跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
任天堂3DS XL 电池更换
你所需要的
  1. 任天堂3DS XL 电池更换, 电池: 步骤 1 中的图像 1,2 任天堂3DS XL 电池更换, 电池: 步骤 1 中的图像 2,2
    • 拧下后壳顶部上的两颗4.2mm螺丝。
    • 这些螺丝有锁紧垫圈。可以防止螺丝从后壳上脱落。 本指南中不需要拆下这些垫圈。
    Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
    justjustintuber - 回复
    what type screwdriver do i use?!? its so small!!!!
    Matthew - 回复
    I had success using a #00 Phillips head
    Jake S -
    Can't clip the front of the back cover back in
    Macro Man - 回复
    I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
    Issu -
    I found these were actually #00
    Demosthien - 回复
    The screws in the 1st picture are stripped. What screwdriver head do I use?
    Adric101 - 回复
  2. 任天堂3DS XL 电池更换: 步骤 2 中的图像 1,2 任天堂3DS XL 电池更换: 步骤 2 中的图像 2,2
    • 握住设备,使盖子朝上。
    • 使用塑料打开工具,从右上角开始撬开盖子。
    • 握住盖子的边缘以确保卡扣不会重新意外连接。
    • 寻找手写笔隔层下面的小部分。 如果仍然固定着,请撬开盖子。
    • 取下设备的盖子并放在一边。
    Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
    Jordan Kelly - 回复
  3. 任天堂3DS XL 电池更换: 步骤 3 中的图像 1,3 任天堂3DS XL 电池更换: 步骤 3 中的图像 2,3 任天堂3DS XL 电池更换: 步骤 3 中的图像 3,3
    • 在电池右侧的缺口处插入塑料打开工具。
    • 将电池从底壳中撬起。
    • 从外壳中提起电池将其放置一边。
    My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
    Corban Bennett - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
42等其他人完成本指南。
由衷感谢以下译者:
en zh
57%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Charlene Donlon
于04/08/14注册
10,215 声望
创作了8篇指南
团队
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G13
5 名成员
创作了44篇指南
5条评论
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
Tommy Lynch - 回复
机器无法开机怎么办?是电池的问题吗?
doanaruto - 回复
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Cole Jackson - 回复
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
Scott Vogel - 回复
添加评论
浏览统计数据:
过去 24 小时: 33
过去 7 天: 264
过去 30 天: 1,095
总计 49,506
