跳转到主内容
Samsung Galaxy S III Battery Replacement
你所需要的
  1. Samsung Galaxy S III Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S III Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 3 中的图像 2,2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 4 中的图像 2,2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 5 中的图像 2,2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Battery Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy S III Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
结论
90等其他人完成本指南。
3条评论
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - 回复
Super simple. Thanks!
bmwherry - 回复
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 78
总计 64,731
