简介
请按照本指南更换 Nintendo Switch Lite 中的破旧和退化的电池。
Switch Lite 使用 JIS 螺丝,但您可以在紧要关头使用十字螺丝刀。当心不要滑丝。 iFixit 的 Phillips 刀头设计与 JIS 型螺丝相兼容。
为了您的安全,请在拆卸 Switch 之前将电池放电至 25% 以下。 如果电池在维修过程中意外损坏,这会降低发生危险事件的风险。如果您的电池膨胀,采取适当的预防措施。
注意:此过程需要卸下屏蔽板,该屏蔽板已通过导热胶粘贴到散热器上。在重新安装屏蔽板之前,需要清除并重新涂上导热膏。
你所需要的
用 JIS 000 螺丝刀或官方 iFixit PH 000 螺丝刀卸下固定后面板的螺丝:
设备顶部的两个3.6毫米长的螺丝
设备底部的两个3.6毫米长的螺丝
为防止这些拧的很紧的螺丝滑丝,请向下用力,缓慢操作,如果螺钉无法卸下,请尝试使用不同的螺丝刀。
I accidentally stripped the back screw and now I can't open it. I removed all the other screws. What should I do?
使用 JIS 000 螺丝刀或官方 iFixit PH 000 螺丝刀卸下以下四颗螺丝:
三颗3.1 mm 螺丝
一颗4.5 mm螺丝
There are four screws instead of three mentioned
With how easy it seems to be to do serious damage with the next few steps, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
i stripped a &&^&^$^ screw
Well I actually removed the screw right next to the 4.5 screw. I did not realize it till my son showed me why the plate wouldn't release. Ha ha, it's funny now but yeah not a big deal. I could have bent it badly assuming I took all screws out though. For anyone reading this before going in. 👍
Toastninja - 回复
使用打开工具或指甲翻转主板互连电缆ZIF接口上的小铰链锁片。
The clip broke off when trying to remove this cable. Audio only works through headphones and the display now won’t turn on after the clip broke. Does anyone know where I could get a clip or how I could fix it without it?
Mi è successa la stessa cosa è non so come ripararla! Chissà se c’è un modo!
使用镊子将排线从主板上的接口上取下。
I turned the unit off beforehand, I used tweezers just like the instructions said (ifixit branded) , my device sparked and now it won’t turn back on
The flap came off is it important or is there a way t fix it?
We're you able to get it working without the white flap? My screen is not working after putting it back together and i noticed this white flap was falling off
Did you get it working without the white flap? Everything on the switch works fine except for audio going through headphones and the display not turning on.
do not use metal sharp pointed tweezers! you will rip your ribbon cable. Use the inside of a Bic type pen or something else dull and plastic to pull the cable away by putting the pen part where the first bend is.
用撬棒尖将电池连接器直接向上撬出主板上的插座。
Caution the connector may not be properly soldered onto the motherboard. For me it snapped off the pins and now have to find a place to get that fixed if even possible. may have bricked it.
Yup, broke the connector right off the motherboard. Thanks, ifixit -_-
I backed out when I reached this point. I couldn't risk damaging it. Do u just need to pull it up? Did you mean that it might have been soldered shut below?
Jannalyzer - 回复
You should just need to pull straight up, but make sure you’re pulling on the wires or the gray plug—do not pull on the black socket or it can snap off of the motherboard.
With how easy it seems to be to do serious damage at this point, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
just broke my connector... ifixit PLEASE put a warning on how fragile the solder on this connector is.
Note for this step, you do not need to apply a lot of force. I used two tools here: small screwdriver to hold down the black base, and one side of fine-tipped tweezers to get under all 3 wires. Gently, push down on the tweezers to push the wires upwards, which should force the gray connector up and off the base. It did not take a lot of force. Take your time and it will be fine. Again, like others have said, do NOT pull or pry up the black base.
在电池和电池槽壁之间的间隙中插入一个三角撬片。
仔细挖开电池下方的开口尖的尖端,然后将其沿边缘滑动,以开始切割粘合剂。
It is not mentioned in any of the steps, but in this picture you can see that the strip that has the Volume & Power buttons is removed. I ended up tearing mine while trying to pry the battery out, so I recommend using the opening tool to release the clamp on it and to remove the piece until reassembly.
将三角撬片留在原处,并在电池槽内再滴几滴脱胶剂或异丙醇。
向上倾斜设备的顶部边缘,然后等待1-2分钟,以使异丙醇削弱粘合剂。
继续沿着电池的顶部边缘打开撬片,在下面切更多的粘合剂。
Don't use isopropyl alcohol for this step! Too much will leak behind the battery well and damage the LCD screen, and 1-2 drops is NOT enough to loosen the adhesive here. Highly recommend getting specific adhesive remover, or using a hair dryer (cool to warm setting, no more than 60*F) to loosen the adhesive. Learn from my mistake!
Just want to second Ashley’s comment here. I spent a lot of time and elbow grease prying that pick in there with IPA to no avail. I’m glad I saw their comment because with the hair dryer on medium I got the thing off in 5 minutes. Fortunately, I didn’t have the same leaking into the screen experience with the many more than a couple drops of alcohol I put behind the battery.
I read the comments too late cus I just &&^&@@ up my screen with alcohol drops.
在安装新电池之前,请使用去粘剂或异丙醇和超细纤维布清除残留在电池槽中的所有残留粘合剂。
如果你的新电池没有预安装的粘合剂,请按照本指南在电池底部安装预切的粘合剂。
Now where do I get the new battery that actually fits?
It may be better to go through the screen replacement guide and remove the midframe assembly before trying to remove the battery. The amount of alcohol or acetone you will need to remove the battery will risk the screen and the plastic underneath. It's definitely more work, but the difficulty is the same if you're doing the battery replacement, just takes longer and needs more thermal paste.
I just want to add that removing this adhesive was a massive pain and it took me both nearly half a bottle of iFixit adhesive remover plus the hair drier trick (medium heat, about 5 min) to finally get it out. But it did finally come out.
Ripping the battery out is awful. Don't even risk it. You have to apply so much force just to get it to move half a mm. I used iso and the hairdryer. Finally got it out but punctured the old one while giving the last few heaves with a screwdriver. Do not recommend! . It got hot and started smoking. When I got the new battery in and hooked everything back up, my screen was dead. Top buttons also dead. It turns on but only by holding the home button. Must have damaged the ribbon cable during my fight with the battery. Just take it to a shop.
35等其他人完成本指南。
由衷感谢以下译者:
72%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
19条评论
Hello!
I am preparing to repair my daughters nintendo switch light. It has stopped charging out of no where. I have all the tools, I just can't find the battery anywhere. Where would you recommend buying it from?
If you are still looking Ifixit sells one themselves Nintendo Switch Lite Battery
Thanks for the guide. Battery replacement kits are now available on Amazon: https://www.amazon.com/Nintendo-HDH-001-... (they weren’t in November! I was also looking for this during that time)
Unfortunately, the battery was much harder to remove than I expected. I did use a lot of isopropyl alcohol, but the adhesive they use really was giving me a lot of trouble. I should’ve wisened up and googled other adhesive removal methods or tried a new approach other than prying with the spudgers.
Well, now the LCD now has what looks like pressure damage in the bottom left where I’d imagine a lot of the prying pressure went. It is much more noticeable when the screen goes all-white, and not too bad with darker colors.
I don’t blame iFixit for my mistake of course, and it is really disappointing that Nintendo used the amount of adhesive that they did. But I hope this comment can serve as a warning to others attempting this repair to be more gentle even if it’s refusing to come off.
Yikes! Sorry to hear this. How did you pry with the spudger exactly? If you kept it around the top edge of the battery well then I would assume it wouldn’t damage the screen, but if you inserted the end of the spudger deeper in the battery well and used that point as the fulcrum, then I could see that putting a lot of pressure on the back of the LCD.
@craiglloyd I did an embarrassing amount of spudger prying pretty much everywhere along the top/bottom of the battery, I actually broke a few spudger tips in the process so that might reveal something about my approach…
But, I’m starting to think it may not be LCD damage after all, but rather some isopropyl alcohol caught behind the screen– During my prying, the Switch case was getting pretty heavily warped, so maybe some of the alcohol (that I definitely used in excess) slipped in and got sandwiched under the screen? I started to notice this since the blotches seem like they’ve moved over time. Here’s an image of the screen now https://imgur.com/DjYmFnJ (and the dark gray blotch along the leftside isn’t a shadow, white spots in bottom left I thought were pressure damage)
It’s still very usable / not noticeable on black colors and thanks again for the guide! I can give the screen more time to see if it improves at all, or maybe try going back in and trying to see it is trapped alcohol that can be released
vmgm -
Have the marks faded over time? We have had the ame issue and believe it is the isopropyl alcohol :/ we didn't use loads but found there was a gap at the bottom of where the battery is held which clearly let some of the alcohol through. I'm really hoping it will evaporate over time but not sure :/
Sadly no, the marks are still there, and haven’t been motivated to try to fix yet. I’ve seen some videos online where people can coerce trapped isopropyl alcohol out without having to take a screen apart, but have been hesitant to try out some of the methods.
vmgm -
Thanks for the detailed procedure. I followed the guide closely except for the battery removal procedure. The battery module is wrapped in foil backed plastic. This is easy to slice around the battery edges with an exacto knife. Once it is free, I could lever the battery module out of the bay. Then, I was able to trim the foil outer wrap into strips with the knife and peel it away in pieces. Now I am ready to install my new battery as soon as it arrives.
Same problem here with the Isoproponol which has left my sons screen really discoloured.
Can I suggest you update this tear down as I have always relied on Ifixit for both tool kits and guides and it is a shame that this has left my sons switch damaged. I do expect a bit better of a company that sells parts and tools to do this stuff.
Thanks however for the brilliant Ifixit tool kits.
after changing the battery I have gotten the 2101-0001 error code, how do i fix this?
What kind of thermal paste are we to use?
réparation super facile, juste un peu de patience avec l'alcool isopropylique, mais sinon, rien de plus simple à remplacer :D
As other people have said, the alcohol got into my unit’s display. I was able to get rid of it by using a hair dryer until the screen got really hot. I then used a suction cup on the screen to push and pull. You can see the “bubbles” start to go away. You may need to place it in several areas of the display. It is a bit scary as you need a good amount of force, but eventually it worked itself out. The display now looks perfect. Note that I left the glass screen protector on while I did this.
Same problem here too. Isopropanol also discolored my screen. Along with some mild pulling I assume that's unfixable? (price for a new/refurbished one makes it not worth... for me anyway) The dark clouds have lessened over a few days, but the lighter area that might have has the additional pulling seems to be the same.
Discard and it felt and it wasn't my fault since the Nintendo switch. Just fell and it wasn't my fault.
The dark splotches on the screen, that result from all the isopropyl alcohol needed to dissolve the unreasonable amount of glue under the battery, are not worth the caution. Especially, considering that to replace the screen costs three times what the battery does. I disassembled the backlight and air dried the different layers; I had 5 out. But that did not help! They were already stained by the alcohol. I tried using Zeiss lens cleaner, but that did not help much. The splotches are not as dark now, but they are still there. I think there is still more alcohol trapped between other layers.
My recommendation is to fully discharge the battery, put on eye protection, and use a "jimmy" and plastic cards to remove the battery. By the looks of it, I think that is certainly what iFixit did in their teardown article.
One trick I found was to stack picks under the battery to help push the battery out and away from the housing. Once i ran out of picks, i was able to put the jimmy between two of the picks and pop the battery the rest of the way out.
All my screws got stripped any ideas on how to remove?
Almost A Mammal - 回复
A Y0 screwdriver seemed to work better for me.
Tommy Morrill - 回复
What type of screw driver do I use to un screw the screws and which way
Luca Capito - 回复
Y 0.6 was all I had but it seemed to fit perfectly
Trevor - 回复
