跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星Gear S3 后盖更换指南
你所需要的
  1. 三星Gear S3 后盖更换指南, 后盖: 步骤 1 中的图像 1,1
    • 倒置您的设备, 使您的手表正面朝下, 背面朝上。
  2. 三星Gear S3 后盖更换指南: 步骤 2 中的图像 1,2 三星Gear S3 后盖更换指南: 步骤 2 中的图像 2,2
    • 用Y00螺丝刀将四个4.2毫米螺丝卸下。
  3. 三星Gear S3 后盖更换指南: 步骤 3 中的图像 1,3 三星Gear S3 后盖更换指南: 步骤 3 中的图像 2,3 三星Gear S3 后盖更换指南: 步骤 3 中的图像 3,3
    • 将金属撬棍沿着后盖与框架之间的缝隙插入。
    • 使劲将后盖从手表的框架上翘起。
    • 事实上这一步确实需要花费一些力气。 如果可以的话, 您可以用短撬棍替代金属撬棍, 这样或许让这一步轻松的多。
    • 这一步的操作会使防水层损坏。
结论
请严格遵循这份指南, 以便您拆修并重组您的设备。
17等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
Lazy_Lazy_Man正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
William Hurty
于10/08/18注册
2,770 声望
创作了3篇指南
团队
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 的会员
CPSU-WHITE-F18S15G2
4 名成员
创作了34篇指南
10条评论
How do I ensure the watch will be waterproof again?
Robert Simpson - 回复
Doesn’t sound like anything a careful application of RTV can’t handle. It can be found in small squeeze tubes at most auto parts stores, where it might be sold as ‘liquid gasket’ or something similar. You can also get it at hardware stores in large tubes meant to be used in caulking guns.
If the original gasket still looks good, no cracks or breaks in it after you remove the cover, I’d wager it will still be water proof after you put it back on. If it’s damaged, I would try to remove it entirely, and likewise, if the replacement cover doesn’t have a seal, you would want to apply some RTV or similar sealant. Ideally, I would use a syringe for this. In the US at least, you can buy needles at a pharmacy without a prescription, you just have to ask for them at the pharmacy counter. Suck some RTV into the syringe, and apply it carefully on the sealing surfaces of the cover. Put the cover on before the RTV dries so it mates to the surfaces, give it about an hour to cure, and it should be water proof.
Jonathan Sherrill -
Will the watch be waterproof again once the new back is installed!??
Paul O'Regan - 回复
The back case of the watch contains an integrated rubberised o-ring.
Force is best applied by taking the band off and working at the edges adjacent to where the band meets the case.
There are small lips here where the thin metal Jimmy can be used to pry the case off with patience and low force by alternating between each end of the case.
The metal spudger tool recommded by this guide is the wrong tool for the job. The ends are far too thick.
Jimmy used: Jimmy
Ben Russell - 回复
I lost 1 screw for the back cover. Where can I get a replacement? I measured the screw. Body Ø.045” x Length .133” x Head Ø.072. Metric conversion probably screw size M1.2 x 3.5mm lg. Any help would be greatly appreciated. Thanks
Bailey Major - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 116
总计 28,719
