the screws to prise it open slightly, then unscrewed and out they came. They're the smallest screws I've ever almost not seen before, so be careful with them.
在设备两边,使用 JIS000 螺丝刀(或 iFixit PH000 螺丝刀)拧下2颗长度为3.8毫米,位于中央的中心螺丝(一面一颗)
注意 如图所示,在主机的两面各有五颗螺丝,本步骤只需要拆除最中心的那一颗,其余四颗不需要拆卸。
I tried my JIS 000 on Step 5 and was unable to get the screw to budge. It’s partner from the other side came right out with no trouble. Don’t really want to narf up the screw, so I bailed out. Anyone else have this issue?
Could just be torqued down a bit more! I’d recommend making sure the driver bit seats nicely into the screw, apply some downward pressure, and slowly twist to try and back it out. Good luck!
Yeah I’m having this exact issue. Screw stripped and now I’m stuck. Wish I hadn’t even started.
What worked for me here was a Phillips 000, not a JIS 000
My kit only has two screwdriver heads! The package was open when I received it!
I had this issue as well. Screw was irreparably stripped. If you can get every other screw out, just keep applying pressure with a flat head screw driver right above the stripped screw and try to break the plastic piece holding onto the screw. It's a very minor invisible bit of damage that will allow you to continue the repair.
after getting all the other screws off I just hinged the back part away and it snapped off neatly where the rusted screw is. not the best solution but it worked.
Steve T -
One of my screws was SUPER attached too, but after following a bit noticed the one other in the left that got out nicely, had the plastic tab broken already! So I went ahead and broke the other tab too. So the two side screws are now holding nothing. But I think it will work thanks to the other 4 or 5 screws. Too bad!
从设备底部提起后盖并取下
从设备底部向上提起后面板并将其卸下。
How to remove micro SD port?
Pull straight up, press back into place when closing back up.
This step is missing in this guide. Here are the steps from another guide:
Step 9) 任天堂Switch的右侧Joy Con手柄滑轨的更换
Step 10) 任天堂Switch的右侧Joy Con手柄滑轨的更换
使用 JIS000 螺丝刀或 iFixit 菲利普000螺丝刀,移除屏蔽板上的6颗3mm的十字形螺丝
Some models have a small board in the lower left beneath the kickstand which accepts SD cards. This will have to be carefully removed with its connections popped out, then replaced after.
Yeah, that “small board” is the microSD Card reader chip, which was covered literally one step ago. All models have a microSD Card reader, that’s how game data is stored…
nin10doh -
用手指或镊子剥下设备顶部边缘靠近风扇排气口的泡沫片。
My Switch (bought about two weeks after launch) seems to be missing this foam piece… Was it added later, similar to the foam piece in the left joy-con (to improve connectivity)?
It’s possible it was added to newer units! Nintendo slightly updated the internals of the Switch not too long ago.
My launch Switch also does not have this piece of foam, so it was most likely added later.
Also did not see this in my launch switch.
Me three, no foam.
How do you know if the thermal paste needs to be replaced?
Youji Hong - 回复
Once you remove a heatsink you must always replace thermal paste even if you had just applied it ( or add a little more) . The reason is that once heat sink is fitted, paste splits around because of pressure and only needed amount will remain. If you remove the heatsink then some paste will move so when installed again there will be spots without paste. Hope this is clear enough. In any case cost of paste is very small compared to work time and value of your equipment…..
MacTek -
When your switch starts to lag and drop FPS, if you play breath of the wild and it starts to slow down in heavy areas like the forest where you get the master sword, can i use artic mx 4 insted of the pink compound?
Diego Soto - 回复
I’d like to know as well if a cpu thermal compound like arctic mx-4 can be used to replace the pink compound
No you shouldn't . It will spill around because it is not viscous enough and then there will be no heat transfer. As suggested by author K5 PRO is the most appropriate compound for such cases.
MacTek -
Arctic is generally only supposed to be used on bigger heat sinks like a personal computer. Its not nearly as thick or gummy compared to K5 PRO, and you should always use something that’s thicker for smaller project like a Switch/phone/tablet.
Why was this not included in the tools/equipment list? Getting to this step and now I will have to reverse and wait for yet another order to arrive. ? Very frustrated
Hi Amanda,
Thanks for bringing this up. Sorry! We inadvertently left that part out during the guide refresh. I’ll add the necessary info into the step.
does ifixit not have an appropriate thermal paste for this step?
there is only arctic silver 5 in the kit and i would guess that that should not be used in this case.
if true, the kit is incompleteLucas Tigy - 回复
在将撬棒的底端伸到白色插头的地下然后向上移动将其从主板上撬下。
be careful not to pry it off the board entirely
This was an old switch and the entire thing with the black plastic came off.. Most of the pins aren't there anymore, too.. is there a solution to that? Does soldering work?
it's probably possible, but unless you have experience with microsoldering, you'd probably be better off taking it to a local repair shop
You can use a spudger to hold down the black plastic side of this connector that is supposed to stay attached to the motherboard while using the pointy spudger as shown in order to reduce any chance of pulling the socket off the motherboard.
小心地将粘在散热器和风扇上的两个泡沫片从风扇上剥离。
将撬棒的尖端插入泡沫片下方没有粘住任何东西的部分,
用手指按压泡沫片顶部以将其固定到位。
将撬棒尖端一直滚动到泡沫片下方的另一端让泡沫片分离。
Maybe it’s because I’m working on a day one switch and the adhesive is just old and stubborn, but this didn’t work well for me. Am I just completely out of luck, or can I order a replacement for the foam?
Trae Block - 回复
I had the same problem and I found a foam manufacturer: https://www.foam-material.com/sample-cus...
I'm pretty sure the type is "Granular Activated Carbon Foam" and the thickness is 0.5 mm but I have no idea what the porosity is.
Yeah ripped the foam. Neither the screwdriver nor spudger technique worked. Day one switch, so 6 years old at this point.
Ndragonawa - 回复
Does the foam need replacing if torn? What does it actually do.
I wanted to know as well, what does it do? Can I replace it with thermal pads?
Can I replace the foam with a 0.5mm thermal pad? Will it be a better solution?
The adhesive remover really helped here being a day one switch
用撬棒或手指将散热器提起并从主板上卸下,以将其卸下。
将散热膏均匀地涂在之前涂过的位置。这包括散热管和铝合金屏蔽罩之间,Switch用来额外散热的那个地方。
What's on the heatsink?
where do i get more of that black fabric like tape that is on the heat sink?
They may sell it in the ifixit store.
(1) Exactly how much thermal paste should be applied to the CPU?
(2) Which application method should be used? The linked instructions list four methods (vertical line, horizontal line, middle dot, or surface spread) but it’s not clear to me which one is appropriate for the Switch. Thanks!
UPDATE: So, for anyone who also wanted to know the answers to these questions:
1. I ended up eyeballing the amount. Imagine an amount the size of a pea, then split that amount in half. That’s how much I used, and it worked fine.
2. The paste (I used K5-Pro as recommended) is quite thick and sticky and difficult to get to behave the way you want, so I ended up just doing the “middle dot” method and spreading it a bit with a popsicle stick before smushing it the rest of the way down with the heat sink. Seems to have done the trick.
Good luck!
Travis -
you can also spread it with the spudger or any non-metalic tool if you are not sure how much you put
just clean it afterwards
K5 (or thermal pads) is ONLY needed between the copper pipe and metal shield plate. It is a pad replacement compound and is not meant for high heat applications like CPUs as it boils and creates air gaps. Air=bad for heat transfer.
Regular thermal compound/paste should be used on the CPU. You’ll have a sticky mess to clean but if you want proper cooling it needs to be done. The instructions clearly state that regular compound is used on the CPU.
Cerus98 -
i used artic silver 5 and worked just fine
The steps doesnt specify but do you have to remove the heat shield from the cpu as well?
使用打开工具、撬棒或你的指甲将风扇电缆 ZIF 接口上的小铰链锁盖翻起。
The little gray tab flew off while I removed the cable. I found it, but I can’t get it back on. Is it possible to install the new fan without it?
No. You will need for professional help to replace the whole ribbon cable connector (ZIF connector).
CCL13 -
A step here is skipped. There is a small board which contains the cart reader and headphone out jack. The connector for the headphone jack will need to be popped off and the board unscrewed. It can then gently be pushed out of the way while leaving it otherwise connected. Reconnecting the headphone jack’s cable is tricky as a heads up. Be patient there.
That step is immediately above this one. Check out step 21 to 23.
CCL13 -
使用镊子将风扇电缆从主板上的接口中直接拉出。
Will need to remove parts and board in top left in order to get to 3rd fan screw.
During reassembly, I found it easier to insert the ribbon from the new fan while the fan was loose and held in my hand. Once the ribbon was inserted and locked down, then I seated and screwed in the fan.
使用镊子或手指将风扇垂直向上提起并将其从设备中取出。
The original fan does not have removable rubber bushings. It has hard plastic ones attached to the fan itself. The original fan is a Foxconn PVB040A05H brushless fan.
Because I cannot remove the brushings but the guide assumes I can, the new fan cannot be screwed in securely, so my repair seems to be failing.
I ended up using 2 tiny regular metal washers per screw and closing it back up. The washers prevent the fan from moving up and down but not side to side. The heat sink probably holds the fan in place well enough that I didn't even need the washers. Either way the replacement fan isn't quite as secure in there as the original. But the repair works -- for anyone else stuck at this step.
Same here. WTF is wrong with this "repair" kit?! I CANNOT repair my Nintendo Switch FFS!
Steffen -
My switch did have rubber bushings that I transferred to the new fan. The old fan was from Delta Electronics.
The fan in my switch did not have bushings either. This replacement kit should be revised to include them.
Come on... The Foxcon model: PVB040A05H-P05 has no rubber bushings. THIS is f*cked up. Now I am sitting with my opened Switch and cannot replace the fan.
My switch had the rubber bushings on the fan already. I took the rubber bushings off the old fan and put them onto the new fan.
使用撬棒的平端撬动排线底部使其从主板上的连接口滑出。
I was able to replace the LCD and touch glass on my son's Switch. Everything went well the LCD worked again the screen too ... everything really ... except the ON / OFF buttons and volume ... I opened the switch again and tried to put the Ribbon Flex Cable back on the ZIF connector. As I was getting unnerved, I ended up detaching the ZIF connector from the motherboard, which came out broken. Now I look for this ZIF connector on the internet and I can't find it. Can anyone help me? Thank you
若要重新组装设备,请倒序按照本指南操作。
15等其他人完成本指南。
由衷感谢以下译者:
71%
Kevin Fu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
Great guide. Just repaired my daughters Switch by replacing power button.
I replaced the cable and still have the same issue, volume up button don't work and volume down is volume up, and it's always kn
Hi, did you manage to fix it? I have the exact issue
I changed the cable and it works.
Thanks
Great guide. There were a couple of steps I found missing, but the rest of the guide had very similar steps, so just applying the same logic to the mini-boards I had to pull worked perfectly. This guide saved me from having to buy a new switch or pay almost the price of a new one to have it repaired!
Guide was almost perfect - two important steps missing: one step for each of the card readers. Which are kind of important, as if the game card reader isn’t reconnected properly, the console won’t boot back up. Fortunately, I figured that problem out before bricking my switch.
Great guide. However, this guide did miss how to disassemble the game card reader which should be done before step 18 since the cartridge slot is blocking one of the screws of the fan. All that is required is to unscrew three (i think they're 3mm) screws and take out a little plastic black piece that was screwed in. Then, you have to pull out the ribbon closest to the fan. (This may take a bit of a hard tug to get out but it should be fine.) After that, the cartridge slot should only be connected via the other long horizontal ribbon to the left and you don't have to do anything because at this point you should be able to move around the cartridge slot and be able to unscrew the fan now. Sorry if this is a bit unclear because this is my first time doing anything like this but I thought I could try to help other people having problems.
Kann ich diese Anleitung auch für die OLED anwenden? Habe im INet sonst leider nichts brauchbares gefunden.
Ina Barz - 回复
backup all your sd card data i had to format mine after this tutorial and lost all my game data
JustForThisComment?ComeOn - 回复
