跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星Galaxy Tab 10.1吋后面板更换
你所需要的
  1. 三星Galaxy Tab 10.1吋后面板更换, 后面板: 步骤 1 中的图像 1,2 三星Galaxy Tab 10.1吋后面板更换, 后面板: 步骤 1 中的图像 2,2
    • 将平板电脑的底部朝向您。
    • 用Tri-Wing螺丝刀卸下充电端口附近的两颗4.1 mm螺丝。
    Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
    Daniella - 回复
    My model doesn't have any screws!
    Barry - 回复
    What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
    Janine Coetzee - 回复
    I have SG Tab Pro 10.1
    There are no screws..... now what?
    iloveto travel - 回复
    Great instructions! Easy to follow.
    skritzberger - 回复
    My model has no screws.
    Faith Odutola - 回复
    My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
    Elsa Kramer - 回复
    Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
    Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
    If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
    I had to order a new screwdriver.
    George Tomlinson - 回复
    I don't see any screws I have a galaxy tab 4
    Tammylynn Gmarter - 回复
    if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
    divinity76 - 回复
    Mine doesn't have screws so what do I do now?
    katrinawisner - 回复
    charging samsung battery dabka ilaaliyo
    Maxamed Xuseen - 回复
  2. 三星Galaxy Tab 10.1吋后面板更换: 步骤 2 中的图像 1,3 三星Galaxy Tab 10.1吋后面板更换: 步骤 2 中的图像 2,3 三星Galaxy Tab 10.1吋后面板更换: 步骤 2 中的图像 3,3
    • 从左侧的中间开始,并在后面板和前面板组件之间插入塑料撬棒。
    • 仔细地沿着左上角和上边缘移动塑料打开撬棒,将后面板远离设备的其余部分。
    • 沿着您已经打开的一边放置开口,以使后面板与设备的其余部分分离。
    • 一定要小心操作,撬得太大力可能会弄碎屏幕。
  3. 三星Galaxy Tab 10.1吋后面板更换: 步骤 3 中的图像 1,3 三星Galaxy Tab 10.1吋后面板更换: 步骤 3 中的图像 2,3 三星Galaxy Tab 10.1吋后面板更换: 步骤 3 中的图像 3,3
    • 使用塑料撬棒,继续沿右下边缘小心地移动,然后从后面板提起屏幕。
结论
要重新组装您的设备,请按照相反的顺序执行这些说明。
13等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Davie Sy
于09/30/13注册
1,430 声望
创作了4篇指南
团队
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G5
5 名成员
创作了17篇指南
4条评论
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - 回复
It currently won’t start and I have read about a fix that requires the back to be removed.
James Tobin - 回复
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - 回复
i need the panel
Ay Bami - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 39,150
