简介
Wi-Fi出故障了?无论你怎么尝试都连不上咖啡店的免费网络了?你可能需要交换你的网卡了。跟着这条指导来学习怎么做。
拆下以下10个固定在上壳体上的螺丝
两个 2.3毫米 的梅花五角螺丝
八个 3.0毫米 的梅花五角螺丝
将AirPort无线网卡上的三根天线用镊子从接口上挑开
把外皮较长的一根天线扣在中间的插槽
外皮较短的天线扣在螺丝旁边的插槽
剩下的一根天线,当然是扣在风扇旁边的插槽啦
若要重新组装你的设备,以逆序方式执行这些说明。
19等其他人完成本指南。
特别感谢这些译者︰
100%
Yiyang Zhao正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
8条评论
Is this responsible for wifi? I re-did my screen and fixed it from blackening, but the wifi icon says "Wi-Fi: No hardware installed". Is this part responsible? If I replace it will I get wifi back?
Howard Lin - 回复
I am having the same exact problem as described by Phil - 04/25/2017
I replaced the card but the wifi and bluetooth keeps disabling itself after few minutes of use , only reboot reactivate it.
I am thinking of changing the antenna ? any ideas? suggestion ?
your help will be very much appreciated .
This isn’t the solution you are looking for, but what I did to my 2015 mbp when the wifi card started failing was getting an external wifi adapter. It’s cheaper, small enough, and works. I got this type: https://www.tp-link.com/us/support/downl... but any type works, this one is just small enough to be unassuming.
stefanikid - 回复
