跳转到主内容
修复你的物品
维修的权力
商店
简介
根据本指南的操作来更换Switch的左侧Joy-Con手柄滑轨。
  1. 移除背部外壳上的4颗6.3 mm的Y字形Y00螺丝。
    • 移除背部外壳上的4颗6.3 mm的Y字形Y00螺丝。
    Please be careful with these screws. Your bit will go through them like butter and strip them if you're not careful. Speaking from experience.
    Benjamin Fryar - 回复
    So should I use glasses screws
    iceprincess4445 - 回复
    what happens if you do strip a screw?
    Stephanie C Cusimano - 回复
    I used a Y0 bit instead and it worked better for me not to strip the screws
    Alexander Watson - 回复
    Any suggestions of what you can do if you do strip the screw
    Emma Johnson - 回复
  2. 移除立式支架下的1颗6.1 mm的十字形飞利浦#000螺丝。
    • 移除立式支架下的1颗6.1 mm的十字形飞利浦#000螺丝。
    Mine was no longer than about 1mm.
    Nani - 回复
    Agree. This was a very short screw.
    Paul Swinglehurst - 回复
  3. 移除主机下方的2颗2.7 mm的十字形飞利浦#000螺丝。
    • 移除主机下方的2颗2.7 mm的十字形飞利浦#000螺丝。
    These screws wouldn’t go back in for me for some reason. I was definitely using the right screws as I set them aside step by step as usual. I’m not sure what the problem could have been, I just reassembled without the screws.
    Jason Rivera - 回复
  4. 移除主机顶部的1颗2.7 mm的十字形飞利浦#000螺丝。
    • 移除主机顶部的1颗2.7 mm的十字形飞利浦#000螺丝。
    This one didn’t want to come out on its own, and only came loose when I completed the rest of the steps to remove the rear panel, as I pulled the panel off.
    Matt Silver - 回复
  5. 移除右侧手柄滑轨上的1颗3.8 mm十字形飞利浦#000螺丝。 移除左侧手柄滑轨上的1颗3.8 mm十字形飞利浦#000螺丝。
    • 移除右侧手柄滑轨上的1颗3.8 mm十字形飞利浦#000螺丝。
    • 移除左侧手柄滑轨上的1颗3.8 mm十字形飞利浦#000螺丝。
    Please do not use a JIS #0 bit on this kit. I ended up stripping the screw on my switch and now I won't be able to get inside. You are much more likely to remove this screw with a JIS #000 bit, like literally every other screw on this machine. Why I thought I should throughly read and follow the instructions is beyond me, because I guess this ifixit guy decided it would be a great meme to get people to ruin their switches.
    Jacob Klinkenberg - 回复
    +1, JIS #0 seems way too large; I used a #00 and that worked. I agree that #000 might have worked even better, but I saw this comment too late.
    Nikolai Knopp -
    Mine was #000 too. #0 was definitely too large. Also there are signs of blue threadlock.
    Nani - 回复
    tried using #000 and #00 but the screw wont turn, any ideas why
    thawdon - 回复
    Ive been trying to unscrew with the correct 000 bit for like 5 minutes and it wont unscrew :/ please help asap
    xenomorphic/dark Mewtwo - 回复
    this screw stripped in like two seconds using the screwdriver included with ifixit’s kit!
    Connor Martini - 回复
    One screw didn’t come off and now it is stripped…. I’m trapped in this step, desperate and questioning all my life choices…….
    ninja android - 回复
    RIP screw RIP repair
    Moritz Boch - 回复
    RIP crew, RIP repair
    Moritz Boch - 回复
    Well this sucks, I can’t get these %#*@ joy con screws out, why did I spend all this money, its works on every other screw on the joy con rails but its like these middle screws aren’t cut deep enough for anything to grab onto it.
    I got them out with a #000 but it took an obscene amount of pressure put down on the screw. Needless to say I’m not putting them back in.
    Eric - 回复
  6. 将外壳从主机上移除。 将外壳从主机上移除。 将外壳从主机上移除。
    • 将外壳从主机上移除。
    You appear to be missing a step. The SD card reader needs to be removed between steps 6 and 7.
    zharin - 回复
    Achtet darauf die Backplate nicht zu kippen, wie es die Bilder vermuten lassen. Ich habe beim nach Hinten klappen ein Plastikgewinde an der Backplate abgebrochen. Aufpassen.
    I think the picture is a bit misleading. I tiltet the plate while I was removing it what resulted in an broken off screwmount.
    Leon Grell - 回复
  7. 移除Micro SD卡槽上的1颗3.1 mm十字形飞利浦螺丝。
    • 移除Micro SD卡槽上的1颗3.1 mm十字形飞利浦螺丝。
  8. 缓慢地垂直提起micro SD卡槽所在的子板,使其从主机上脱离,然后断开连接并移除它。 在重新组装时,对齐子板并轻轻地按压接口上的海绵垫,直到接头发出咔哒声为止。
    • 缓慢地垂直提起micro SD卡槽所在的子板,使其从主机上脱离,然后断开连接并移除它。
    • 在重新组装时,对齐子板并轻轻地按压接口上的海绵垫,直到接头发出咔哒声为止。
  9. 移除屏蔽板上的6颗3.1mm的十字形飞利浦#000螺丝。
    • 移除屏蔽板上的6颗3.1mm的十字形飞利浦#000螺丝。
    Agreed, still missing that step… I don’t have the image that is in your linked screenshot.. but your screenshot doesn’t mention removing a 7th screw anyway. I had my screwdriver underneath trying to pry it open before realizing there was another screw holding it all together.
    beaugalbraith - 回复
    Sorry everyone! The guide was missing a prerequisite guide. The missing SD card steps should be there now.
    Arthur Shi - 回复
  10. 将屏蔽板从主机上移除。 在铜质热管和屏蔽罩之间涂有一层较厚的粉色导热硅脂。为了最好的散热效果,在移除屏蔽罩之后,最好参考我们的散热硅脂更换指南来移除旧的散热硅脂并为其更换合适厚度的硅脂,例如K5 Pro。 在铜质热管和屏蔽罩之间涂有一层较厚的粉色导热硅脂。为了最好的散热效果,在移除屏蔽罩之后,最好参考我们的散热硅脂更换指南来移除旧的散热硅脂并为其更换合适厚度的硅脂,例如K5 Pro。
    • 将屏蔽板从主机上移除。
    • 在铜质热管和屏蔽罩之间涂有一层较厚的粉色导热硅脂。为了最好的散热效果,在移除屏蔽罩之后,最好参考我们的散热硅脂更换指南来移除旧的散热硅脂并为其更换合适厚度的硅脂,例如K5 Pro
    How do you know if the thermal paste needs to be replaced?
    Youji Hong - 回复
    Once you remove a heatsink you must always replace thermal paste even if you had just applied it ( or add a little more) . The reason is that once heat sink is fitted, paste splits around because of pressure and only needed amount will remain. If you remove the heatsink then some paste will move so when installed again there will be spots without paste. Hope this is clear enough. In any case cost of paste is very small compared to work time and value of your equipment…..
    MacTek -
    I’d recommend replacing the thermal compound to ensure that the cooling system works as intended.
    Blake Klein - 回复
    When your switch starts to lag and drop FPS, if you play breath of the wild and it starts to slow down in heavy areas like the forest where you get the master sword, can i use artic mx 4 insted of the pink compound?
    Diego Soto - 回复
    I’d like to know as well if a cpu thermal compound like arctic mx-4 can be used to replace the pink compound
    Adam Stillman - 回复
    No you shouldn't . It will spill around because it is not viscous enough and then there will be no heat transfer. As suggested by author K5 PRO is the most appropriate compound for such cases.
    MacTek -
    Arctic is generally only supposed to be used on bigger heat sinks like a personal computer. Its not nearly as thick or gummy compared to K5 PRO, and you should always use something that’s thicker for smaller project like a Switch/phone/tablet.
    Shawn Christensen -
    I really don’t understand in what areas I should be replacing the thermal paste.
    Do I leave the giant pink glob that’s present on the back plate or replace that as well?
    Or do I only apply it under the heat sink and on the motherboard?
    Nik Terzic - 回复
  11. 在将撬棒的底部伸到白色插头的地下然后向上移动将其从主板上撬下。 在将撬棒的底部伸到白色插头的地下然后向上移动将其从主板上撬下。
    • 在将撬棒的底部伸到白色插头的地下然后向上移动将其从主板上撬下。
    It is possible to just slide the old rail out after this step, and slide in the new one.
    Johny Sanders - 回复
  12. 移除散热器上的3颗3.1mm的十字形#000螺丝。
    • 移除散热器上的3颗3.1mm的十字形#000螺丝。
  13. 将散热片以45°角抬起,向右侧旋转以移除。 将散热片以45°角抬起,向右侧旋转以移除。 将散热片以45°角抬起,向右侧旋转以移除。
    • 将散热片以45°角抬起,向右侧旋转以移除。
    What's on the heatsink?
    Raven.K - 回复
    Directions for this step say you can use Artic Silver ArctiClean but when adding to iFixit cart it says “This won’t work with your device (Nintendo Switch).
    Dan S. - 回复
    where do i get more of that black fabric like tape that is on the heat sink?
    Regal Pikachu - 回复
  14. 用干净的指甲向上撬开固定游戏卡读卡器排线的ZIF连接器。 用干净的指甲向上撬开固定游戏卡读卡器排线的ZIF连接器。 用干净的指甲向上撬开固定游戏卡读卡器排线的ZIF连接器。
    • 用干净的指甲向上撬开固定游戏卡读卡器排线的ZIF连接器
  15. 用撬棒较尖的一头缓缓将游戏卡读卡器的排线从插座上移除。 用撬棒较尖的一头缓缓将游戏卡读卡器的排线从插座上移除。 用撬棒较尖的一头缓缓将游戏卡读卡器的排线从插座上移除。
    • 用撬棒较尖的一头缓缓将游戏卡读卡器的排线从插座上移除。
  16. 用飞利浦螺丝刀从耳机孔支架上移除两颗 3.1 mm的螺丝。 用飞利浦螺丝刀从耳机孔支架上移除两颗 3.1 mm的螺丝。
    • 用飞利浦螺丝刀从耳机孔支架上移除两颗 3.1 mm的螺丝。
  17. 移除耳机孔支架。
    • 移除耳机孔支架。
  18. 用飞利浦螺丝刀从耳机孔和游戏卡读卡器子板上移除一颗3.1 mm螺丝。 用飞利浦螺丝刀从耳机孔和游戏卡读卡器子板上移除一颗3.1 mm螺丝。
    • 用飞利浦螺丝刀从耳机孔和游戏卡读卡器子板上移除一颗3.1 mm螺丝。
  19. 使用撬棒的尖端撬起屏幕排线连接口上的黑色小卡扣。 使用撬棒的尖端撬起屏幕排线连接口上的黑色小卡扣。
    • 使用撬棒的尖端撬起屏幕排线连接口上的黑色小卡扣。
  20. 在组装时,为了让耳机孔连接器就位,请先将整个游戏卡槽子板轻轻抬离Switch的顶部,这样就可以使耳机孔连接器与插座对齐。 用撬棒按压连接器直到听到咔哒声表示连接到位。 沿着整个插头的顶部按压,确保排线放置的位置正确,包括热管下的区域。
    • 在组装时,为了让耳机孔连接器就位,请先将整个游戏卡槽子板轻轻抬离Switch的顶部,这样就可以使耳机孔连接器与插座对齐。
    • 用撬棒按压连接器直到听到咔哒声表示连接到位。
    • 沿着整个插头的顶部按压,确保排线放置的位置正确,包括热管下的区域。
  21. 移除耳机孔和游戏卡槽主板上的1颗3.1mm的十字形螺丝。 移除耳机孔和游戏卡槽主板上的1颗3.1mm的十字形螺丝。 移除耳机孔和游戏卡槽主板上的1颗3.1mm的十字形螺丝。
    • 移除耳机孔和游戏卡槽主板上的1颗3.1mm的十字形螺丝。
  22. 将右侧扬声器的排线与主板断开连接。 将右侧扬声器的排线与主板断开连接。
    • 将右侧扬声器的排线与主板断开连接。
  23. 将左侧扬声器的排线与主板断开连接。 将左侧扬声器的排线与主板断开连接。
    • 将左侧扬声器的排线与主板断开连接。
  24. 使用撬棒的尖端撬开屏幕排线连接口上的黑色小卡扣。 使用撬棒的尖端撬开屏幕排线连接口上的黑色小卡扣。
    • 使用撬棒的尖端撬开屏幕排线连接口上的黑色小卡扣。
  25. 使用撬棒的尖端撬动排线底部使其从主板上的连接口滑出。 使用撬棒的尖端撬动排线底部使其从主板上的连接口滑出。
    • 使用撬棒的尖端撬动排线底部使其从主板上的连接口滑出。
  26. 使用撬棒的尖端撬开电源/音量键排线连接口上的黑色小卡扣。 使用撬棒的尖端撬开电源/音量键排线连接口上的黑色小卡扣。
    • 使用撬棒的尖端撬开电源/音量键排线连接口上的黑色小卡扣。
  27. 使用撬棒的尖端撬开风扇排线连接口上的灰色小卡扣。 使用撬棒的尖端撬开风扇排线连接口上的灰色小卡扣。
    • 使用撬棒的尖端撬开风扇排线连接口上的灰色小卡扣。
  28. 使用撬棒的平端将白色的同轴线从主板上的连接口撬离。 使用撬棒的平端将白色的同轴线从主板上的连接口撬离。
    • 使用撬棒的平端将白色的同轴线从主板上的连接口撬离。
    Does anyone know what this cable does? If it came completely disconnected from the motherboard, am i screwed?
    DYLLAN HACKETT - 回复
  29. 使用撬棒的平端将黑色的同轴线从主板上的连接口撬离。 使用撬棒的平端将黑色的同轴线从主板上的连接口撬离。
    • 使用撬棒的平端将黑色的同轴线从主板上的连接口撬离。
  30. 使用撬棒的尖端撬开右侧手柄排线连接口上的灰色小卡扣。 使用撬棒的尖端撬开右侧手柄排线连接口上的灰色小卡扣。
    • 使用撬棒的尖端撬开右侧手柄排线连接口上的灰色小卡扣。
  31. 使用撬棒的尖端撬开该处排线连接口上的黑色小卡扣。 使用撬棒的尖端撬开该处排线连接口上的黑色小卡扣。
    • 使用撬棒的尖端撬开该处排线连接口上的黑色小卡扣。
  32. 使用撬棒的尖端撬开左侧手柄排线连接口上的灰色小卡扣。 使用撬棒的尖端撬开左侧手柄排线连接口上的灰色小卡扣。
    • 使用撬棒的尖端撬开左侧手柄排线连接口上的灰色小卡扣。
  33. 移除主板上的4颗2.5mm的十字形#000螺丝。
    • 移除主板上的4颗2.5mm的十字形#000螺丝。
    • 移除USB-C端口上的2颗3.14mm的十字形#000螺丝。
  34. 断开前面提到的所有排线与主板的连接,轻轻地抬起并晃动主板,将其移除。
    • 断开前面提到的所有排线与主板的连接,轻轻地抬起并晃动主板,将其移除。
    It should go without saying but make sure all ribbon cables are released and out of the way so you can lift the board out.
    Josh Lukins - 回复
  35. 使用撬棒的平端将排线撬起。
    • 使用撬棒的平端将排线撬起。
  36. 移除左侧Joy-Con手柄滑轨上的4颗3.8mm的十字形#0螺丝。
    • 移除左侧Joy-Con手柄滑轨上的4颗3.8mm的十字形#0螺丝。
  37. 移除左侧Joy-Con手柄滑轨。
    • 移除左侧Joy-Con手柄滑轨。
    Amazing tutorial but in step 36, what is the Joy con rail attached to? Is that a interior shell?
    ana.madureira9 - 回复
结论
若要重新组装设备,请倒序按照本指南操作。
18等其他人完成本指南。
特别感谢这些译者︰
100%
Kevin Fu正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Blake Klein
于2017年01月29日注册
55,812 信誉积分
创作了49篇指南
Okay you don’t once mention the %#*@ MicroSD slot or even how to remove it. The picture go it being present when you remove the back plate to it just dissapearing when you show the step to remove the shield plate with no explaintion of how?
Joseph Dillander - 回复
Great catch! It looks like I forgot to import that prerequisite. The guide has been updated, thanks!!
Blake Klein -
No problem, also if you can update it to include how to remove the Game card slot too, that’d be great.
Joseph Dillander -
@jdillander91 Game card has been added, thanks!
Blake Klein - 回复
If this was a neon Switch, this would be the rail that gets attached with the blue or the red joy con?
felipemanzur21 - 回复
it would be the Blue joy con
Nick Heilman -
I just did this, after step 11 leave the battery in place just unplug it. Undo the screws holding the rail in. You can slide out the old ribbon and remove the old rail. Put the new one in and slide the new ribbon it into place as there’s a small gap that allows this on the of the circuit board. Clip it in, plug in the battery. Then put it back together. This saves step 12 to 36.
Duncan Nicholls - 回复
The most difficult step is reinserting the motherboard. It is a very tight fit and you have to be sure all the cables that connect to the top of the board are on top of the board. Other that that it is mostly just tedious. Thank you for the guide!
Paul Goggans - 回复
I completed this guide, but the left joy con is still not being detected after the sensor rail was replaced with a sensor rail purchased on this site. The joy con in question will attach and sync with another console, so that leads me to believe it is a fault with the switch console itself. Is there something else that I can replace that would fix this issue?
Sean Douglas - 回复
These instructions work great! My 14 year old son and I replaced the left rail in his switch in roughly 90 minutes.
The only suggestion I have for improvement is that in steps 12 and 13 you remove the heat sink but the photos for steps 14 through 21 show it still in place.
The rest was spot on!!
Thank you!
David Young - 回复
This would be a great guide if you removed steps 12-34 and their correlating reassembly steps. The left joycon rail can be replaced simply by unplugging it from the zif connector and gently sliding out from underneath the motherboard. The new joycon rail can be installed in the exact same manner. This allows for people to install without completely tearing down their switch.
Joseph Shea - 回复
添加评论
浏览统计数据:
过去的24小时: 51
过去的7天: 330
过去的30天: 1,295
总计 20,844
